percpu.h File Reference
This include file defines the per CPU information required by RTEMS. More...
#include <rtems/score/cpu.h>
#include <rtems/score/isrlevel.h>
#include <rtems/score/smp.h>
#include <rtems/score/smplock.h>
#include <rtems/score/timestamp.h>
Include dependency graph for percpu.h:
struct  Per_CPU_Stats
 Per-CPU statistics. More...
struct  Per_CPU_Control
 Per CPU Core Structure. More...
struct  Per_CPU_Control_envelope
#define _Per_CPU_Acquire(cpu)
#define _Per_CPU_Release(cpu)
#define _Per_CPU_ISR_disable_and_acquire(cpu, isr_cookie)
#define _Per_CPU_Release_and_ISR_enable(cpu, isr_cookie)
#define _Per_CPU_Acquire_all(isr_cookie)   _ISR_Disable( isr_cookie )
#define _Per_CPU_Release_all(isr_cookie)   _ISR_Enable( isr_cookie )
#define _Per_CPU_Get_snapshot()   ( &_Per_CPU_Information[ _SMP_Get_current_processor() ].per_cpu )
#define _Per_CPU_Get()   _Per_CPU_Get_snapshot()
#define _Thread_Dispatch_disable_level   _Per_CPU_Get()->thread_dispatch_disable_level
#define _Thread_Heir   _Per_CPU_Get()->heir
#define _Thread_Executing   _Per_CPU_Get()->executing
#define _ISR_Nest_level   _Per_CPU_Get()->isr_nest_level
#define _CPU_Interrupt_stack_low   _Per_CPU_Get()->interrupt_stack_low
#define _CPU_Interrupt_stack_high   _Per_CPU_Get()->interrupt_stack_high
#define _Thread_Dispatch_necessary   _Per_CPU_Get()->dispatch_necessary
#define _Thread_Time_of_last_context_switch   _Per_CPU_Get()->time_of_last_context_switch
typedef struct Per_CPU_Control Per_CPU_Control
RTEMS_INLINE_ROUTINE struct Thread_Control * _Thread_Get_executing (void)
 Returns the thread control block of the executing thread. More...
Per_CPU_Control_envelope _Per_CPU_Information [] CPU_STRUCTURE_ALIGNMENT
 Set of Per CPU Core Information. More...
