Data Structures | Macros | Enumerations | Functions | Variables
nios2-utility.h File Reference
NIOS II Utility. More...
#include <stddef.h>
#include <stdint.h>
#include <stdbool.h>
Include dependency graph for nios2-utility.h:
struct  Nios2_MPU_Configuration
struct  Nios2_MPU_Region_descriptor
#define NIOS2_CTLREG_INDEX_STATUS   0
#define NIOS2_CTLREG_INDEX_ESTATUS   1
#define NIOS2_CTLREG_INDEX_BSTATUS   2
#define NIOS2_CTLREG_INDEX_IENABLE   3
#define NIOS2_CTLREG_INDEX_IPENDING   4
#define NIOS2_CTLREG_INDEX_CPUID   5
#define NIOS2_CTLREG_INDEX_EXCEPTION   7
#define NIOS2_CTLREG_INDEX_PTEADDR   8
#define NIOS2_CTLREG_INDEX_TLBACC   9
#define NIOS2_CTLREG_INDEX_TLBMISC   10
#define NIOS2_CTLREG_INDEX_BADADDR   12
#define NIOS2_CTLREG_INDEX_CONFIG   13
#define NIOS2_CTLREG_INDEX_MPUBASE   14
#define NIOS2_CTLREG_INDEX_MPUACC   15
#define NIOS2_CONTEXT_OFFSET_R16   0
#define NIOS2_CONTEXT_OFFSET_R17   4
#define NIOS2_CONTEXT_OFFSET_R18   8
#define NIOS2_CONTEXT_OFFSET_R19   12
#define NIOS2_CONTEXT_OFFSET_R20   16
#define NIOS2_CONTEXT_OFFSET_R21   20
#define NIOS2_CONTEXT_OFFSET_R22   24
#define NIOS2_CONTEXT_OFFSET_R23   28
#define NIOS2_CONTEXT_OFFSET_FP   32
#define NIOS2_CONTEXT_OFFSET_STATUS   36
#define NIOS2_CONTEXT_OFFSET_SP   40
#define NIOS2_CONTEXT_OFFSET_RA   44
#define NIOS2_CONTEXT_OFFSET_THREAD_DISPATCH_DISABLED   48
#define NIOS2_CONTEXT_OFFSET_STACK_MPUBASE   52
#define NIOS2_CONTEXT_OFFSET_STACK_MPUACC   56
#define NIOS2_ISR_STATUS_MASK_IIC   0xfffffffe
#define NIOS2_ISR_STATUS_BITS_IIC   0x00000000
#define NIOS2_ISR_STATUS_MASK_EIC_IL   0xfffffc0f
#define NIOS2_ISR_STATUS_BITS_EIC_IL   0x000003f0
#define NIOS2_ISR_STATUS_MASK_EIC_RSIE   0xf7ffffff
#define NIOS2_ISR_STATUS_BITS_EIC_RSIE   0x00000000
#define NIOS2_STATUS_RSIE   (1 << 23)
#define NIOS2_STATUS_NMI   (1 << 22)
#define NIOS2_STATUS_PRS_OFFSET   16
#define NIOS2_STATUS_PRS_MASK   (0x3f << NIOS2_STATUS_PRS_OFFSET)
#define NIOS2_STATUS_CRS_OFFSET   10
#define NIOS2_STATUS_CRS_MASK   (0x3f << NIOS2_STATUS_CRS_OFFSET)
#define NIOS2_STATUS_IL_OFFSET   4
#define NIOS2_STATUS_IL_MASK   (0x3f << NIOS2_STATUS_IL_OFFSET)
#define NIOS2_STATUS_IH   (1 << 3)
#define NIOS2_STATUS_EH   (1 << 2)
#define NIOS2_STATUS_U   (1 << 1)
#define NIOS2_STATUS_PIE   (1 << 0)
#define NIOS2_EXCEPTION_CAUSE_OFFSET   2
#define NIOS2_EXCEPTION_CAUSE_MASK   (0x1f << NIOS2_EXCEPTION_CAUSE_OFFSET)
#define NIOS2_PTEADDR_PTBASE_OFFSET   22
#define NIOS2_PTEADDR_PTBASE_MASK   (0x3ff << NIOS2_PTEADDR_PTBASE_OFFSET)
#define NIOS2_PTEADDR_VPN_OFFSET   2
#define NIOS2_PTEADDR_VPN_MASK   (0xfffff << NIOS2_PTEADDR_VPN_OFFSET)
#define NIOS2_TLBACC_IG_OFFSET   25
#define NIOS2_TLBACC_IG_MASK   (0x3ff << NIOS2_TLBACC_IG_OFFSET)
#define NIOS2_TLBACC_C   (1 << 24)
#define NIOS2_TLBACC_R   (1 << 23)
#define NIOS2_TLBACC_W   (1 << 22)
#define NIOS2_TLBACC_X   (1 << 21)
#define NIOS2_TLBACC_G   (1 << 20)
#define NIOS2_TLBACC_PFN_OFFSET   2
#define NIOS2_TLBACC_PFN_MASK   (0xfffff << NIOS2_TLBACC_PFN_OFFSET)
#define NIOS2_TLBMISC_WAY_OFFSET   20
#define NIOS2_TLBMISC_WAY_MASK   (0xf << NIOS2_TLBMISC_WAY_OFFSET)
#define NIOS2_TLBMISC_RD   (1 << 19)
#define NIOS2_TLBMISC_WE   (1 << 18)
#define NIOS2_TLBMISC_PID_OFFSET   5
#define NIOS2_TLBMISC_PID_MASK   (0x3fff << NIOS2_TLBMISC_PID_OFFSET)
#define NIOS2_TLBMISC_DBL   (1 << 3)
#define NIOS2_TLBMISC_BAD   (1 << 2)
#define NIOS2_TLBMISC_PERM   (1 << 1)
#define NIOS2_TLBMISC_D   (1 << 0)
#define NIOS2_CONFIG_ANI   (1 << 1)
#define NIOS2_CONFIG_PE   (1 << 0)
#define NIOS2_MPUBASE_BASE_OFFSET   6
#define NIOS2_MPUBASE_BASE_MASK   (0x1ffffff << NIOS2_MPUBASE_BASE_OFFSET)
#define NIOS2_MPUBASE_INDEX_OFFSET   1
#define NIOS2_MPUBASE_INDEX_MASK   (0x0000003e)
#define NIOS2_MPUBASE_D   (1 << 0)
#define NIOS2_MPUACC_MASK_OFFSET   6
#define NIOS2_MPUACC_MASK_MASK   (0x7fffffc0)
#define NIOS2_MPUACC_LIMIT_OFFSET   6
#define NIOS2_MPUACC_LIMIT_MASK   (0xffffffc0)
#define NIOS2_MPUACC_C   (1 << 5)
#define NIOS2_MPUACC_PERM_OFFSET   2
#define NIOS2_MPUACC_PERM_MASK   (0x0000001c)
#define NIOS2_MPUACC_RD   (1 << 1)
#define NIOS2_MPUACC_WR   (1 << 0)
#define NIOS2_MPU_REGION_DESC_INST(index, base, end)
#define NIOS2_MPU_REGION_DESC_DATA_RO(index, base, end)
#define NIOS2_MPU_REGION_DESC_DATA_RW(index, base, end)
#define NIOS2_MPU_REGION_DESC_DATA_IO(index, base, end)
enum  Nios2_MPU_Region_permissions {
  NIOS2_MPU_INST_PERM_SVR_NONE_USER_NONE = 0, NIOS2_MPU_INST_PERM_SVR_EXECUTE_USER_NONE, NIOS2_MPU_INST_PERM_SVR_EXECUTE_USER_EXECUTE, NIOS2_MPU_DATA_PERM_SVR_NONE_USER_NONE = 0,
  NIOS2_MPU_DATA_PERM_SVR_READONLY_USER_NONE, NIOS2_MPU_DATA_PERM_SVR_READONLY_USER_READONLY, NIOS2_MPU_DATA_PERM_SVR_READWRITE_USER_NONE = 4, NIOS2_MPU_DATA_PERM_SVR_READWRITE_USER_READONLY,
  NIOS2_MPU_DATA_PERM_SVR_READWRITE_USER_READWRITE
uint32_t _Nios2_ISR_Set_level (uint32_t new_level, uint32_t status)
void _Nios2_MPU_Set_configuration (const Nios2_MPU_Configuration *config)
const Nios2_MPU_Configuration * _Nios2_MPU_Get_configuration (void)
bool _Nios2_MPU_Setup_region_registers (const Nios2_MPU_Configuration *config, const Nios2_MPU_Region_descriptor *desc, uint32_t *mpubase, uint32_t *mpuacc)
bool _Nios2_MPU_Get_region_descriptor (const Nios2_MPU_Configuration *config, int index, bool data, Nios2_MPU_Region_descriptor *desc)
int _Nios2_MPU_Get_disabled_region_index (const Nios2_MPU_Configuration *config, bool data, int begin, int end)
 Searches the region table part for a disabled region. More...
bool _Nios2_MPU_Add_region (const Nios2_MPU_Configuration *config, const Nios2_MPU_Region_descriptor *desc, bool force)
 Adds a region according to region descriptor desc. More...
uint32_t _Nios2_MPU_Disable_protected (void)
void _Nios2_MPU_Reset (const Nios2_MPU_Configuration *config)
uint32_t _Nios2_Thread_dispatch_disabled
 Nios II specific thread dispatch disabled indicator. More...
char _Nios2_ISR_Status_mask []
 This global symbol specifies the status register mask used to disable interrupts. More...
char _Nios2_ISR_Status_bits []
 This symbol specifies the status register bits used to disable interrupts. More...
NIOS II Utility.
◆ NIOS2_MPU_REGION_DESC_DATA_IO
#define NIOS2_MPU_REGION_DESC_DATA_IO (   index,
  base,
  end
Value:
(index), (base), (end), NIOS2_MPU_DATA_PERM_SVR_READWRITE_USER_NONE, \
true, false, false, true \
◆ NIOS2_MPU_REGION_DESC_DATA_RO
#define NIOS2_MPU_REGION_DESC_DATA_RO (   index,
  base,
  end
Value:
(index), (base), (end), NIOS2_MPU_DATA_PERM_SVR_READONLY_USER_NONE, \
true, true, false, true \
◆ NIOS2_MPU_REGION_DESC_DATA_RW
#define NIOS2_MPU_REGION_DESC_DATA_RW (   index,
  base,
  end
Value:
◆ NIOS2_MPU_REGION_DESC_INST
#define NIOS2_MPU_REGION_DESC_INST (   index,
  base,
  end
Value:
(index), (base), (end), NIOS2_MPU_INST_PERM_SVR_EXECUTE_USER_NONE, \
false, false, false, true \
◆ _Nios2_MPU_Add_region()
bool _Nios2_MPU_Add_region ( const Nios2_MPU_Configuration *  config,
const Nios2_MPU_Region_descriptor *  desc,
bool  force
If force is true, then an enabled region will be overwritten.
Return values
trueSuccessful operation.
falseInvalid region descriptor or region already in use.
◆ _Nios2_MPU_Get_disabled_region_index()
int _Nios2_MPU_Get_disabled_region_index ( const Nios2_MPU_Configuration *  config,
bool  data,
int  begin,
int  end
The table will be searched between indices begin and end. The end index is not part of the search range. If end is negative, then the region count will be used. Thus a begin of 0 and a end of -1 will specify the complete table.
Return values
-1No disabled region is available.
otherIndex of disabled region.
Variable Documentation
◆ _Nios2_ISR_Status_bits
char _Nios2_ISR_Status_bits[]
The board support package must provide a global symbol with this name to specify the status register bits used in _CPU_ISR_Disable().
◆ _Nios2_ISR_Status_mask
char _Nios2_ISR_Status_mask[]
The board support package must provide a global symbol with this name to specify the status register mask used in _CPU_ISR_Disable().
◆ _Nios2_Thread_dispatch_disabled
This global variable is used by the interrupt dispatch support for the external interrupt controller (EIC) with shadow registers. This makes it possible to do the thread dispatch after an interrupt without disabled interrupts and thus probably reduce the maximum interrupt latency. Its purpose is to prevent unbounded stack usage of the interrupted thread.
