RTEMS
6.1
bsps
include
dev
nand
xnandpsu_hw.h File Reference
#include "xil_io.h"
#define
XNANDPSU_HW_H
/* by using protection macros */
#define
XNANDPSU_PKT_OFFSET
0x00U
#define
XNANDPSU_MEM_ADDR1_OFFSET
0x04U
#define
XNANDPSU_MEM_ADDR2_OFFSET
0x08U
#define
XNANDPSU_CMD_OFFSET
0x0CU
#define
XNANDPSU_PROG_OFFSET
0x10U
#define
XNANDPSU_INTR_STS_EN_OFFSET
0x14U
#define
XNANDPSU_INTR_SIG_EN_OFFSET
0x18U
#define
XNANDPSU_INTR_STS_OFFSET
0x1CU
#define
XNANDPSU_READY_BUSY_OFFSET
0x20U
#define
XNANDPSU_FLASH_STS_OFFSET
0x28U
#define
XNANDPSU_TIMING_OFFSET
0x2CU
#define
XNANDPSU_BUF_DATA_PORT_OFFSET
0x30U
#define
XNANDPSU_ECC_OFFSET
0x34U
#define
XNANDPSU_ECC_ERR_CNT_OFFSET
0x38U
#define
XNANDPSU_ECC_SPR_CMD_OFFSET
0x3CU
#define
XNANDPSU_ECC_CNT_1BIT_OFFSET
0x40U
#define
XNANDPSU_ECC_CNT_2BIT_OFFSET
0x44U
#define
XNANDPSU_ECC_CNT_3BIT_OFFSET
0x48U
#define
XNANDPSU_ECC_CNT_4BIT_OFFSET
0x4CU
#define
XNANDPSU_CPU_REL_OFFSET
0x58U
#define
XNANDPSU_ECC_CNT_5BIT_OFFSET
0x5CU
#define
XNANDPSU_ECC_CNT_6BIT_OFFSET
0x60U
#define
XNANDPSU_ECC_CNT_7BIT_OFFSET
0x64U
#define
XNANDPSU_ECC_CNT_8BIT_OFFSET
0x68U
#define
XNANDPSU_DATA_INTF_OFFSET
0x6CU
#define
XNANDPSU_DMA_SYS_ADDR0_OFFSET
0x50U
#define
XNANDPSU_DMA_SYS_ADDR1_OFFSET
0x24U
#define
XNANDPSU_DMA_BUF_BND_OFFSET
0x54U
#define
XNANDPSU_SLV_DMA_CONF_OFFSET
0x80U
Packet Register bit definitions and masks
#define
XNANDPSU_PKT_PKT_SIZE_MASK
0x000007FFU
#define
XNANDPSU_PKT_PKT_CNT_MASK
0x00FFF000U
#define
XNANDPSU_PKT_PKT_CNT_SHIFT
12U
Memory Address Register 1 bit definitions and masks
#define
XNANDPSU_MEM_ADDR1_COL_ADDR_MASK
0x0000FFFFU
#define
XNANDPSU_MEM_ADDR1_PG_ADDR_MASK
0xFFFF0000U
#define
XNANDPSU_MEM_ADDR1_PG_ADDR_SHIFT
16U
Memory Address Register 2 bit definitions and masks
#define
XNANDPSU_MEM_ADDR2_MEM_ADDR_MASK
0x000000FFU
#define
XNANDPSU_MEM_ADDR2_BUS_WIDTH_MASK
0x01000000U
#define
XNANDPSU_MEM_ADDR2_NFC_BCH_MODE_MASK
0x0E000000U
#define
XNANDPSU_MEM_ADDR2_MODE_MASK
0x30000000U
#define
XNANDPSU_MEM_ADDR2_CHIP_SEL_MASK
0xC0000000U
#define
XNANDPSU_MEM_ADDR2_CHIP_SEL_SHIFT
30U
#define
XNANDPSU_MEM_ADDR2_BUS_WIDTH_SHIFT
24U
#define
XNANDPSU_MEM_ADDR2_NFC_BCH_MODE_SHIFT
25U
Command Register bit definitions and masks
#define
XNANDPSU_CMD_CMD1_MASK
0x000000FFU
#define
XNANDPSU_CMD_CMD2_MASK
0x0000FF00U
#define
XNANDPSU_CMD_PG_SIZE_MASK
0x03800000U
#define
XNANDPSU_CMD_DMA_EN_MASK
0x0C000000U
#define
XNANDPSU_CMD_ADDR_CYCLES_MASK
0x70000000U
#define
XNANDPSU_CMD_ECC_ON_MASK
0x80000000U
#define
XNANDPSU_CMD_CMD2_SHIFT
8U
#define
XNANDPSU_CMD_PG_SIZE_SHIFT
23U
#define
XNANDPSU_CMD_DMA_EN_SHIFT
26U
#define
XNANDPSU_CMD_ADDR_CYCLES_SHIFT
28U
#define
XNANDPSU_CMD_ECC_ON_SHIFT
31U
Program Register bit definitions and masks
#define
XNANDPSU_PROG_RD_MASK
0x00000001U
#define
XNANDPSU_PROG_MUL_DIE_MASK
0x00000002U
#define
XNANDPSU_PROG_BLK_ERASE_MASK
0x00000004U
#define
XNANDPSU_PROG_RD_STS_MASK
0x00000008U
#define
XNANDPSU_PROG_PG_PROG_MASK
0x00000010U
#define
XNANDPSU_PROG_MUL_DIE_RD_MASK
0x00000020U
#define
XNANDPSU_PROG_RD_ID_MASK
0x00000040U
#define
XNANDPSU_PROG_RD_PRM_PG_MASK
0x00000080U
#define
XNANDPSU_PROG_RST_MASK
0x00000100U
#define
XNANDPSU_PROG_GET_FEATURES_MASK
0x00000200U
#define
XNANDPSU_PROG_SET_FEATURES_MASK
0x00000400U
#define
XNANDPSU_PROG_RD_UNQ_ID_MASK
0x00000800U
#define
XNANDPSU_PROG_RD_STS_ENH_MASK
0x00001000U
#define
XNANDPSU_PROG_RD_INTRLVD_MASK
0x00002000U
#define
XNANDPSU_PROG_CHNG_RD_COL_ENH_MASK
0x00004000U
#define
XNANDPSU_PROG_COPY_BACK_INTRLVD_MASK
0x00008000U
#define
XNANDPSU_PROG_RD_CACHE_START_MASK
0x00010000U
#define
XNANDPSU_PROG_RD_CACHE_SEQ_MASK
0x00020000U
#define
XNANDPSU_PROG_RD_CACHE_RAND_MASK
0x00040000U
#define
XNANDPSU_PROG_RD_CACHE_END_MASK
0x00080000U
#define
XNANDPSU_PROG_SMALL_DATA_MOVE_MASK
0x00100000U
#define
XNANDPSU_PROG_CHNG_ROW_ADDR_MASK
0x00200000U
#define
XNANDPSU_PROG_CHNG_ROW_ADDR_END_MASK
0x00400000U
#define
XNANDPSU_PROG_RST_LUN_MASK
0x00800000U
#define
XNANDPSU_PROG_PGM_PG_CLR_MASK
0x01000000U
#define
XNANDPSU_PROG_VOL_SEL_MASK
0x02000000U
#define
XNANDPSU_PROG_ODT_CONF_MASK
0x04000000U
Interrupt Status Enable Register bit definitions and masks
#define
XNANDPSU_INTR_STS_EN_BUFF_WR_RDY_STS_EN_MASK
0x00000001U
#define
XNANDPSU_INTR_STS_EN_BUFF_RD_RDY_STS_EN_MASK
0x00000002U
#define
XNANDPSU_INTR_STS_EN_TRANS_COMP_STS_EN_MASK
0x00000004U
#define
XNANDPSU_INTR_STS_EN_MUL_BIT_ERR_STS_EN_MASK
0x00000008U
#define
XNANDPSU_INTR_STS_EN_ERR_INTR_STS_EN_MASK
0x00000010U
#define
XNANDPSU_INTR_STS_EN_DMA_INT_STS_EN_MASK
0x00000040U
#define
XNANDPSU_INTR_STS_EN_ERR_AHB_STS_EN_MASK
0x00000080U
Interrupt Signal Enable Register bit definitions and masks
#define
XNANDPSU_INTR_SIG_EN_BUFF_WR_RDY_STS_EN_MASK
0x00000001U
#define
XNANDPSU_INTR_SIG_EN_BUFF_RD_RDY_STS_EN_MASK
0x00000002U
#define
XNANDPSU_INTR_SIG_EN_TRANS_COMP_STS_EN_MASK
0x00000004U
#define
XNANDPSU_INTR_SIG_EN_MUL_BIT_ERR_STS_EN_MASK
0x00000008U
#define
XNANDPSU_INTR_SIG_EN_ERR_INTR_STS_EN_MASK
0x00000010U
#define
XNANDPSU_INTR_SIG_EN_DMA_INT_STS_EN_MASK
0x00000040U
#define
XNANDPSU_INTR_SIG_EN_ERR_AHB_STS_EN_MASK
0x00000080U
Interrupt Status Register bit definitions and masks
#define
XNANDPSU_INTR_STS_BUFF_WR_RDY_STS_EN_MASK
0x00000001U
#define
XNANDPSU_INTR_STS_BUFF_RD_RDY_STS_EN_MASK
0x00000002U
#define
XNANDPSU_INTR_STS_TRANS_COMP_STS_EN_MASK
0x00000004U
#define
XNANDPSU_INTR_STS_MUL_BIT_ERR_STS_EN_MASK
0x00000008U
#define
XNANDPSU_INTR_STS_ERR_INTR_STS_EN_MASK
0x00000010U
#define
XNANDPSU_INTR_STS_DMA_INT_STS_EN_MASK
0x00000040U
#define
XNANDPSU_INTR_STS_ERR_AHB_STS_EN_MASK
0x00000080U
Interrupt bit definitions and masks
#define
XNANDPSU_INTR_BUFF_WR_RDY_STS_EN_MASK
0x00000001U
#define
XNANDPSU_INTR_BUFF_RD_RDY_STS_EN_MASK
0x00000002U
#define
XNANDPSU_INTR_TRANS_COMP_STS_EN_MASK
0x00000004U
#define
XNANDPSU_INTR_MUL_BIT_ERR_STS_EN_MASK
0x00000008U
#define
XNANDPSU_INTR_ERR_INTR_STS_EN_MASK
0x00000010U
#define
XNANDPSU_INTR_DMA_INT_STS_EN_MASK
0x00000040U
#define
XNANDPSU_INTR_ERR_AHB_STS_EN_MASK
0x00000080U
ID2 Register bit definitions and masks
#define
XNANDPSU_ID2_DEVICE_ID2_MASK
0x000000FFU
Flash Status Register bit definitions and masks
#define
XNANDPSU_FLASH_STS_FLASH_STS_MASK
0x0000FFFFU
Timing Register bit definitions and masks
#define
XNANDPSU_TIMING_TCCS_TIME_MASK
0x00000003U
#define
XNANDPSU_TIMING_SLOW_FAST_TCAD_MASK
0x00000004U
#define
XNANDPSU_TIMING_DQS_BUFF_SEL_MASK
0x00000078U
#define
XNANDPSU_TIMING_TADL_TIME_MASK
0x00007F80U
ECC Register bit definitions and masks
#define
XNANDPSU_ECC_ADDR_MASK
0x0000FFFFU
#define
XNANDPSU_ECC_SIZE_MASK
0x01FF0000U
#define
XNANDPSU_ECC_HAMMING_BCH_MASK
0x02000000U
ECC Error Count Register bit definitions and masks
#define
XNANDPSU_ECC_ERR_CNT_PKT_BND_ERR_CNT_MASK
0x000000FFU
#define
XNANDPSU_ECC_ERR_CNT_PG_BND_ERR_CNT_MASK
0x0000FF00U
ECC Spare Command Register bit definitions and masks
#define
XNANDPSU_ECC_SPR_CMD_SPR_CMD_MASK
0x000000FFU
#define
XNANDPSU_ECC_SPR_CMD_ECC_ADDR_CYCLES_MASK
0x70000000U
Data Interface Register bit definitions and masks
#define
XNANDPSU_DATA_INTF_SDR_MASK
0x00000007U
#define
XNANDPSU_DATA_INTF_NVDDR_MASK
0x00000038U
#define
XNANDPSU_DATA_INTF_NVDDR2_MASK
0x000001C0U
#define
XNANDPSU_DATA_INTF_DATA_INTF_MASK
0x00000600U
#define
XNANDPSU_DATA_INTF_NVDDR_SHIFT
3U
#define
XNANDPSU_DATA_INTF_DATA_INTF_SHIFT
9U
DMA Buffer Boundary Register bit definitions and masks
#define
XNANDPSU_DMA_BUF_BND_BND_MASK
0x00000007U
#define
XNANDPSU_DMA_BUF_BND_4K
0x0U
#define
XNANDPSU_DMA_BUF_BND_8K
0x1U
#define
XNANDPSU_DMA_BUF_BND_16K
0x2U
#define
XNANDPSU_DMA_BUF_BND_32K
0x3U
#define
XNANDPSU_DMA_BUF_BND_64K
0x4U
#define
XNANDPSU_DMA_BUF_BND_128K
0x5U
#define
XNANDPSU_DMA_BUF_BND_256K
0x6U
#define
XNANDPSU_DMA_BUF_BND_512K
0x7U
Slave DMA Configuration Register bit definitions and masks
#define
XNANDPSU_SLV_DMA_CONF_SDMA_TX_RX_MASK
0x00000001U
#define
XNANDPSU_SLV_DMA_CONF_DMA_TRANS_CNT_MASK
0x001FFFFEU
#define
XNANDPSU_SLV_DMA_CONF_DMA_BURST_SIZE_MASK
0x00E00000U
#define
XNANDPSU_SLV_DMA_CONF_DMA_TMOUT_CNT_VAL_MASK
0x0F000000U
#define
XNANDPSU_SLV_DMA_CONF_SDMA_EN_MASK
0x10000000U
#define
XNandPsu_ReadReg
(BaseAddress, RegOffset) Xil_In32((BaseAddress) + (RegOffset))
#define
XNandPsu_WriteReg
(BaseAddress, RegOffset, Data) Xil_Out32(((BaseAddress) + (RegOffset)), (Data))
