nfs.c File Reference
NFS Client Implementation for RTEMSHooks Into the RTEMS NFS Filesystem. More...
#include <rtems/libio.h>
#include <rtems/libio_.h>
#include <rtems/seterr.h>
#include <stdint.h>
#include <assert.h>
#include <sys/stat.h>
#include <dirent.h>
#include <netdb.h>
#include <ctype.h>
#include <netinet/in.h>
#include <arpa/inet.h>
#include <nfs_prot.h>
#include <mount_prot.h>
#include "rpcio.h"
#include "librtemsNfs.h"
Include dependency graph for nfs.c:
struct  strbuf
struct  readlinkres_strbuf
struct  DirInfoRec_
struct  serporidok
struct  serporid
struct  NfsRec_
struct  NfsNodeRec_
struct  nfsstats
struct  ResolvePathArgRec_
#define CONFIG_AVG_NAMLEN   10
#define CONFIG_NFS_SMALL_XACT_SIZE   800 /* size of RPC arguments for non-write ops */
#define CONFIG_ATTR_LIFETIME   10/*secs*/
#define DEFAULT_NFS_ST_BLKSIZE   NFS_MAXDATA
#define CONFIG_NFS_BIG_XACT_SIZE   UDPMSGSIZE /* dont change this */
#define NFSCALL_TIMEOUT   (&_nfscalltimeout)
#define MNTCALL_TIMEOUT   (&_nfscalltimeout)
#define DELIM   '/'
#define HOSTDELIM   ':'
#define UPDIR   ".."
#define UIDSEP   '@'
#define NFS_VERSION_2   NFS_VERSION
#define NFS_MAJOR   (nfsGlob.nfs_major)
#define NFS_MAKE_DEV_T_INO_HACK(node)
#define NFS_MAKE_DEV_T(node)
#define DIRENT_HEADER_SIZE
#define DEBUG_COUNT_NODES   (1<<0)
#define DEBUG_TRACK_NODES   (1<<1)
#define DEBUG_EVALPATH   (1<<2)
#define DEBUG_READDIR   (1<<3)
#define DEBUG_SYSCALLS   (1<<4)
#define STATIC   static
#define MUTEX_ATTRIBUTES
#define LOCK(s)
#define UNLOCK(s)
#define NFS_GLOBAL_ACQUIRE(lock_context)   rtems_interrupt_lock_acquire(&nfs_global_lock, lock_context)
#define NFS_GLOBAL_RELEASE(lock_context)   rtems_interrupt_lock_release(&nfs_global_lock, lock_context)
#define SERP_ARGS(node)   ((node)->serporid.serporid_u.serporid.arg_u)
#define SERP_ATTR(node)   ((node)->serporid.serporid_u.serporid.attributes)
#define SERP_FILE(node)   ((node)->serporid.serporid_u.serporid.file)
#define READ_LONG_IS_ATOMIC
#define SATTR_MODE   (1<<0)
#define SATTR_UID   (1<<1)
#define SATTR_GID   (1<<2)
#define SATTR_SIZE   (1<<3)
#define SATTR_ATIME   (1<<4)
#define SATTR_TOUCHA   (1<<5)
#define SATTR_MTIME   (1<<6)
#define SATTR_TOUCHM   (1<<7)
#define SATTR_TOUCH   (SATTR_TOUCHM | SATTR_TOUCHA)
typedef struct strbuf strbuf
typedef struct readlinkres_strbuf readlinkres_strbuf
typedef struct DirInfoRec_ DirInfoRec
typedef struct DirInfoRec_ * DirInfo
typedef struct serporidok serporidok
typedef struct serporid serporid
typedef uint32_t TimeStamp
typedef struct NfsRec_ NfsRec
typedef struct NfsRec_ * Nfs
typedef struct NfsNodeRec_ NfsNodeRec
typedef struct NfsNodeRec_ * NfsNode
typedef struct ResolvePathArgRec_ ResolvePathArgRec
typedef struct ResolvePathArgRec_ * ResolvePathArg
int nfsMountsShow (FILE *)
 Dump a list of the currently mounted NFS to a file. More...
rtems_status_code rtems_filesystem_resolve_location (char *buf, int len, rtems_filesystem_location_info_t *loc)
 A utility routine to find the path leading to a rtems_filesystem_location_info_t node. More...
int nfsInit (int smallPoolDepth, int bigPoolDepth)
 NFS driver interface. More...
int nfsCleanup (void)
 Driver cleanup code. More...
STATIC int nfscall (RpcUdpServer srvr, int proc, xdrproc_t xargs, void *pargs, xdrproc_t xres, void *pres)
int rtems_nfs_initialize (rtems_filesystem_mount_table_entry_t *mt_entry, const void *data)
 Filesystem mount table mount handler. More...
STATIC void nfs_fsunmount_me (rtems_filesystem_mount_table_entry_t *mt_entry)
int nfsSetTimeout (uint32_t timeout_ms)
 Set the timeout (initial default: 10s) for NFS and mount calls. More...
uint32_t nfsGetTimeout (void)
 Read current timeout (in milliseconds)
const struct _rtems_filesystem_operations_table nfs_fs_ops
int nfsStBlksize = DEFAULT_NFS_ST_BLKSIZE
◆ DIRENT_HEADER_SIZE
Value:
( sizeof(struct dirent) - \
sizeof( ((struct dirent *)0)->d_name ) )
◆ LOCK
#define LOCK (   s)
Value:
do { \
rtems_semaphore_obtain((s), \
} while (0)
#define RTEMS_NO_TIMEOUT
Constant for indefinite wait.
Definition: rtems.h:170
#define RTEMS_WAIT
This option constants indicates that the task is to wait on resource.
Definition: options.h:56
◆ MUTEX_ATTRIBUTES
Value:
RTEMS_PRIORITY | \
RTEMS_INHERIT_PRIORITY | \
RTEMS_BINARY_SEMAPHORE)
#define RTEMS_LOCAL
This is the attribute constant to indicate local resource.
Definition: attr.h:53
◆ NFS_MAKE_DEV_T
#define NFS_MAKE_DEV_T (   node)
Value:
rtems_filesystem_make_dev_t( NFS_MAJOR, \
(((rtems_device_minor_number)((node)->nfs->id))<<16) | (SERP_ATTR((node)).fsid & (((rtems_device_minor_number)1<<16)-1)) )
Definition: mount.h:43
◆ NFS_MAKE_DEV_T_INO_HACK
#define NFS_MAKE_DEV_T_INO_HACK (   node)
Value:
(((rtems_device_minor_number)((node)->nfs->id))<<16) | (((rtems_device_minor_number)SERP_ATTR((node)).fileid) >> 16) )
◆ UNLOCK
#define UNLOCK (   s)
Value:
} while (0)
rtems_status_code rtems_semaphore_release(rtems_id id)
RTEMS Semaphore Release.
Definition: semrelease.c:56
Variable Documentation
◆ nfs_fs_ops
Initial value:
.lock_h = nfs_lock,
.unlock_h = nfs_unlock,
.eval_path_h = nfs_eval_path,
.link_h = nfs_link,
.are_nodes_equal_h = nfs_are_nodes_equal,
.mknod_h = nfs_mknod,
.rmnod_h = nfs_rmnod,
.fchmod_h = nfs_fchmod,
.chown_h = nfs_chown,
.clonenod_h = nfs_clonenode,
.freenod_h = nfs_freenode,
.fsunmount_me_h = nfs_fsunmount_me,
.utime_h = nfs_utime,
.symlink_h = nfs_symlink,
.readlink_h = nfs_readlink,
.rename_h = nfs_rename,
int rtems_filesystem_default_unmount(rtems_filesystem_mount_table_entry_t *mt_entry)
Definition: default_unmount.c:21
int rtems_filesystem_default_mount(rtems_filesystem_mount_table_entry_t *mt_entry)
Definition: default_mount.c:21
int rtems_filesystem_default_statvfs(const rtems_filesystem_location_info_t *loc, struct statvfs *buf)
Definition: default_statvfs.c:23
