Files | Macros | Typedefs | Enumerations | Functions | Variables
NFS Client Library
file  mount_prot.h
 Nfsclient Mount Prot.
file  librtemsNfs.h
 Public Interface to the NFS Client Library for RTEMS.
file  rpcio.h
 A Multithreaded RPC/UDP Multiplexor.
#define RPCIOD_DEFAULT_ID   0xdef10000
typedef struct RpcUdpServerRec_ * RpcUdpServer
typedef struct RpcUdpXactRec_ * RpcUdpXact
typedef RpcUdpXact RpcUdpClnt
typedef void * XdrProcT
 Mute compiler warnings.
typedef void * CaddrT
typedef struct RpcUdpXactPoolRec_ * RpcUdpXactPool
enum  XactPoolGetMode { XactGetFail, XactGetWait, XactGetCreate }
void rpcSetXIDs (uint32_t xid)
 Sets the XIDs of the RPC transaction hash table. More...
int rpcUdpInit (void)
 Initialize the driver. More...
int rpcUdpCleanup (void)
 RPC cleanup and stop. More...
int nfsInit (int smallPoolDepth, int bigPoolDepth)
 NFS driver interface. More...
int nfsCleanup (void)
 Driver cleanup code. More...
int nfsMountsShow (FILE *f)
 Dump a list of the currently mounted NFS to a file. More...
int rtems_nfs_initialize (rtems_filesystem_mount_table_entry_t *mt_entry, const void *data)
 Filesystem mount table mount handler. More...
rtems_status_code rtems_filesystem_resolve_location (char *buf, int len, rtems_filesystem_location_info_t *loc)
 A utility routine to find the path leading to a rtems_filesystem_location_info_t node. More...
int nfsSetTimeout (uint32_t timeout_ms)
 Set the timeout (initial default: 10s) for NFS and mount calls. More...
uint32_t nfsGetTimeout (void)
 Read current timeout (in milliseconds)
enum clnt_stat rpcUdpServerCreate (struct sockaddr_in *paddr, rpcprog_t prog, rpcvers_t vers, u_long uid, u_long gid, RpcUdpServer *pclnt)
void rpcUdpServerDestroy (RpcUdpServer s)
int rpcUdpStats (FILE *f)
 Dump statistics to a file (stdout if NULL);. More...
enum clnt_stat rpcUdpClntCreate (struct sockaddr_in *psaddr, rpcprog_t prog, rpcvers_t vers, u_long uid, u_long gid, RpcUdpClnt *pclnt)
void RpcUdpClntDestroy (RpcUdpClnt clnt)
enum clnt_stat rpcUdpClntCall (RpcUdpClnt clnt, u_long proc, XdrProcT xargs, CaddrT pargs, XdrProcT xres, CaddrT pres, struct timeval *timeout)
RpcUdpXact rpcUdpXactCreate (u_long program, u_long version, u_long size)
void rpcUdpXactDestroy (RpcUdpXact xact)
enum clnt_stat rpcUdpSend (RpcUdpXact xact, RpcUdpServer srvr, struct timeval *timeout, u_long proc, xdrproc_t xres, caddr_t pres, xdrproc_t xargs, caddr_t pargs,...)
 Send a transaction.
enum clnt_stat rpcUdpRcv (RpcUdpXact xact)
 Wait for a transaction to complete.
enum clnt_stat rpcUdpCallRp (struct sockaddr_in *pserver_addr, u_long prog, u_long vers, u_long proc, XdrProcT xargs, CaddrT pargs, XdrProcT xres, CaddrT pres, u_long uid, u_long gid, struct timeval *timeout)
RpcUdpXactPool rpcUdpXactPoolCreate (rpcprog_t prog, rpcvers_t version, int xactsize, int poolsize)
void rpcUdpXactPoolDestroy (RpcUdpXactPool pool)
RpcUdpXact rpcUdpXactPoolGet (RpcUdpXactPool pool, XactPoolGetMode mode)
void rpcUdpXactPoolPut (RpcUdpXact xact)
rtems_task_priority rpciodPriority
 RPCIO driver interface. More...
◆ nfsCleanup()
int nfsCleanup ( void  )
Return values
0on success, nonzero if still in use
◆ nfsInit()
int nfsInit ( int  smallPoolDepth,
int  bigPoolDepth
Initialize the NFS driver.
The RPCIO driver must have been initialized prior to calling this.
Note, called in nfsfs initialise when mount is called with defaults.
ARGS: depth of the small and big transaction pools, i.e. how many transactions (buffers) should always be kept around.
(If more transactions are needed, they are created and destroyed on the fly).
Supply zero values to have the driver chose reasonable defaults.
Return values
0Successful operation.
-1An error occurred. The errno is set to indicate the error.
◆ nfsMountsShow()
int nfsMountsShow ( FILE *  f)
Dump a list of the currently mounted NFS to a file (stdout is used in case f==NULL)
◆ nfsSetTimeout()
int nfsSetTimeout ( uint32_t  timeout_ms)
Return values
0on success, nonzero if the requested timeout is less than a clock tick or if the system clock rate cannot be determined.
◆ rpcSetXIDs()
void rpcSetXIDs ( uint32_t  xid)
The active RPC transactions are stored in a hash table. Each table entry contains the XID of its corresponding transaction. The XID consists of two parts. The lower part is determined by the hash table index. The upper part is incremented in each send operation.
This function sets the upper part of the XID in all hash table entries. This can be used to ensure that the XIDs are not reused in a short interval for example during a boot process or after resets.
Parameters
[in]xidThe upper part is used to set the upper XID part of the hash table entries.
◆ rpcUdpCleanup()
int rpcUdpCleanup ( void  )
Return values
References rtems_build_name, RTEMS_DEFAULT_ATTRIBUTES, and rtems_semaphore_create().
◆ rpcUdpInit()
int rpcUdpInit ( void  )
Note, called in nfsfs initialise when mount is called.
Return values
0on success, -1 on failure
◆ rpcUdpStats()
int rpcUdpStats ( FILE *  f)
Return values
0for convenience
◆ rtems_filesystem_resolve_location()
rtems_status_code rtems_filesystem_resolve_location ( char *  buf,
int  len,
rtems_filesystem_location_info_t *  loc
This should really be present in libcsupport...
Parameters
[in]'loc'and a buffer 'buf' (length 'len') to hold the path.
[out]pathcopied into 'buf'
Return values
0on success, RTEMS error code on error.
◆ rtems_nfs_initialize()
int rtems_nfs_initialize ( rtems_filesystem_mount_table_entry_t *  mt_entry,
const void *  data
Filesystem mount table mount handler. Do not call, use the mount call.
Variable Documentation
◆ rpciodPriority
If you need RPCIO for other purposes than NFS you may want to include <rpcio.h> #include "rpcio.h" Priority of daemon; may be setup prior to calling rpcUdpInit(); otherwise the network task priority from the rtems_bsdnet_config is used...
