RTEMS Allocator Mutex
Protection for all memory allocations and deallocations in RTEMS. More...
Collaboration diagram for RTEMS Allocator Mutex:
SCORE_EXTERN API_Mutex_Control * _RTEMS_Allocator_Mutex
 Memory allocation mutex. More...
SCORE_EXTERN API_Mutex_Control * _Once_Mutex
When the APIs all use this for allocation and deallocation protection, then this possibly should be renamed and moved to a higher level in the hierarchy.
Variable Documentation
◆ _RTEMS_Allocator_Mutex
SCORE_EXTERN API_Mutex_Control* _RTEMS_Allocator_Mutex
This points to the API Mutex instance used to ensure that only one thread at a time is allocating or freeing memory.
