nios2-mpu-add-region.c File Reference
#include <rtems/score/nios2-utility.h>
Include dependency graph for nios2-mpu-add-region.c:
int _Nios2_MPU_Get_disabled_region_index (const Nios2_MPU_Configuration *config, bool data, int begin, int end)
 Searches the region table part for a disabled region. More...
bool _Nios2_MPU_Add_region (const Nios2_MPU_Configuration *config, const Nios2_MPU_Region_descriptor *desc, bool force)
 Adds a region according to region descriptor desc. More...
◆ _Nios2_MPU_Add_region()
bool _Nios2_MPU_Add_region ( const Nios2_MPU_Configuration *  config,
const Nios2_MPU_Region_descriptor *  desc,
bool  force
If force is true, then an enabled region will be overwritten.
Return values
trueSuccessful operation.
falseInvalid region descriptor or region already in use.
◆ _Nios2_MPU_Get_disabled_region_index()
int _Nios2_MPU_Get_disabled_region_index ( const Nios2_MPU_Configuration *  config,
bool  data,
int  begin,
int  end
The table will be searched between indices begin and end. The end index is not part of the search range. If end is negative, then the region count will be used. Thus a begin of 0 and a end of -1 will specify the complete table.
Return values
-1No disabled region is available.
otherIndex of disabled region.
