Files | Functions | Variables
Object Handler Multiprocessing Support
This handler encapsulates functionality which is used to manage objects which have been declared to be globally visible. More...
Collaboration diagram for Object Handler Multiprocessing Support:
file  objectmp.c
 Objects MP Support.
void _Objects_MP_Handler_initialization (void)
 Intializes the inactive global object chain based on the maximum number of global objects configured. More...
void _Objects_MP_Handler_early_initialization (void)
 Intializes the global object node number used in the ID field of all objects. More...
void _Objects_MP_Open (Objects_Information *information, Objects_MP_Control *the_global_object, uint32_t the_name, Objects_Id the_id)
 Place the specified global object in the specified information table. More...
bool _Objects_MP_Allocate_and_open (Objects_Information *information, uint32_t the_name, Objects_Id the_id, bool is_fatal_error)
 Allocates a global object control block and places it in the specified information table. More...
void _Objects_MP_Close (Objects_Information *information, Objects_Id the_id)
 Removes a global object from the specified information table. More...
Objects_Name_or_id_lookup_errors _Objects_MP_Global_name_search (Objects_Information *information, Objects_Name the_name, uint32_t nodes_to_search, Objects_Id *the_id)
 Look for the object with the_name in the global object tables indicated by information. More...
void _Objects_MP_Is_remote (Objects_Information *information, Objects_Id the_id, Objects_Locations *location, Objects_Control **the_object)
 Searches the Global Object Table managed by information for the object indicated by ID. More...
RTEMS_INLINE_ROUTINE Objects_MP_Control * _Objects_MP_Allocate_global_object (void)
 This function allocates a Global Object control block.
RTEMS_INLINE_ROUTINE void _Objects_MP_Free_global_object (Objects_MP_Control *the_object)
 This routine deallocates a Global Object control block.
RTEMS_INLINE_ROUTINE bool _Objects_MP_Is_null_global_object (Objects_MP_Control *the_object)
 This function returns whether the global object is NULL or not.
SCORE_EXTERN uint32_t _Objects_MP_Maximum_global_objects
 This is the maximum number of global objects configured.
SCORE_EXTERN Chain_Control _Objects_MP_Inactive_global_objects
 The following chain header is used to manage the set of inactive global object control blocks.
This handler knows objects from all of the nodes in the system.
◆ _Objects_MP_Allocate_and_open()
bool _Objects_MP_Allocate_and_open ( Objects_Information *  information,
uint32_t  the_name,
Objects_Id  the_id,
bool  is_fatal_error
This routine allocates a global object control block and places it in the specified information table. If the allocation fails, then is_fatal_error determines the error processing actions taken.
Parameters
[in]informationpoints to the object information table for this object class.
[in]the_nameis the name of the object being opened.
[in]the_idis the Id of the object being opened.
[in]is_fatal_erroris true if not being able to allocate the object is considered a fatal error.
Todo:
This method only works for object types with 4 byte object names. It does not support variable length object names.
References _Objects_MP_Allocate_global_object(), _Objects_MP_Is_null_global_object(), _Terminate(), and INTERNAL_ERROR_CORE.
Referenced by rtems_semaphore_create().
◆ _Objects_MP_Close()
void _Objects_MP_Close ( Objects_Information *  information,
Objects_Id  the_id
This routine removes a global object from the specified information table and deallocates the global object control block.
References _Chain_Extract(), _Chain_First(), _Chain_Is_tail(), _Chain_Next(), _Objects_Are_ids_equal(), _Objects_Get_node(), _Objects_MP_Free_global_object(), _Terminate(), and INTERNAL_ERROR_CORE.
◆ _Objects_MP_Global_name_search()
Objects_Name_or_id_lookup_errors _Objects_MP_Global_name_search ( Objects_Information *  information,
Objects_Id *  the_id
This routine looks for the object with the_name in the global object tables indicated by information. It returns the ID of the object with that name if one is found.
Parameters
[in]the_nameis the name of the object being searched for.
[in]nodes_to_searchindicates the set of nodes to search.
[in]the_idwill contain the Id of the object if found.
Return values
Thismethod returns one of the Objects_Name_or_id_lookup_errors. If successful, the_id will contain the Id of the object.
References _Objects_Maximum_nodes, and Objects_Name::name_u32.
◆ _Objects_MP_Handler_early_initialization()
void _Objects_MP_Handler_early_initialization ( void  )
This routine intializes the global object node number used in the ID field of all objects.
References _Terminate(), and INTERNAL_ERROR_CORE.
◆ _Objects_MP_Handler_initialization()
void _Objects_MP_Handler_initialization ( void  )
This routine intializes the inactive global object chain based on the maximum number of global objects configured.
References _Chain_Initialize(), _Chain_Initialize_empty(), _Objects_MP_Inactive_global_objects, _Objects_MP_Maximum_global_objects, and _Workspace_Allocate_or_fatal_error().
◆ _Objects_MP_Is_remote()
void _Objects_MP_Is_remote ( Objects_Information *  information,
Objects_Id  the_id,
Objects_Locations *  location,
Objects_Control **  the_object
This function searches the Global Object Table managed by information for the object indicated by ID. If the object is found, then location is set to objects_remote, otherwise location is set to objects_error. In both cases, the_object is undefined.
Parameters
[in]locationwill contain the location of the object.
[in]the_objectwill contain a pointer to the object.
Return values
Thismethod fills in location to indicate successful location of the object or error. On success, the_object will be filled in.
References _Objects_Get_node(), _Objects_Is_local_node(), and _Objects_Maximum_nodes.
◆ _Objects_MP_Open()
void _Objects_MP_Open ( Objects_Information *  information,
Objects_MP_Control *  the_global_object,
uint32_t  the_name,
Objects_Id  the_id
This routine place the specified global object in the specified information table.
Parameters
[in]the_global_objectpoints to the object being opened.
Todo:
References _Chain_Prepend(), and _Objects_Get_node().
