#define | XQSPIPSU_FLASH_CONFIG_H_ /* by using protection macros */ |
#define | WRITE_STATUS_CMD 0x01 |
#define | WRITE_CMD 0x02 |
#define | READ_CMD 0x03 |
#define | WRITE_DISABLE_CMD 0x04 |
#define | READ_STATUS_CMD 0x05 |
#define | WRITE_ENABLE_CMD 0x06 |
#define | VOLATILE_WRITE_ENABLE_CMD 0x50 |
#define | QUAD_MODE_ENABLE_BIT 0x06 |
#define | FAST_READ_CMD 0x0B |
#define | DUAL_READ_CMD 0x3B |
#define | QUAD_READ_CMD 0x6B |
#define | BULK_ERASE_CMD 0xC7 |
#define | SEC_ERASE_CMD 0xD8 |
#define | READ_ID 0x9F |
#define | READ_SFDP 0x5A |
#define | READ_CONFIG_CMD 0x35 |
#define | WRITE_CONFIG_CMD 0x01 |
#define | ENTER_4B_ADDR_MODE 0xB7 |
#define | EXIT_4B_ADDR_MODE 0xE9 |
#define | EXIT_4B_ADDR_MODE_ISSI 0x29 |
#define | READ_CMD_4B 0x13 |
#define | FAST_READ_CMD_4B 0x0C |
#define | DUAL_READ_CMD_4B 0x3C |
#define | QUAD_READ_CMD_4B 0x6C |
#define | WRITE_CMD_4B 0x12 |
#define | SEC_ERASE_CMD_4B 0xDC |
#define | BANK_REG_RD 0x16 |
#define | BANK_REG_WR 0x17 |
#define | READ_ECCSR 0x18 |
#define | EXTADD_REG_RD 0xC8 |
#define | EXTADD_REG_WR 0xC5 |
#define | DIE_ERASE_CMD 0xC4 |
#define | READ_FLAG_STATUS_CMD 0x70 |
#define | WRITE_STATUS_REG_2_CMD 0x31 |
#define | READ_STATUS_REG_2_CMD 0x35 |
#define | WB_QUAD_MODE_ENABLE_BIT 0x01 |
#define | COMMAND_OFFSET 0 /* Flash instruction */ |
#define | ADDRESS_1_OFFSET 1 /* MSB byte of address to read or write */ |
#define | ADDRESS_2_OFFSET 2 /* Middle byte of address to read or write */ |
#define | ADDRESS_3_OFFSET 3 /* LSB byte of address to read or write */ |
| #define | ADDRESS_4_OFFSET |
#define | DATA_OFFSET 5 /* Start of Data for Read/Write */ |
| #define | DUMMY_OFFSET |
| #define | DUMMY_SIZE |
| #define | DUMMY_CLOCKS |
#define | RD_ID_SIZE 4 /* Read ID command + 3 bytes ID response */ |
#define | BULK_ERASE_SIZE 1 /* Bulk Erase command size */ |
#define | SEC_ERASE_SIZE 4 /* Sector Erase command + Sector address */ |
| #define | BANK_SEL_SIZE |
| #define | RD_CFG_SIZE |
| #define | WR_CFG_SIZE |
#define | DIE_ERASE_SIZE 4 /* Die Erase command + Die address */ |
#define | OVERHEAD_SIZE 4 |
#define | FLASH1BASE 0x0000000 |
#define | SIXTEENMB 0x1000000 |
#define | FLASH_QUAD_EN_MASK 0x02 |
#define | FLASH_SRWD_MASK 0x80 |
#define | BANKMASK 0xF000000 |
#define | BUSWIDTH_SINGLE 0 |
#define | BUSWIDTH_DOUBLE 1 |
#define | MICRON_ID_BYTE0 0x20 |
#define | SPANSION_ID_BYTE0 0x01 |
#define | WINBOND_ID_BYTE0 0xEF |
#define | MACRONIX_ID_BYTE0 0xC2 |
#define | ISSI_ID_BYTE0 0x9D |
This file contains flash configuration table and flash related defines. This file should be included in the example files and compiled along with the examples (*.c).
- Note
None.
MODIFICATION HISTORY:
Ver Who Date Changes
1.12 akm 07/07/20 First release
1.12 akm 07/07/20 Add support for Macronix flash(MX66U2G45G, MX66L2G45G)
and ISSI flash(IS25LP01G, IS25WP01G) parts.
1.13 akm 12/10/20 Set Read command as per the qspi bus width.
1.14 akm 07/16/21 Enable Quad Mode for Winbond flashes.
1.15 akm 11/19/21 Fix read/write failures on Spansion flash parts.
