Files | Macros | Functions
Stack Checker Mechanism
Stack Checker Information. More...
file  check.c
 Stack Overflow Check User Extension SetNOTE: This extension set automatically determines at initialization time whether the stack for this CPU grows up or down and installs the correct extension routines for that direction.
#define RTEMS_STACK_CHECKER_EXTENSION
 Stack Checker Extension Set Definition. More...
bool rtems_stack_checker_is_blown (void)
 Checks if current task is blown its stack. More...
void rtems_stack_checker_report_usage (void)
 Print the stack usage report using printk. More...
void rtems_stack_checker_report_usage_with_plugin (void *context, rtems_printk_plugin_t print)
 Print the stack usage report using caller's routine. More...
bool rtems_stack_checker_create_extension (Thread_Control *running, Thread_Control *the_thread)
 Stack Checker Task Create Extension. More...
void rtems_stack_checker_begin_extension (Thread_Control *the_thread)
 Stack Checker Task Begin Extension. More...
void rtems_stack_checker_switch_extension (Thread_Control *running, Thread_Control *heir)
 Stack Checker Task Context Switch Extension. More...
This include file contains information necessary to utilize and install the stack checker mechanism.
◆ RTEMS_STACK_CHECKER_EXTENSION
Value:
rtems_stack_checker_create_extension, /* rtems_task_create */ \
0, /* rtems_task_start */ \
0, /* rtems_task_restart */ \
0, /* rtems_task_delete */ \
rtems_stack_checker_switch_extension, /* task_switch */ \
rtems_stack_checker_begin_extension, /* task_begin */ \
0, /* task_exitted */ \
0 /* rtems_stack_checker_fatal_extension */, /* fatal */ \
This macro defines the user extension handler set for the stack checker. This macro is normally only used by confdefs.h.
◆ rtems_stack_checker_begin_extension()
void rtems_stack_checker_begin_extension ( Thread_Control *  the_thread)
This method is the task begin extension for the stack checker.
Parameters
[in]the_threadpoints to task starting to execute
Note
This is called from the internal method _Thread_Handler.
References Objects_Control::id, and Thread_Control::Object.
◆ rtems_stack_checker_create_extension()
bool rtems_stack_checker_create_extension ( Thread_Control *  running,
This method is the task create extension for the stack checker.
Parameters
[in]runningpoints to the currently executing task
[in]the_threadpoints to the newly created task
Note
If this this the first task created, the stack checker will automatically intialize itself.
◆ rtems_stack_checker_is_blown()
bool rtems_stack_checker_is_blown ( void  )
This method is used to determine if the current stack pointer of the currently executing task is within bounds.
Return values
Thismethod returns true if the currently executing task has blown its stack.
References _Thread_Get_executing(), Thread_Start_information::Initial_stack, and Thread_Control::Start.
◆ rtems_stack_checker_report_usage()
void rtems_stack_checker_report_usage ( void  )
This method prints a stack usage report for the curently executing task.
Note
It uses printk to print the report.
References printk_plugin(), and rtems_stack_checker_report_usage_with_plugin().
◆ rtems_stack_checker_report_usage_with_plugin()
void rtems_stack_checker_report_usage_with_plugin ( void *  context,
Parameters
[in]contextis the context to pass to the print handler
[in]printis the print handler
Note
It uses the caller's routine to print the report.
Referenced by rtems_stack_checker_report_usage().
◆ rtems_stack_checker_switch_extension()
void rtems_stack_checker_switch_extension ( Thread_Control *  running,
Thread_Control *  heir
This method is the task context switch extension for the stack checker.
Parameters
[in]runningpoints to the currently executing task which is being context switched out
[in]runningpoints to the heir task which we are switching to
Note
This is called from the internal method _Thread_Dispatch.
References Thread_Start_information::Initial_stack, and Thread_Control::Start.
