Convert String to Pointer (with validation)
More...
| rtems_status_code | rtems_string_to_pointer (const char *s, void **n, char **endptr) |
| | Convert String to Pointer (with validation). More...
| rtems_status_code | rtems_string_to_unsigned_char (const char *s, unsigned char *n, char **endptr, int base) |
| | Convert String to Unsigned Character (with validation). More...
| rtems_status_code | rtems_string_to_int (const char *s, int *n, char **endptr, int base) |
| | Convert String to Int (with validation). More...
| rtems_status_code | rtems_string_to_unsigned_int (const char *s, unsigned int *n, char **endptr, int base) |
| | Convert String to Unsigned Int (with validation). More...
| rtems_status_code | rtems_string_to_long (const char *s, long *n, char **endptr, int base) |
| | Convert String to Long (with validation). More...
| rtems_status_code | rtems_string_to_unsigned_long (const char *s, unsigned long *n, char **endptr, int base) |
| | Convert String to Unsigned Long (with validation). More...
| rtems_status_code | rtems_string_to_long_long (const char *s, long long *n, char **endptr, int base) |
| | Convert String to Long Long (with validation). More...
| rtems_status_code | rtems_string_to_unsigned_long_long (const char *s, unsigned long long *n, char **endptr, int base) |
| | Convert String to Unsigned Long Long (with validation). More...
| rtems_status_code | rtems_string_to_float (const char *s, float *n, char **endptr) |
| | Convert String to Float (with validation). More...
| rtems_status_code | rtems_string_to_double (const char *s, double *n, char **endptr) |
| | Convert String to Double (with validation). More...
| rtems_status_code | rtems_string_to_long_double (const char *s, long double *n, char **endptr) |
| | Convert String to long double (with validation). More...
This file defines the interface to a set of string conversion helpers.
◆ rtems_string_to_double()
| rtems_status_code rtems_string_to_double |
const char * |
s, |
double * |
n, |
char ** |
endptr |
This method converts a string to a double with range validation.
- Parameters
| [in] | s | is the string to convert |
| [in] | n | points to the variable to place the converted output in |
| [in] | endptr | is used to keep track of the position in the string |
- Return values
| This | method returns RTEMS_SUCCESSFUL on successful conversion and *n is filled in. Otherwise, the status indicates the source of the error. |
◆ rtems_string_to_float()
| rtems_status_code rtems_string_to_float |
const char * |
s, |
float * |
n, |
char ** |
endptr |
This method converts a string to a float with range validation.
- Parameters
- Return values
◆ rtems_string_to_int()
| rtems_status_code rtems_string_to_int |
const char * |
s, |
int * |
n, |
char ** |
endptr, |
int |
base |
This method converts a string to an int with range validation.
- Parameters
| [in] | base | is the expected base of the number |
- Return values
◆ rtems_string_to_long()
| rtems_status_code rtems_string_to_long |
const char * |
s, |
long * |
n, |
char ** |
endptr, |
int |
base |
This method converts a string to a long with range validation.
- Parameters
- Return values
◆ rtems_string_to_long_double()
| rtems_status_code rtems_string_to_long_double |
const char * |
s, |
long double * |
n, |
char ** |
endptr |
This method converts a string to a long double with range validation.
- Parameters
- Return values
◆ rtems_string_to_long_long()
| rtems_status_code rtems_string_to_long_long |
const char * |
s, |
long long * |
n, |
char ** |
endptr, |
int |
base |
This method converts a string to a long long with range validation.
- Parameters
- Return values
◆ rtems_string_to_pointer()
| rtems_status_code rtems_string_to_pointer |
const char * |
s, |
void ** |
n, |
char ** |
endptr |
This method converts a string to a pointer (void *) with basic numeric validation.
- Parameters
- Return values
◆ rtems_string_to_unsigned_char()
| rtems_status_code rtems_string_to_unsigned_char |
const char * |
s, |
unsigned char * |
n, |
char ** |
endptr, |
int |
base |
This method converts a string to an unsigned character with range validation.
- Parameters
- Return values
◆ rtems_string_to_unsigned_int()
| rtems_status_code rtems_string_to_unsigned_int |
const char * |
s, |
unsigned int * |
n, |
char ** |
endptr, |
int |
base |
This method converts a string to an unsigned int with range validation.
- Parameters
- Return values
◆ rtems_string_to_unsigned_long()
| rtems_status_code rtems_string_to_unsigned_long |
const char * |
s, |
unsigned long * |
n, |
char ** |
endptr, |
int |
base |
This method converts a string to an unsigned long with range validation.
- Parameters
- Return values
◆ rtems_string_to_unsigned_long_long()
| rtems_status_code rtems_string_to_unsigned_long_long |
const char * |
s, |
unsigned long long * |
n, |
char ** |
endptr, |
int |
base |
- Parameters
- Return values
