Macros | Typedefs | Functions
cbs.h File Reference
Constants and Structures Associated with the CBS library in RTEMS. More...
#include <rtems/score/schedulercbs.h>
Include dependency graph for cbs.h:
#define RTEMS_CBS_OK   SCHEDULER_CBS_OK
#define RTEMS_CBS_ERROR_GENERIC   SCHEDULER_CBS_ERROR_GENERIC
#define RTEMS_CBS_ERROR_NO_MEMORY   SCHEDULER_CBS_ERROR_NO_MEMORY
#define RTEMS_CBS_ERROR_INVALID_PARAMETER   SCHEDULER_CBS_ERROR_INVALID_PARAM
#define RTEMS_CBS_ERROR_UNAUTHORIZED   SCHEDULER_CBS_ERROR_UNAUTHORIZED
#define RTEMS_CBS_ERROR_UNIMPLEMENTED   SCHEDULER_CBS_ERROR_UNIMPLEMENTED
#define RTEMS_CBS_ERROR_MISSING_COMPONENT   SCHEDULER_CBS_ERROR_MISSING_COMPONENT
#define RTEMS_CBS_ERROR_INCONSISTENT_STATE   SCHEDULER_CBS_ERROR_INCONSISTENT_STATE
#define RTEMS_CBS_ERROR_SYSTEM_OVERLOAD   SCHEDULER_CBS_ERROR_SYSTEM_OVERLOAD
#define RTEMS_CBS_ERROR_INTERNAL_ERROR   SCHEDULER_CBS_ERROR_INTERNAL_ERROR
#define RTEMS_CBS_ERROR_NOT_FOUND   SCHEDULER_CBS_ERROR_NOT_FOUND
#define RTEMS_CBS_ERROR_FULL   SCHEDULER_CBS_ERROR_FULL
#define RTEMS_CBS_ERROR_EMPTY   SCHEDULER_CBS_ERROR_EMPTY
#define RTEMS_CBS_ERROR_NOSERVER   SCHEDULER_CBS_ERROR_NOSERVER
typedef Scheduler_CBS_Budget_overrun rtems_cbs_budget_overrun
 Callback function invoked when a budget overrun of a task occurs. More...
typedef Scheduler_CBS_Server_id rtems_cbs_server_id
 Server id. More...
typedef Scheduler_CBS_Parameters rtems_cbs_parameters
 Server parameters. More...
RTEMS_INLINE_ROUTINE int rtems_cbs_initialize (void)
 Initialize the CBS library. More...
RTEMS_INLINE_ROUTINE int rtems_cbs_cleanup (void)
 Cleanup resources associated to the CBS Library. More...
RTEMS_INLINE_ROUTINE int rtems_cbs_create_server (rtems_cbs_parameters *params, rtems_cbs_budget_overrun budget_overrun_callback, rtems_cbs_server_id *server_id)
 Create a new server with specified parameters. More...
RTEMS_INLINE_ROUTINE int rtems_cbs_attach_thread (rtems_cbs_server_id server_id, rtems_id task_id)
 Attach a task to an already existing server. More...
RTEMS_INLINE_ROUTINE int rtems_cbs_detach_thread (rtems_cbs_server_id server_id, rtems_id task_id)
 Detach from the CBS server. More...
RTEMS_INLINE_ROUTINE int rtems_cbs_destroy_server (rtems_cbs_server_id server_id)
 Detach all tasks from a server and destroy it. More...
RTEMS_INLINE_ROUTINE int rtems_cbs_get_server_id (rtems_id task_id, rtems_cbs_server_id *server_id)
 Get CBS server id. More...
RTEMS_INLINE_ROUTINE int rtems_cbs_get_parameters (rtems_cbs_server_id server_id, rtems_cbs_parameters *params)
 Get CBS parameters. More...
RTEMS_INLINE_ROUTINE int rtems_cbs_set_parameters (rtems_cbs_server_id server_id, rtems_cbs_parameters *params)
 Set CBS parameters. More...
RTEMS_INLINE_ROUTINE int rtems_cbs_get_execution_time (rtems_cbs_server_id server_id, time_t *exec_time, time_t *abs_time)
 Get the CBS get execution time. More...
RTEMS_INLINE_ROUTINE int rtems_cbs_get_remaining_budget (rtems_cbs_server_id server_id, time_t *remaining_budget)
 Get the remaining CBS budget. More...
RTEMS_INLINE_ROUTINE int rtems_cbs_get_approved_budget (rtems_cbs_server_id server_id, time_t *appr_budget)
 Get the approved CBS budget. More...
This include file contains all the constants and structures associated with the CBS library in RTEMS.
Typedef Documentation
◆ rtems_cbs_budget_overrun
◆ rtems_cbs_parameters
Server parameters.
◆ rtems_cbs_server_id
Server id.
◆ rtems_cbs_attach_thread()
RTEMS_INLINE_ROUTINE int rtems_cbs_attach_thread ( rtems_cbs_server_id  server_id,
rtems_id  task_id
Returns
status code.
◆ rtems_cbs_cleanup()
RTEMS_INLINE_ROUTINE int rtems_cbs_cleanup ( void  )
Returns
status code.
References _Scheduler_CBS_Cleanup().
◆ rtems_cbs_create_server()
RTEMS_INLINE_ROUTINE int rtems_cbs_create_server ( rtems_cbs_parameters *  params,
rtems_cbs_server_id *  server_id
Returns
status code.
◆ rtems_cbs_destroy_server()
RTEMS_INLINE_ROUTINE int rtems_cbs_destroy_server ( rtems_cbs_server_id  server_id)
Returns
status code.
◆ rtems_cbs_detach_thread()
RTEMS_INLINE_ROUTINE int rtems_cbs_detach_thread ( rtems_cbs_server_id  server_id,
rtems_id  task_id
Detach from the CBS Server.
Returns
status code.
◆ rtems_cbs_get_approved_budget()
RTEMS_INLINE_ROUTINE int rtems_cbs_get_approved_budget ( rtems_cbs_server_id  server_id,
time_t *  appr_budget
Retrieve the budget that has been approved for the subsequent server instances.
Returns
status code.
◆ rtems_cbs_get_execution_time()
RTEMS_INLINE_ROUTINE int rtems_cbs_get_execution_time ( rtems_cbs_server_id  server_id,
time_t *  exec_time,
time_t *  abs_time
Retrieve time info relative to the current server.
Returns
status code.
◆ rtems_cbs_get_parameters()
RTEMS_INLINE_ROUTINE int rtems_cbs_get_parameters ( rtems_cbs_server_id  server_id,
Get CBS parameters.
Retrieve CBS scheduling parameters.
Returns
status code.
◆ rtems_cbs_get_remaining_budget()
RTEMS_INLINE_ROUTINE int rtems_cbs_get_remaining_budget ( rtems_cbs_server_id  server_id,
time_t *  remaining_budget
Retrieve remaining budget for the current server instance.
Returns
status code.
◆ rtems_cbs_get_server_id()
RTEMS_INLINE_ROUTINE int rtems_cbs_get_server_id ( rtems_id  task_id,
Get CBS server id.
Get a thread server id, or RTEMS_CBS_E_NOT_FOUND if it is not attached to any server.
Returns
status code.
◆ rtems_cbs_initialize()
RTEMS_INLINE_ROUTINE int rtems_cbs_initialize ( void  )
Initializes the CBS library.
Returns
status code.
References _Scheduler_CBS_Initialize().
◆ rtems_cbs_set_parameters()
RTEMS_INLINE_ROUTINE int rtems_cbs_set_parameters ( rtems_cbs_server_id  server_id,
Set CBS parameters.
Change CBS scheduling parameters.
Returns
status code.
