Files | Macros | Functions | Variables
Thread Handler Multiprocessing Support
This handler encapsulates functionality which is related to managing threads in a multiprocessor system configuration. More...
Collaboration diagram for Thread Handler Multiprocessing Support:
file  threadmp.c
 Distributed MP Support.
#define _Thread_MP_Is_receive(_the_thread)   ((_the_thread) == _MPCI_Receive_server_tcb)
 This function returns true if the thread in question is the multiprocessing receive thread. More...
void _Thread_MP_Handler_initialization (uint32_t maximum_proxies)
 Initialize MP thread handler. More...
Thread_Control * _Thread_MP_Allocate_proxy (States_Control the_state)
 Allocate a MP proxy control block from the inactive chain of free proxy control blocks. More...
Thread_Control * _Thread_MP_Find_proxy (Objects_Id the_id)
 Removes the MP proxy control block for the specified id from the active chain of proxy control blocks. More...
RTEMS_INLINE_ROUTINE void _Thread_MP_Free_proxy (Thread_Control *the_thread)
 This routine frees a proxy control block to the inactive chain of free proxy control blocks.
SCORE_EXTERN Chain_Control _Thread_MP_Active_proxies
 Manage the active set MP proxies. More...
SCORE_EXTERN Chain_Control _Thread_MP_Inactive_proxies
 Manage the inactive set of MP proxies. More...
This handler must manage proxies which represent remote threads blocking on local operations.
◆ _Thread_MP_Is_receive
#define _Thread_MP_Is_receive (   _the_thread)    ((_the_thread) == _MPCI_Receive_server_tcb)
Note
This is a macro to avoid needing a prototype for _MPCI_Receive_server_tcb until it is used.
◆ _Thread_MP_Allocate_proxy()
Thread_Control* _Thread_MP_Allocate_proxy ( States_Control  the_state)
This allocates a proxy control block from the inactive chain of free proxy control blocks.
Note
This function returns a thread control pointer because proxies are substitutes for remote threads.
References _Chain_Get(), _Thread_Is_null(), and _Thread_MP_Inactive_proxies.
◆ _Thread_MP_Find_proxy()
Thread_Control* _Thread_MP_Find_proxy ( Objects_Id  the_id)
This function removes the proxy control block for the specified id from the active chain of proxy control blocks.
References _Addresses_Subtract_offset(), _Chain_First(), _Chain_Is_tail(), _ISR_Disable, and _Thread_MP_Active_proxies.
◆ _Thread_MP_Handler_initialization()
void _Thread_MP_Handler_initialization ( uint32_t  maximum_proxies)
This routine initializes the multiprocessing portion of the Thread Handler.
References _Chain_Initialize(), _Chain_Initialize_empty(), _Thread_MP_Active_proxies, _Thread_MP_Inactive_proxies, and _Workspace_Allocate_or_fatal_error().
Variable Documentation
◆ _Thread_MP_Active_proxies
The following chain is used to manage the active set proxies.
Referenced by _Thread_MP_Find_proxy(), and _Thread_MP_Handler_initialization().
◆ _Thread_MP_Inactive_proxies
The following chain is used to manage the inactive set of proxies.
Referenced by _Thread_MP_Allocate_proxy(), and _Thread_MP_Handler_initialization().
