Test Support
Test support functions. More...
struct  rtems_test_parallel_context
 Internal context for parallel job execution. More...
struct  rtems_test_parallel_job
 Basic parallel job description. More...
#define RTEMS_TEST_INITIAL_EXTENSION   { NULL, NULL, NULL, NULL, NULL, NULL, NULL, rtems_test_fatal_extension }
 Initial extension for tests.
typedef void(* rtems_test_parallel_worker_setup) (rtems_test_parallel_context *ctx, size_t worker_index, rtems_id worker_id)
 Worker task setup handler. More...
void rtems_test_fatal_extension (rtems_fatal_source source, bool is_internal, rtems_fatal_code code)
 Fatal extension for tests.
int rtems_test_begin_with_plugin (rtems_printk_plugin_t printf_func, void *printf_arg)
 Prints a begin of test message. More...
int rtems_test_end_with_plugin (rtems_printk_plugin_t printf_func, void *printf_arg)
 Prints an end of test message. More...
void rtems_test_parallel (rtems_test_parallel_context *ctx, rtems_test_parallel_worker_setup worker_setup, const rtems_test_parallel_job *jobs, size_t job_count)
 Runs a bunch of jobs in parallel on all processors of the system. More...
const char rtems_test_name []
 Each test must define a test name string.
Typedef Documentation
◆ rtems_test_parallel_worker_setup
Called during rtems_test_parallel() to optionally setup a worker task before it is started.
Parameters
[in]ctxThe parallel context.
[in]worker_indexThe worker index.
[in]worker_idThe worker task identifier.
◆ rtems_test_begin_with_plugin()
int rtems_test_begin_with_plugin ( rtems_printk_plugin_t  printf_func,
void *  printf_arg
Parameters
[in]printf_funcThe formatted output function.
[in,out]printf_argThe formatted output function argument.
Returns
As specified by printf().
References rtems_test_end_with_plugin(), and rtems_test_name.
◆ rtems_test_end_with_plugin()
int rtems_test_end_with_plugin ( rtems_printk_plugin_t  printf_func,
void *  printf_arg
Parameters
Returns
References rtems_test_name.
Referenced by rtems_test_begin_with_plugin().
◆ rtems_test_parallel()
void rtems_test_parallel ( rtems_test_parallel_context *  ctx,
const rtems_test_parallel_job *  jobs,
size_t  job_count
The worker tasks inherit the priority of the executing task.
There are SMP barriers before and after the job body.
Parameters
[in]worker_setupOptional handler to setup a worker task before it is started.
[in]jobsThe table of jobs.
[in]job_countThe count of jobs in the job table.
