Data Structures | Macros | Enumerations | Functions | Variables
pppd.h File Reference
#include <stdbool.h>
#include <limits.h>
#include <sys/param.h>
#include <sys/types.h>
#include <sys/time.h>
#include <net/ppp_defs.h>
#include <rtems/rtemsdialer.h>
#include <stdint.h>
#include <varargs.h>
Include dependency graph for pppd.h:
struct  option_t
struct  permitted_ip
struct  pppd_stats
struct  wordlist
struct  protent
struct  option_info
#define __V(x)   (va_alist) va_dcl
#define const
#define volatile
#define NUM_PPP   1 /* One PPP interface supported (per process) */
#define MAXWORDLEN   1024 /* max length of word in file (incl null) */
#define MAXARGS   1 /* max # args to a command */
#define MAXNAMELEN   256 /* max length of hostname or name for auth */
#define MAXSECRETLEN   256 /* max length of password or secret */
#define OPT_VALUE   0xffL /* mask for presupplied value */
#define OPT_HEX   0x100L /* int option is in hex */
#define OPT_NOARG   0x200L /* option doesn't take argument */
#define OPT_OR   0x400L /* OR in argument to value */
#define OPT_INC   0x800L /* increment value */
#define OPT_PRIV   0x1000L /* privileged option */
#define OPT_STATIC   0x2000L /* string option goes into static array */
#define OPT_LLIMIT   0x4000L /* check value against lower limit */
#define OPT_ULIMIT   0x8000L /* check value against upper limit */
#define OPT_LIMITS   (OPT_LLIMIT|OPT_ULIMIT)
#define OPT_ZEROOK   0x10000L /* 0 value is OK even if not within limits */
#define OPT_NOINCR   0x20000L /* value mustn't be increased */
#define OPT_ZEROINF   0x40000L /* with OPT_NOINCR, 0 == infinity */
#define OPT_A2INFO   0x100000L /* addr2 -> option_info to update */
#define OPT_A2COPY   0x200000L /* addr2 -> second location to rcv value */
#define OPT_ENABLE   0x400000L /* use *addr2 as enable for option */
#define OPT_PRIVFIX   0x800000L /* can't be overridden if noauth */
#define OPT_PREPASS   0x1000000L /* do this opt in pre-pass to find device */
#define OPT_INITONLY   0x2000000L /* option can only be set in init phase */
#define OPT_DEVEQUIV   0x4000000L /* equiv to device name */
#define OPT_DEVNAM   (OPT_PREPASS | OPT_INITONLY | OPT_DEVEQUIV)
#define OPT_VAL(x)   ((x) & OPT_VALUE)
#define GIDSET_TYPE   gid_t
#define CALLBACK_DIALIN   1 /* we are expecting the call back */
#define CALLBACK_DIALOUT   2 /* we are dialling out to call back */
#define PHASE_DEAD   0
#define PHASE_INITIALIZE   1
#define PHASE_SERIALCONN   2
#define PHASE_DORMANT   3
#define PHASE_ESTABLISH   4
#define PHASE_AUTHENTICATE   5
#define PHASE_CALLBACK   6
#define PHASE_NETWORK   7
#define PHASE_RUNNING   8
#define PHASE_TERMINATE   9
#define PHASE_DISCONNECT   10
#define PHASE_HOLDOFF   11
#define dbglog   pppd_dbglog
#define info   pppd_info
#define notice   pppd_notice
#define warn   pppd_warn
#define error   pppd_error
#define fatal   pppd_fatal
#define GETCHAR(c, cp)
#define PUTCHAR(c, cp)
#define GETSHORT(s, cp)
#define PUTSHORT(s, cp)
#define GETLONG(l, cp)
#define PUTLONG(l, cp)
#define INCPTR(n, cp)   ((cp) += (n))
#define DECPTR(n, cp)   ((cp) -= (n))
#define TIMEOUT(r, f, t)   ppptimeout((r), (f), (t))
#define UNTIMEOUT(r, f)   pppuntimeout((r), (f))
#define BCOPY(s, d, l)   memcpy(d, s, l)
#define BZERO(s, n)   memset(s, 0, n)
#define PRINTMSG(m, l)   { info("Remote message: %0.*v", l, m); }
#define MAKEHEADER(p, t)
#define EXIT_OK   0
#define EXIT_FATAL_ERROR   1
#define EXIT_OPTION_ERROR   2
#define EXIT_NOT_ROOT   3
#define EXIT_NO_KERNEL_SUPPORT   4
#define EXIT_USER_REQUEST   5
#define EXIT_LOCK_FAILED   6
#define EXIT_OPEN_FAILED   7
#define EXIT_CONNECT_FAILED   8
#define EXIT_PTYCMD_FAILED   9
#define EXIT_NEGOTIATION_FAILED   10
#define EXIT_PEER_AUTH_FAILED   11
#define EXIT_IDLE_TIMEOUT   12
#define EXIT_CONNECT_TIME   13
#define EXIT_CALLBACK   14
#define EXIT_PEER_DEAD   15
#define EXIT_HANGUP   16
#define EXIT_LOOPBACK   17
#define EXIT_INIT_FAILED   18
#define EXIT_AUTH_TOPEER_FAILED   19
#define DEBUGMAIN   1
#define DEBUGUPAP   1
#define DEBUGCHAP   1
#define MAINDEBUG(x)   if (debug) dbglog x
#define SYSDEBUG(x)
#define FSMDEBUG(x)
#define LCPDEBUG(x)
#define IPCPDEBUG(x)
#define IPV6CPDEBUG(x)
#define UPAPDEBUG(x)   if (debug) dbglog x
#define CHAPDEBUG(x)   if (debug) dbglog x
#define IPXCPDEBUG(x)
#define SIGTYPE   int
enum  opt_type {
  o_special_noarg = 0, o_special = 1, o_bool, o_int,
  o_uint32, o_string
void die (int)
void quit (void)
void novm (char *)
void ppptimeout (void(*func)(void *), void *arg, int t)
void pppuntimeout (void(*func)(void *), void *arg)
void update_link_stats (int)
void new_phase (int)
void log_packet (u_char *, int, char *, int)
void print_string (void *, int, void(*)(void *, char *,...), void *)
int slprintf (char *, int, char *,...)
int vslprintf (char *, int, char *, va_list)
size_t strlcpy (char *, const char *, size_t)
size_t strlcat (char *, const char *, size_t)
 like strcat/strncat, doesn't overflow destination buffer, always leaves destination null-terminated (for len > 0).
void pppd_dbglog (char *,...)
void pppd_info (char *,...)
void pppd_notice (char *,...)
void pppd_warn (char *,...)
void pppd_error (char *,...)
void pppd_fatal (char *,...)
void link_required (int)
void link_terminated (int)
void link_down (int)
void link_established (int)
void start_networks (void)
void np_up (int, int)
void np_down (int, int)
void np_finished (int, int)
void auth_peer_fail (int, int)
void auth_peer_success (int, int, char *, int)
void auth_withpeer_fail (int, int)
void auth_withpeer_success (int, int)
int auth_check_options (void)
void auth_reset (int)
int check_passwd (int, char *, int, char *, int, char **)
int get_secret (int, char *, char *, unsigned char *, int *, int)
int auth_ip_addr (int, uint32_t)
int bad_ip_adrs (uint32_t)
void demand_conf (void)
void demand_block (void)
void demand_unblock (void)
void demand_discard (void)
void demand_rexmit (int)
int loop_chars (unsigned char *, int)
int loop_frame (unsigned char *, int)
void sys_init (void)
void sys_cleanup (void)
int sys_check_options (void)
void sys_close (void)
int ppp_available (void)
int get_pty (int *, int *, char *, int)
int open_ppp_loopback (void)
int establish_ppp (int)
void restore_loop (void)
void disestablish_ppp (int)
void clean_check (void)
void set_up_tty (int, int)
void restore_tty (int)
void setdtr (int, int)
void output (int, u_char *, int)
void wait_input (struct timeval *)
void ppp_delay (void)
int read_packet (u_char *)
int get_loop_output (void)
void ppp_send_config (int, int, uint32_t, int, int)
void ppp_set_xaccm (int, ext_accm)
void ppp_recv_config (int, int, uint32_t, int, int)
int ccp_test (int, u_char *, int, int)
void ccp_flags_set (int, int, int)
int ccp_fatal_error (int)
int get_idle_time (int, struct ppp_idle *)
int get_ppp_stats (int, struct pppd_stats *)
int sifvjcomp (int, int, int, int)
int sifup (int)
int sifnpmode (int u, int proto, enum NPmode mode)
int sifdown (int)
int sifaddr (int, uint32_t, uint32_t, uint32_t)
int cifaddr (int, uint32_t, uint32_t)
int sifdefaultroute (int, uint32_t, uint32_t)
int cifdefaultroute (int, uint32_t, uint32_t)
int sifproxyarp (int, uint32_t)
int cifproxyarp (int, uint32_t)
uint32_t GetMask (uint32_t)
int lock (char *)
int relock (int)
void unlock (void)
void logwtmp (const char *, const char *, const char *)
int get_host_seed (void)
int have_route_to (uint32_t)
int parse_args (int argc, char **argv)
int options_from_file (char *filename, int must_exist, int check_prot, int privileged)
int options_from_user (void)
int options_for_tty (void)
int options_from_list (struct wordlist *, int privileged)
int getword (FILE *f, char *word, int *newlinep, char *filename)
void option_error (char *fmt,...)
int int_option (char *, int *)
void add_options (option_t *)
int pppd_kill_link
int hungup
int pppifunit
char ifname []
int pppd_ttyfd
char hostname []
u_char outpacket_buf []
int pppd_phase
int baud_rate
int redirect_stderr
char peer_authname []
int privileged
int need_holdoff
char ** script_env
int detached
GIDSET_TYPE groups [NGROUPS_MAX]
int ngroups
struct pppd_stats link_stats
int using_pty
int log_to_fd
char * no_ppp_msg
volatile int pppd_status
int devnam_fixed
int unsuccess
int do_callback
int doing_callback
dialerfp pppd_dialer
int debug
int kdebugflag
int default_device
char devnam [MAXPATHLEN]
int crtscts
bool modem
int inspeed
uint32_t netmask
bool lockflag
bool nodetach
bool updetach
char * initializer
char * connect_script
char * disconnect_script
char * welcomer
char * ptycommand
int maxconnect
char user [MAXNAMELEN]
char passwd [MAXSECRETLEN]
bool auth_required
bool persist
bool uselogin
char our_name [MAXNAMELEN]
char remote_name [MAXNAMELEN]
bool explicit_remote
bool demand
char * ipparam
bool cryptpap
int idle_time_limit
int holdoff
bool holdoff_specified
bool notty
char * record_file
bool sync_serial
int maxfail
char linkname [MAXPATHLEN]
bool tune_kernel
int connect_delay
char * current_option
int privileged_option
char * option_source
struct protent * protocols []
struct option_info devnam_info
struct option_info initializer_info
struct option_info connect_script_info
struct option_info disconnect_script_info
struct option_info welcomer_info
struct option_info ptycommand_info
int(* new_phase_hook )(int)
int(* idle_time_hook )(struct ppp_idle *)
int(* holdoff_hook )(void)
int(* pap_check_hook )(void)
int(* pap_auth_hook )(char *user, char *passwd)
void(* pap_logout_hook )(void)
int(* pap_passwd_hook )(char *user, char *passwd)
void(* ip_up_hook )(void)
void(* ip_down_hook )(void)
void(* auth_linkup_hook )(void)
void(* auth_linkdown_hook )(void)
◆ GETCHAR
#define GETCHAR (   c,
  cp
Value:
(c) = *(cp)++; \
◆ GETLONG
#define GETLONG (   l,
  cp
Value:
(l) = *(cp)++ << 8; \
(l) |= *(cp)++; (l) <<= 8; \
(l) |= *(cp)++; \
◆ GETSHORT
#define GETSHORT (   s,
  cp
Value:
(s) = *(cp)++ << 8; \
(s) |= *(cp)++; \
◆ MAKEHEADER
#define MAKEHEADER (   p,
Value:
PUTCHAR(PPP_ALLSTATIONS, p); \
PUTCHAR(PPP_UI, p); \
PUTSHORT(t, p); }
◆ PUTCHAR
#define PUTCHAR (   c,
  cp
Value:
*(cp)++ = (u_char) (c); \
◆ PUTLONG
#define PUTLONG (   l,
  cp
Value:
*(cp)++ = (u_char) ((l) >> 24); \
*(cp)++ = (u_char) ((l) >> 16); \
*(cp)++ = (u_char) ((l) >> 8); \
*(cp)++ = (u_char) (l); \
◆ PUTSHORT
#define PUTSHORT (   s,
  cp
Value:
*(cp)++ = (u_char) ((s) >> 8); \
*(cp)++ = (u_char) (s); \
