Files | Macros | Functions | Variables
Timecounter Handler
Collaboration diagram for Timecounter Handler:
file  score/include/rtems/score/timecounter.h
 Timecounter API.
file  timecounterimpl.h
 Timecounter Implementation.
#define _Timecounter_Acquire(lock_context)   _ISR_lock_ISR_disable_and_acquire( &_Timecounter_Lock, lock_context )
 Lock to protect the timecounter mechanic. More...
void _Timecounter_Bintime (struct bintime *bt)
 Returns the wall clock time in the bintime format. More...
void _Timecounter_Nanotime (struct timespec *ts)
 Returns the wall clock time in the timespec format. More...
void _Timecounter_Microtime (struct timeval *tv)
 Returns the wall clock time in the timeval format. More...
void _Timecounter_Binuptime (struct bintime *bt)
 Returns the uptime in the bintime format. More...
void _Timecounter_Nanouptime (struct timespec *ts)
 Returns the uptime in the timespec format. More...
void _Timecounter_Microuptime (struct timeval *tv)
 Returns the uptime in the timeval format. More...
void _Timecounter_Getbintime (struct bintime *bt)
void _Timecounter_Getnanotime (struct timespec *ts)
void _Timecounter_Getmicrotime (struct timeval *tv)
void _Timecounter_Getbinuptime (struct bintime *bt)
void _Timecounter_Getnanouptime (struct timespec *ts)
void _Timecounter_Getmicrouptime (struct timeval *tv)
void _Timecounter_Install (struct timecounter *tc)
 Installs the timecounter. More...
void _Timecounter_Tick (void)
 Performs a timecounter tick.
void _Timecounter_Tick_simple (uint32_t delta, uint32_t offset, ISR_lock_Context *lock_context)
 Performs a simple timecounter tick. More...
void _Timecounter_Initialize (void)
void _Timecounter_Set_clock (const struct timespec *ts)
volatile time_t _Timecounter_Time_second
 The wall clock time in seconds.
volatile time_t _Timecounter_Time_uptime
 The uptime in seconds. More...
struct timecounter * _Timecounter
 The current timecounter.
◆ _Timecounter_Acquire
#define _Timecounter_Acquire (   lock_context)    _ISR_lock_ISR_disable_and_acquire( &_Timecounter_Lock, lock_context )
Acquires the timecounter lock.
Parameters
[in]lock_contextThe lock context.
See _Timecounter_Tick_simple().
Referenced by rtems_clock_tick(), rtems_timecounter_simple_downcounter_tick(), and rtems_timecounter_simple_upcounter_tick().
◆ _Timecounter_Bintime()
void _Timecounter_Bintime ( struct bintime *  bt)
Parameters
[out]btReturns the wall clock time.
◆ _Timecounter_Binuptime()
void _Timecounter_Binuptime ( struct bintime *  bt)
Parameters
[out]btReturns the uptime.
◆ _Timecounter_Getbintime()
void _Timecounter_Getbintime ( struct bintime *  bt)
This function obtains the time with a lower overhead and lower accuracy compared to the _Timecounter_Bintime() variant.
Parameters
[out]tsReturns the wall clock time.
◆ _Timecounter_Getbinuptime()
void _Timecounter_Getbinuptime ( struct bintime *  bt)
This function obtains the time with a lower overhead and lower accuracy compared to the _Timecounter_Binuptime() variant.
Parameters
[out]tsReturns the uptime.
◆ _Timecounter_Getmicrotime()
void _Timecounter_Getmicrotime ( struct timeval *  tv)
This function obtains the time with a lower overhead and lower accuracy compared to the _Timecounter_Microtime() variant.
Parameters
[out]tvReturns the wall clock time.
See also
_Timecounter_Getbintime().
Referenced by rtems_bsd_getmicrotime().
◆ _Timecounter_Getmicrouptime()
void _Timecounter_Getmicrouptime ( struct timeval *  tv)
This function obtains the time with a lower overhead and lower accuracy compared to the _Timecounter_Microuptime() variant.
Parameters
[out]tvReturns the uptime.
Referenced by rtems_bsd_getmicrouptime().
◆ _Timecounter_Getnanotime()
void _Timecounter_Getnanotime ( struct timespec *  ts)
This function obtains the time with a lower overhead and lower accuracy compared to the _Timecounter_Nanotime() variant.
Parameters
See also
Referenced by rtems_bsd_getnanotime().
◆ _Timecounter_Getnanouptime()
void _Timecounter_Getnanouptime ( struct timespec *  ts)
This function obtains the time with a lower overhead and lower accuracy compared to the _Timecounter_Nanouptime() variant.
Parameters
Referenced by rtems_bsd_getnanouptime().
◆ _Timecounter_Install()
void _Timecounter_Install ( struct timecounter *  tc)
The timecounter structure must contain valid values in the fields tc_get_timecount, tc_counter_mask, tc_frequency and tc_quality. All other fields must be zero initialized.
Parameters
[in]tcThe timecounter.
Referenced by rtems_timecounter_install().
◆ _Timecounter_Microtime()
void _Timecounter_Microtime ( struct timeval *  tv)
Parameters
Referenced by _TOD_Get_timeval(), and rtems_bsd_microtime().
◆ _Timecounter_Microuptime()
void _Timecounter_Microuptime ( struct timeval *  tv)
Parameters
Referenced by rtems_bsd_microuptime().
◆ _Timecounter_Nanotime()
void _Timecounter_Nanotime ( struct timespec *  ts)
Parameters
Referenced by rtems_bsd_nanotime().
◆ _Timecounter_Nanouptime()
void _Timecounter_Nanouptime ( struct timespec *  ts)
Parameters
Referenced by rtems_bsd_nanouptime().
◆ _Timecounter_Tick_simple()
void _Timecounter_Tick_simple ( uint32_t  delta,
uint32_t  offset,
ISR_lock_Context *  lock_context
This is a special purpose tick function for simple timecounter to support legacy clock drivers.
Parameters
[in]deltaThe time in timecounter ticks elapsed since the last call to _Timecounter_Tick_simple().
[in]offsetThe current value of the timecounter.
[in]lock_contextThe lock context of the corresponding _Timecounter_Acquire().
Variable Documentation
◆ _Timecounter_Time_uptime
For compatibility with the FreeBSD network stack the initial value is one second.
Referenced by rtems_clock_get_uptime_seconds().
