Macros | Functions
RTEMS File Systems FormatFormat the file system ready for use. More...
#include <inttypes.h>
#include <rtems/rfs/rtems-rfs-data.h>
#include <rtems/rfs/rtems-rfs-inode.h>
#include <rtems/rtems-rfs-format.h>
#include <rtems/rfs/rtems-rfs-dir.h>
Include dependency graph for rtems-rfs-format.c:
#define GIGS(_g)   (((uint64_t)(_g)) * 1024 * 1024)
 Return the number of gigabytes.
#define write_sb(_o, _d)   rtems_rfs_write_u32(sb + (_o), _d)
int rtems_rfs_format (const char *name, const rtems_rfs_format_config *config)
 RFS Format command. More...
◆ rtems_rfs_format()
int rtems_rfs_format ( const char *  name,
const rtems_rfs_format_config *  config
RFS Format command.
Parameters
[in]nameis the device name to format.
[in]configis a pointer to the configuration table.
Return values
-1Error. See errno.
0No error. Format successful.
