Typedefs | Functions
rbtreeimpl.h File Reference
Inlined Routines Associated with Red-Black Trees. More...
#include <rtems/score/rbtree.h>
Include dependency graph for rbtreeimpl.h:
typedef bool(* RBTree_Visitor) (const RBTree_Node *node, RBTree_Direction dir, void *visitor_arg)
 Red-black tree visitor. More...
void _RBTree_Iterate (const RBTree_Control *rbtree, RBTree_Direction dir, RBTree_Visitor visitor, void *visitor_arg)
 Red-black tree iteration. More...
RTEMS_INLINE_ROUTINE RBTree_Direction _RBTree_Opposite_direction (RBTree_Direction the_dir)
 Get the direction opposite to the_dir.
RTEMS_INLINE_ROUTINE RBTree_Direction _RBTree_Direction (const RBTree_Node *the_node, const RBTree_Node *parent)
 Returns the direction of the node. More...
RTEMS_INLINE_ROUTINE bool _RBTree_Is_red (const RBTree_Node *the_node)
 Is this node red. More...
RTEMS_INLINE_ROUTINE RBTree_Node * _RBTree_Sibling (const RBTree_Node *the_node, const RBTree_Node *parent)
 Returns the sibling of the node. More...
RTEMS_INLINE_ROUTINE bool _RBTree_Is_equal (RBTree_Compare_result compare_result)
RTEMS_INLINE_ROUTINE bool _RBTree_Is_greater (RBTree_Compare_result compare_result)
RTEMS_INLINE_ROUTINE bool _RBTree_Is_lesser (RBTree_Compare_result compare_result)
RTEMS_INLINE_ROUTINE void _RBTree_Rotate (RBTree_Node *the_node, RBTree_Direction dir)
 Rotates the node in the specified direction. More...
This include file contains the bodies of the routines which are associated with Red-Black Trees and inlined.
Note
The routines in this file are ordered from simple to complex. No other RBTree Handler routine is referenced unless it has already been defined.
