Files | Data Structures | Macros | Enumerations | Functions
Spinlock Handler
This handler encapsulates functionality which provides the foundation Spinlock services used in all of the APIs supported by RTEMS. More...
Collaboration diagram for Spinlock Handler:
file  corespinlock.c
 Initialize a Spinlock.
file  corespinlockrelease.c
 Release a Spinlock.
struct  CORE_spinlock_Attributes
 The following defines the control block used to manage the attributes of each spinlock. More...
struct  CORE_spinlock_Control
 The following defines the control block used to manage each spinlock. More...
#define CORE_SPINLOCK_STATUS_LAST   CORE_SPINLOCK_UNAVAILABLE
 This is a shorthand for the last status code. More...
#define CORE_SPINLOCK_UNLOCKED   0
 This indicates the lock is available. More...
#define CORE_SPINLOCK_LOCKED   1
 This indicates the lock is unavailable. More...
enum  CORE_spinlock_Status {
  CORE_SPINLOCK_SUCCESSFUL, CORE_SPINLOCK_HOLDER_RELOCKING, CORE_SPINLOCK_NOT_HOLDER, CORE_SPINLOCK_TIMEOUT,
  CORE_SPINLOCK_IS_BUSY, CORE_SPINLOCK_UNAVAILABLE
 Core Spinlock handler return statuses. More...
void _CORE_spinlock_Initialize (CORE_spinlock_Control *the_spinlock, CORE_spinlock_Attributes *the_spinlock_attributes)
 Initialize the spinlock. More...
CORE_spinlock_Status _CORE_spinlock_Wait (CORE_spinlock_Control *the_spinlock, bool wait, Watchdog_Interval timeout)
 Wait for spinlock. More...
CORE_spinlock_Status _CORE_spinlock_Release (CORE_spinlock_Control *the_spinlock)
 Manually release the spinlock. More...
RTEMS_INLINE_ROUTINE void _CORE_spinlock_Initialize_attributes (CORE_spinlock_Attributes *the_attributes)
 This method is used to initialize core spinlock attributes. More...
RTEMS_INLINE_ROUTINE bool _CORE_spinlock_Is_busy (CORE_spinlock_Control *the_spinlock)
 This method is used to determine if the spinlock is available or not. More...
◆ CORE_SPINLOCK_LOCKED
Referenced by _CORE_spinlock_Release().
◆ CORE_SPINLOCK_STATUS_LAST
Referenced by _POSIX_Spinlock_Translate_core_spinlock_return_code().
◆ CORE_SPINLOCK_UNLOCKED
◆ CORE_spinlock_Status
This status indicates that the operation completed successfully.
This status indicates that the current thread already holds the spinlock.
An attempt to relock it will result in deadlock.
This status indicates that the current thread is attempting to unlock a spinlock that is held by another thread.
This status indicates that a thread reached the limit of time it was willing to wait on the spin lock.
This status indicates that a thread is currently waiting for this spin lock.
This status indicates that the spinlock is currently locked and thus unavailable.
◆ _CORE_spinlock_Initialize()
void _CORE_spinlock_Initialize ( CORE_spinlock_Control *  the_spinlock,
CORE_spinlock_Attributes *  the_spinlock_attributes
This routine initializes the spinlock based on the parameters passed.
Parameters
[in]the_spinlockis the spinlock control block to initialize
[in]the_spinlock_attributesdefine the behavior of this instance
References CORE_spinlock_Control::Attributes, CORE_spinlock_Control::holder, CORE_spinlock_Control::lock, and CORE_spinlock_Control::users.
◆ _CORE_spinlock_Initialize_attributes()
RTEMS_INLINE_ROUTINE void _CORE_spinlock_Initialize_attributes ( CORE_spinlock_Attributes *  the_attributes)
Parameters
[in]the_attributespointer to the attributes to initialize.
References CORE_spinlock_Attributes::XXX.
◆ _CORE_spinlock_Is_busy()
RTEMS_INLINE_ROUTINE bool _CORE_spinlock_Is_busy ( CORE_spinlock_Control *  the_spinlock)
Parameters
[in]the_spinlockwill be checked
Returns
This method will return true if the spinlock is busy and false otherwise.
References CORE_spinlock_Control::users.
◆ _CORE_spinlock_Release()
CORE_spinlock_Status _CORE_spinlock_Release ( CORE_spinlock_Control *  the_spinlock)
This routine manually releases the spinlock. All of the threads waiting for the spinlock will be readied.
Parameters
[in]the_spinlockis the spinlock to surrender
References _ISR_Disable, CORE_SPINLOCK_LOCKED, CORE_spinlock_Control::holder, and CORE_spinlock_Control::lock.
◆ _CORE_spinlock_Wait()
CORE_spinlock_Status _CORE_spinlock_Wait ( CORE_spinlock_Control *  the_spinlock,
bool  wait,
Wait for spinlock.
This routine wait for the spinlock to be released. If the spinlock is set to automatic and this is the appropriate thread, then it returns immediately. Otherwise, the calling thread is blocked until the spinlock is released.
Parameters
[in]the_spinlockis the spinlock to wait for
[in]waitis true if willing to wait
[in]timeoutis the maximum number of ticks to spin (0 is forever)
Return values
Astatus is returned which indicates the success or failure of this operation.
