RTEMS 6.1
Data Structures | Macros | Typedefs | Enumerations | Functions | Variables
Overview
struct  XNandPsu_Config
struct  XNandPsu_BbtDesc
struct  XNandPsu_BadBlockPattern
struct  XNandPsu_Geometry
struct  XNandPsu_Features
struct  XNandPsu_EccMatrix
struct  XNandPsu_EccCfg
struct  XNandPsu
struct  __attribute__
struct  OnfiCmdFormat
struct  XQspiPsu_Msg
struct  XQspiPsu_Config
struct  XQspiPsu
struct  OptionsMap
#define XNANDPSU_H   /* by using protection macros */
#define XNANDPSU_DEBUG
#define XNANDPSU_MAX_TARGETS   1U
#define XNANDPSU_MAX_PKT_SIZE   0x7FFU
#define XNANDPSU_MAX_PKT_COUNT   0xFFFU
#define XNANDPSU_PAGE_SIZE_512   512U
#define XNANDPSU_PAGE_SIZE_2K   2048U
#define XNANDPSU_PAGE_SIZE_4K   4096U
#define XNANDPSU_PAGE_SIZE_8K   8192U
#define XNANDPSU_PAGE_SIZE_16K   16384U
#define XNANDPSU_PAGE_SIZE_1K_16BIT   1024U
#define XNANDPSU_MAX_PAGE_SIZE   16384U
#define XNANDPSU_HAMMING   0x1U
#define XNANDPSU_BCH   0x2U
#define XNANDPSU_MAX_BLOCKS   16384U
#define XNANDPSU_MAX_SPARE_SIZE   0x800U
#define XNANDPSU_MAX_LUNS   8U
#define XNANDPSU_MAX_PAGES_PER_BLOCK   512U
#define XNANDPSU_INTR_POLL_TIMEOUT   0xF000000U
#define XNANDPSU_SDR_CLK   ((u16)100U * (u16)1000U * (u16)1000U)
#define XNANDPSU_NVDDR_CLK_0   ((u16)20U * (u16)1000U * (u16)1000U)
#define XNANDPSU_NVDDR_CLK_1   ((u16)33U * (u16)1000U * (u16)1000U)
#define XNANDPSU_NVDDR_CLK_2   ((u16)50U * (u16)1000U * (u16)1000U)
#define XNANDPSU_NVDDR_CLK_3   ((u16)66U * (u16)1000U * (u16)1000U)
#define XNANDPSU_NVDDR_CLK_4   ((u16)83U * (u16)1000U * (u16)1000U)
#define XNANDPSU_NVDDR_CLK_5   ((u16)100U * (u16)1000U * (u16)1000U)
#define XNANDPSU_MAX_TIMING_MODE   5
#define XNandPsu_SetBits(InstancePtr, RegOffset, BitMask)
#define XNandPsu_ClrBits(InstancePtr, RegOffset, BitMask)
#define XNandPsu_ReadModifyWrite(InstancePtr, RegOffset, Mask, Value)
#define XNandPsu_IntrSigEnable(InstancePtr, Mask)
#define XNandPsu_IntrSigClear(InstancePtr, Mask)
#define XNandPsu_IntrStsEnable(InstancePtr, Mask)
#define IS_ONFI(Buff)
#define XNANDPSU_BBM_H   /* by using protection macros */
#define XNANDPSU_BLOCK_GOOD   0x0U
#define XNANDPSU_BLOCK_BAD   0x1U
#define XNANDPSU_BLOCK_RESERVED   0x2U
#define XNANDPSU_BLOCK_FACTORY_BAD   0x3U
#define XNANDPSU_FLASH_BLOCK_GOOD   0x3U
#define XNANDPSU_FLASH_BLOCK_BAD   0x2U
#define XNANDPSU_FLASH_BLOCK_RESERVED   0x1U
#define XNANDPSU_FLASH_BLOCK_FAC_BAD   0x0U
#define XNANDPSU_BBT_SCAN_2ND_PAGE   0x00000001U
#define XNANDPSU_BBT_DESC_PAGE_OFFSET   0U
#define XNANDPSU_BBT_DESC_SIG_OFFSET   8U
#define XNANDPSU_BBT_DESC_VER_OFFSET   12U
#define XNANDPSU_NO_OOB_BBT_DESC_SIG_OFFSET   0U
#define XNANDPSU_NO_OOB_BBT_DESC_VER_OFFSET   4U
#define XNANDPSU_BBT_DESC_SIG_LEN   4U
#define XNANDPSU_BBT_DESC_MAX_BLOCKS   64U
#define XNANDPSU_BBT_BLOCK_SHIFT   2U
#define XNANDPSU_BBT_ENTRY_NUM_BLOCKS   4U
#define XNANDPSU_BB_PTRN_OFF_SML_PAGE   5U
#define XNANDPSU_BB_PTRN_LEN_SML_PAGE   1U
#define XNANDPSU_BB_PTRN_OFF_LARGE_PAGE   0U
#define XNANDPSU_BB_PTRN_LEN_LARGE_PAGE   2U
#define XNANDPSU_BB_PATTERN   0xFFU
#define XNANDPSU_BLOCK_TYPE_MASK   0x03U
#define XNANDPSU_BLOCK_SHIFT_MASK   0x06U
#define XNANDPSU_ONDIE_SIG_OFFSET   0x4U
#define XNANDPSU_ONDIE_VER_OFFSET   0x14U
#define XNANDPSU_BBT_VERSION_LENGTH   1U
#define XNANDPSU_BBT_SIG_LENGTH   4U
#define XNANDPSU_BBT_BUF_LENGTH
#define XNandPsu_BbtBlockShift(Block)    (u8)(((Block) * 2U) & XNANDPSU_BLOCK_SHIFT_MASK)
#define XNANDPSU_HW_H   /* by using protection macros */
#define XNANDPSU_PKT_OFFSET   0x00U
#define XNANDPSU_MEM_ADDR1_OFFSET   0x04U
#define XNANDPSU_MEM_ADDR2_OFFSET   0x08U
#define XNANDPSU_CMD_OFFSET   0x0CU
#define XNANDPSU_PROG_OFFSET   0x10U
#define XNANDPSU_INTR_STS_EN_OFFSET   0x14U
#define XNANDPSU_INTR_SIG_EN_OFFSET   0x18U
#define XNANDPSU_INTR_STS_OFFSET   0x1CU
#define XNANDPSU_READY_BUSY_OFFSET   0x20U
#define XNANDPSU_FLASH_STS_OFFSET   0x28U
#define XNANDPSU_TIMING_OFFSET   0x2CU
#define XNANDPSU_BUF_DATA_PORT_OFFSET   0x30U
#define XNANDPSU_ECC_OFFSET   0x34U
#define XNANDPSU_ECC_ERR_CNT_OFFSET   0x38U
#define XNANDPSU_ECC_SPR_CMD_OFFSET   0x3CU
#define XNANDPSU_ECC_CNT_1BIT_OFFSET   0x40U
#define XNANDPSU_ECC_CNT_2BIT_OFFSET   0x44U
#define XNANDPSU_ECC_CNT_3BIT_OFFSET   0x48U
#define XNANDPSU_ECC_CNT_4BIT_OFFSET   0x4CU
#define XNANDPSU_CPU_REL_OFFSET   0x58U
#define XNANDPSU_ECC_CNT_5BIT_OFFSET   0x5CU
#define XNANDPSU_ECC_CNT_6BIT_OFFSET   0x60U
#define XNANDPSU_ECC_CNT_7BIT_OFFSET   0x64U
#define XNANDPSU_ECC_CNT_8BIT_OFFSET   0x68U
#define XNANDPSU_DATA_INTF_OFFSET   0x6CU
#define XNANDPSU_DMA_SYS_ADDR0_OFFSET   0x50U
#define XNANDPSU_DMA_SYS_ADDR1_OFFSET   0x24U
#define XNANDPSU_DMA_BUF_BND_OFFSET   0x54U
#define XNANDPSU_SLV_DMA_CONF_OFFSET   0x80U
#define XNANDPSU_ONFI_H   /* by using protection macros */
#define ONFI_CMD_RD1   0x00U
#define ONFI_CMD_RD2   0x30U
#define ONFI_CMD_CHNG_RD_COL1   0x05U
#define ONFI_CMD_CHNG_RD_COL2   0xE0U
#define ONFI_CMD_BLK_ERASE1   0x60U
#define ONFI_CMD_BLK_ERASE2   0xD0U
#define ONFI_CMD_RD_STS   0x70U
#define ONFI_CMD_PG_PROG1   0x80U
#define ONFI_CMD_PG_PROG2   0x10U
#define ONFI_CMD_CHNG_WR_COL   0x85U
#define ONFI_CMD_RD_ID   0x90U
#define ONFI_CMD_RD_PRM_PG   0xECU
#define ONFI_CMD_RST   0xFFU
#define ONFI_CMD_MUL_RD1   0x00U
#define ONFI_CMD_MUL_RD2   0x32U
#define ONFI_CMD_CPBK_RD1   0x00U
#define ONFI_CMD_CPBK_RD2   0x35U
#define ONFI_CMD_CHNG_RD_COL_ENHCD1   0x06U
#define ONFI_CMD_CHNG_RD_COL_ENHCD2   0xE0U
#define ONFI_CMD_RD_CACHE_RND1   0x00U
#define ONFI_CMD_RD_CACHE_RND2   0x31U
#define ONFI_CMD_RD_CACHE_SEQ   0x31U
#define ONFI_CMD_RD_CACHE_END   0x3FU
#define ONFI_CMD_MUL_BLK_ERASE1   0x60U
#define ONFI_CMD_MUL_BLK_ERASE2   0xD1U
#define ONFI_CMD_RD_STS_ENHCD   0x78U
#define ONFI_CMD_BLK_ERASE_INTRLVD2   0xD1U
#define ONFI_CMD_MUL_PG_PROG1   0x80U
#define ONFI_CMD_MUL_PG_PROG2   0x11U
#define ONFI_CMD_PG_CACHE_PROG1   0x80U
#define ONFI_CMD_PG_CACHE_PROG2   0x15U
#define ONFI_CMD_CPBK_PROG1   0x85U
#define ONFI_CMD_CPBK_PROG2   0x10U
#define ONFI_CMD_MUL_CPBK_PROG1   0x85U
#define ONFI_CMD_MUL_CPBK_PROG2   0x10U
#define ONFI_CMD_SMALL_DATA_MV1   0x85U
#define ONFI_CMD_SMALL_DATA_MV2   0x10U
#define ONFI_CMD_CHNG_ROW_ADDR   0x85U
#define ONFI_CMD_VOL_SEL   0xE1U
#define ONFI_CMD_ODT_CONF   0xE2U
#define ONFI_CMD_RD_UNIQID   0xEDU
#define ONFI_CMD_GET_FEATURES   0xEEU
#define ONFI_CMD_SET_FEATURES   0xEFU
#define ONFI_CMD_LUN_GET_FEATURES   0xD4U
#define ONFI_CMD_LUN_SET_FEATURES   0xD5U
#define ONFI_CMD_RST_LUN   0xFAU
#define ONFI_CMD_SYN_RST   0xFCU
#define ONFI_STS_FAIL   0x01U
#define ONFI_STS_FAILC   0x02U
#define ONFI_STS_CSP   0x08U
#define ONFI_STS_VSP   0x10U
#define ONFI_STS_ARDY   0x20U
#define ONFI_STS_RDY   0x40U
#define ONFI_STS_WP   0x80U
#define ONFI_CRC_LEN   254U
#define ONFI_PRM_PG_LEN   256U
#define ONFI_MND_PRM_PGS   3U
#define ONFI_SIG_LEN   4U
#define ONFI_CMD_INVALID   0x00U
#define ONFI_READ_ID_LEN   4U
#define ONFI_READ_ID_ADDR   0x20U
#define ONFI_READ_ID_ADDR_CYCLES   1U
#define ONFI_PRM_PG_ADDR_CYCLES   1U
#define XQSPIPSU_H_
#define BYTES256_PER_PAGE   256U
#define BYTES512_PER_PAGE   512U
#define BYTES1024_PER_PAGE   1024U
#define PAGES16_PER_SECTOR   16U
#define PAGES128_PER_SECTOR   128U
#define PAGES256_PER_SECTOR   256U
#define PAGES512_PER_SECTOR   512U
#define PAGES1024_PER_SECTOR   1024U
#define NUM_OF_SECTORS2   2U
#define NUM_OF_SECTORS4   4U
#define NUM_OF_SECTORS8   8U
#define NUM_OF_SECTORS16   16U
#define NUM_OF_SECTORS32   32U
#define NUM_OF_SECTORS64   64U
#define NUM_OF_SECTORS128   128U
#define NUM_OF_SECTORS256   256U
#define NUM_OF_SECTORS512   512U
#define NUM_OF_SECTORS1024   1024U
#define NUM_OF_SECTORS2048   2048U
#define NUM_OF_SECTORS4096   4096U
#define NUM_OF_SECTORS8192   8192U
#define SECTOR_SIZE_64K   0X10000U
#define SECTOR_SIZE_128K   0X20000U
#define SECTOR_SIZE_256K   0X40000U
#define SECTOR_SIZE_512K   0X80000U
#define XQSPIPSU_READMODE_DMA   0x0U
#define XQSPIPSU_READMODE_IO   0x1U
#define XQSPIPSU_SELECT_FLASH_CS_LOWER   0x1U
#define XQSPIPSU_SELECT_FLASH_CS_UPPER   0x2U
#define XQSPIPSU_SELECT_FLASH_CS_BOTH   0x3U
#define XQSPIPSU_SELECT_FLASH_BUS_LOWER   0x1U
#define XQSPIPSU_SELECT_FLASH_BUS_UPPER   0x2U
#define XQSPIPSU_SELECT_FLASH_BUS_BOTH   0x3U
#define XQSPIPSU_SELECT_MODE_SPI   0x1U
#define XQSPIPSU_SELECT_MODE_DUALSPI   0x2U
#define XQSPIPSU_SELECT_MODE_QUADSPI   0x4U
#define XQSPIPSU_GENFIFO_CS_SETUP   0x05U
#define XQSPIPSU_GENFIFO_CS_HOLD   0x04U
#define XQSPIPSU_CLK_ACTIVE_LOW_OPTION   0x2U
#define XQSPIPSU_CLK_PHASE_1_OPTION   0x4U
#define XQSPIPSU_MANUAL_START_OPTION   0x8U
#define XQSPIPSU_LQSPI_MODE_OPTION   0x20U
#define XQSPIPSU_LQSPI_LESS_THEN_SIXTEENMB   1U
#define XQSPIPSU_GENFIFO_EXP_START   0x100U
#define XQSPIPSU_DMA_BYTES_MAX   0x10000000U
#define XQSPIPSU_CLK_PRESCALE_2   0x00U
#define XQSPIPSU_CLK_PRESCALE_4   0x01U
#define XQSPIPSU_CLK_PRESCALE_8   0x02U
#define XQSPIPSU_CLK_PRESCALE_16   0x03U
#define XQSPIPSU_CLK_PRESCALE_32   0x04U
#define XQSPIPSU_CLK_PRESCALE_64   0x05U
#define XQSPIPSU_CLK_PRESCALE_128   0x06U
#define XQSPIPSU_CLK_PRESCALE_256   0x07U
#define XQSPIPSU_CR_PRESC_MAXIMUM   7U
#define XQSPIPSU_CONNECTION_MODE_SINGLE   0U
#define XQSPIPSU_CONNECTION_MODE_STACKED   1U
#define XQSPIPSU_CONNECTION_MODE_PARALLEL   2U
#define XQSPIPSU_FREQ_37_5MHZ   37500000U
#define XQSPIPSU_FREQ_40MHZ   40000000U
#define XQSPIPSU_FREQ_100MHZ   100000000U
#define XQSPIPSU_FREQ_150MHZ   150000000U
#define XQSPIPSU_MSG_FLAG_STRIPE   0x1U
#define XQSPIPSU_MSG_FLAG_RX   0x2U
#define XQSPIPSU_MSG_FLAG_TX   0x4U
#define XQSPIPSU_MSG_FLAG_POLL   0x8U
#define XQSPIPSU_RXADDR_OVER_32BIT   0x100000000U
#define XQSPIPSU_SET_WP   1
#define XQspiPsu_Select(InstancePtr, Mask)
#define XQspiPsu_Enable(InstancePtr)
#define XQspiPsu_Disable(InstancePtr)
#define XQspiPsu_GetLqspiConfigReg(InstancePtr)
#define XQSPIPSU_HW_H
#define XQspiPsu_In32   Xil_In32
#define XQspiPsu_Out32   Xil_Out32
#define XQspiPsu_ReadReg(BaseAddress, RegOffset)   XQspiPsu_In32((BaseAddress) + (RegOffset))
#define XQspiPsu_WriteReg(BaseAddress, RegOffset, RegisterValue)   XQspiPsu_Out32((BaseAddress) + (RegOffset), (RegisterValue))
#define MAX_DELAY_CNT   10000000U
#define XQSPIPSU_NUM_OPTIONS   (sizeof(OptionsTable) / sizeof(OptionsMap))
typedef void(* XQspiPsu_StatusHandler) (const void *CallBackRef, u32 StatusEvent, u32 ByteCount)
enum  XNandPsu_DataInterface { XNANDPSU_SDR = 0U , XNANDPSU_NVDDR }
enum  XNandPsu_TimingMode {
  XNANDPSU_SDR0 = 0U , XNANDPSU_SDR1 , XNANDPSU_SDR2 , XNANDPSU_SDR3 ,
  XNANDPSU_SDR4 , XNANDPSU_SDR5 , XNANDPSU_NVDDR0 , XNANDPSU_NVDDR1 ,
  XNANDPSU_NVDDR2 , XNANDPSU_NVDDR3 , XNANDPSU_NVDDR4 , XNANDPSU_NVDDR5
enum  XNandPsu_SWMode { XNANDPSU_POLLING = 0 , XNANDPSU_INTERRUPT }
enum  XNandPsu_DmaMode { XNANDPSU_PIO = 0 , XNANDPSU_SDMA , XNANDPSU_MDMA }
enum  XNandPsu_EccMode { XNANDPSU_NONE = 0 , XNANDPSU_HWECC , XNANDPSU_EZNAND , XNANDPSU_ONDIE }
enum  OnfiCommandList {
  READ =0 , MULTIPLANE_READ , COPYBACK_READ , CHANGE_READ_COLUMN ,
  CHANGE_READ_COLUMN_ENHANCED , READ_CACHE_RANDOM , READ_CACHE_SEQUENTIAL , READ_CACHE_END ,
  BLOCK_ERASE , MULTIPLANE_BLOCK_ERASE , READ_STATUS , READ_STATUS_ENHANCED ,
  PAGE_PROGRAM , MULTIPLANE_PAGE_PROGRAM , PAGE_CACHE_PROGRAM , COPYBACK_PROGRAM ,
  MULTIPLANE_COPYBACK_PROGRAM , SMALL_DATA_MOVE , CHANGE_WRITE_COLUMN , CHANGE_ROW_ADDR ,
  READ_ID , VOLUME_SELECT , ODT_CONFIGURE , READ_PARAM_PAGE ,
  READ_UNIQUE_ID , GET_FEATURES , SET_FEATURES , LUN_GET_FEATURES ,
  LUN_SET_FEATURES , RESET_LUN , SYN_RESET , RESET ,
  MAX_CMDS
s32 XNandPsu_CfgInitialize (XNandPsu *InstancePtr, XNandPsu_Config *ConfigPtr, u32 EffectiveAddr)
s32 XNandPsu_Erase (XNandPsu *InstancePtr, u64 Offset, u64 Length)
s32 XNandPsu_Write (XNandPsu *InstancePtr, u64 Offset, u64 Length, u8 *SrcBuf)
s32 XNandPsu_Read (XNandPsu *InstancePtr, u64 Offset, u64 Length, u8 *DestBuf)
s32 XNandPsu_EraseBlock (XNandPsu *InstancePtr, u32 Target, u32 Block)
s32 XNandPsu_WriteSpareBytes (XNandPsu *InstancePtr, u32 Page, u8 *Buf)
s32 XNandPsu_ReadSpareBytes (XNandPsu *InstancePtr, u32 Page, u8 *Buf)
s32 XNandPsu_ChangeTimingMode (XNandPsu *InstancePtr, XNandPsu_DataInterface NewIntf, XNandPsu_TimingMode NewMode)
s32 XNandPsu_GetFeature (XNandPsu *InstancePtr, u32 Target, u8 Feature, u8 *Buf)
s32 XNandPsu_SetFeature (XNandPsu *InstancePtr, u32 Target, u8 Feature, u8 *Buf)
s32 XNandPsu_ScanBbt (XNandPsu *InstancePtr)
s32 XNandPsu_MarkBlockBad (XNandPsu *InstancePtr, u32 Block)
void XNandPsu_EnableDmaMode (XNandPsu *InstancePtr)
void XNandPsu_DisableDmaMode (XNandPsu *InstancePtr)
void XNandPsu_EnableEccMode (XNandPsu *InstancePtr)
void XNandPsu_DisableEccMode (XNandPsu *InstancePtr)
void XNandPsu_Prepare_Cmd (XNandPsu *InstancePtr, u8 Cmd1, u8 Cmd2, u8 EccState, u8 DmaMode, u8 AddrCycles)
XNandPsu_ConfigXNandPsu_LookupConfig (u16 DevID)
void XNandPsu_InitBbtDesc (XNandPsu *InstancePtr)
s32 XNandPsu_IsBlockBad (XNandPsu *InstancePtr, u32 Block)
u32 XNandPsu_OnfiParamPageCrc (u8 *ParamBuf, u32 StartOff, u32 Length)
XQspiPsu_ConfigXQspiPsu_LookupConfig (u16 DeviceId)
s32 XQspiPsu_CfgInitialize (XQspiPsu *InstancePtr, const XQspiPsu_Config *ConfigPtr, UINTPTR EffectiveAddr)
void XQspiPsu_Reset (XQspiPsu *InstancePtr)
void XQspiPsu_Abort (XQspiPsu *InstancePtr)
s32 XQspiPsu_PolledTransfer (XQspiPsu *InstancePtr, XQspiPsu_Msg *Msg, u32 NumMsg)
s32 XQspiPsu_InterruptTransfer (XQspiPsu *InstancePtr, XQspiPsu_Msg *Msg, u32 NumMsg)
s32 XQspiPsu_InterruptHandler (XQspiPsu *InstancePtr)
void XQspiPsu_SetStatusHandler (XQspiPsu *InstancePtr, void *CallBackRef, XQspiPsu_StatusHandler FuncPointer)
s32 XQspiPsu_StartDmaTransfer (XQspiPsu *InstancePtr, XQspiPsu_Msg *Msg, u32 NumMsg)
s32 XQspiPsu_CheckDmaDone (XQspiPsu *InstancePtr)
s32 XQspiPsu_SetClkPrescaler (const XQspiPsu *InstancePtr, u8 Prescaler)
void XQspiPsu_SelectFlash (XQspiPsu *InstancePtr, u8 FlashCS, u8 FlashBus)
s32 XQspiPsu_SetOptions (XQspiPsu *InstancePtr, u32 Options)
s32 XQspiPsu_ClearOptions (XQspiPsu *InstancePtr, u32 Options)
u32 XQspiPsu_GetOptions (const XQspiPsu *InstancePtr)
s32 XQspiPsu_SetReadMode (XQspiPsu *InstancePtr, u32 Mode)
void XQspiPsu_SetWP (const XQspiPsu *InstancePtr, u8 Value)
void XQspiPsu_WriteProtectToggle (const XQspiPsu *InstancePtr, u32 Toggle)
 This API enables/ disables Write Protect pin on the flash parts.
void XQspiPsu_Idle (const XQspiPsu *InstancePtr)
void XQspiPsu_PollDataHandler (XQspiPsu *InstancePtr, u32 StatusReg)
void XQspiPsu_GenFifoEntryData (XQspiPsu *InstancePtr, XQspiPsu_Msg *Msg)
void XQspiPsu_PollDataConfig (XQspiPsu *InstancePtr, XQspiPsu_Msg *FlashMsg)
void XQspiPsu_FillTxFifo (XQspiPsu *InstancePtr, XQspiPsu_Msg *Msg, u32 Size)
void XQspiPsu_TXSetup (XQspiPsu *InstancePtr, XQspiPsu_Msg *Msg)
void XQspiPsu_SetupRxDma (const XQspiPsu *InstancePtr, XQspiPsu_Msg *Msg)
void XQspiPsu_Setup64BRxDma (const XQspiPsu *InstancePtr, XQspiPsu_Msg *Msg)
u32 XQspiPsu_SetIOMode (XQspiPsu *InstancePtr, XQspiPsu_Msg *Msg)
void XQspiPsu_RXSetup (XQspiPsu *InstancePtr, XQspiPsu_Msg *Msg)
void XQspiPsu_TXRXSetup (XQspiPsu *InstancePtr, XQspiPsu_Msg *Msg, u32 *GenFifoEntry)
void XQspiPsu_GenFifoEntryDataLen (XQspiPsu *InstancePtr, XQspiPsu_Msg *Msg, u32 *GenFifoEntry)
u32 XQspiPsu_CreatePollDataConfig (const XQspiPsu *InstancePtr, const XQspiPsu_Msg *FlashMsg)
u32 XQspiPsu_SelectSpiMode (u8 SpiMode)
void XQspiPsu_SetDefaultConfig (XQspiPsu *InstancePtr)
void XQspiPsu_ReadRxFifo (XQspiPsu *InstancePtr, XQspiPsu_Msg *Msg, s32 Size)
void XQspiPsu_IORead (XQspiPsu *InstancePtr, XQspiPsu_Msg *Msg, u32 StatusReg)
const OnfiCmdFormat OnfiCmd [MAX_CMDS]
XQspiPsu_Config XQspiPsu_ConfigTable [XPAR_XQSPIPSU_NUM_INSTANCES]
Packet Register bit definitions and masks
#define XNANDPSU_PKT_PKT_SIZE_MASK   0x000007FFU
#define XNANDPSU_PKT_PKT_CNT_MASK   0x00FFF000U
#define XNANDPSU_PKT_PKT_CNT_SHIFT   12U
Memory Address Register 1 bit definitions and masks
#define XNANDPSU_MEM_ADDR1_COL_ADDR_MASK   0x0000FFFFU
#define XNANDPSU_MEM_ADDR1_PG_ADDR_MASK   0xFFFF0000U
#define XNANDPSU_MEM_ADDR1_PG_ADDR_SHIFT   16U
Memory Address Register 2 bit definitions and masks
#define XNANDPSU_MEM_ADDR2_MEM_ADDR_MASK   0x000000FFU
#define XNANDPSU_MEM_ADDR2_BUS_WIDTH_MASK   0x01000000U
#define XNANDPSU_MEM_ADDR2_NFC_BCH_MODE_MASK   0x0E000000U
#define XNANDPSU_MEM_ADDR2_MODE_MASK   0x30000000U
#define XNANDPSU_MEM_ADDR2_CHIP_SEL_MASK   0xC0000000U
#define XNANDPSU_MEM_ADDR2_CHIP_SEL_SHIFT   30U
#define XNANDPSU_MEM_ADDR2_BUS_WIDTH_SHIFT   24U
#define XNANDPSU_MEM_ADDR2_NFC_BCH_MODE_SHIFT   25U
Command Register bit definitions and masks
#define XNANDPSU_CMD_CMD1_MASK   0x000000FFU
#define XNANDPSU_CMD_CMD2_MASK   0x0000FF00U
#define XNANDPSU_CMD_PG_SIZE_MASK   0x03800000U
#define XNANDPSU_CMD_DMA_EN_MASK   0x0C000000U
#define XNANDPSU_CMD_ADDR_CYCLES_MASK   0x70000000U
#define XNANDPSU_CMD_ECC_ON_MASK   0x80000000U
#define XNANDPSU_CMD_CMD2_SHIFT   8U
#define XNANDPSU_CMD_PG_SIZE_SHIFT   23U
#define XNANDPSU_CMD_DMA_EN_SHIFT   26U
#define XNANDPSU_CMD_ADDR_CYCLES_SHIFT   28U
#define XNANDPSU_CMD_ECC_ON_SHIFT   31U
Program Register bit definitions and masks
#define XNANDPSU_PROG_RD_MASK   0x00000001U
#define XNANDPSU_PROG_MUL_DIE_MASK   0x00000002U
#define XNANDPSU_PROG_BLK_ERASE_MASK   0x00000004U
#define XNANDPSU_PROG_RD_STS_MASK   0x00000008U
#define XNANDPSU_PROG_PG_PROG_MASK   0x00000010U
#define XNANDPSU_PROG_MUL_DIE_RD_MASK   0x00000020U
#define XNANDPSU_PROG_RD_ID_MASK   0x00000040U
#define XNANDPSU_PROG_RD_PRM_PG_MASK   0x00000080U
#define XNANDPSU_PROG_RST_MASK   0x00000100U
#define XNANDPSU_PROG_GET_FEATURES_MASK   0x00000200U
#define XNANDPSU_PROG_SET_FEATURES_MASK   0x00000400U
#define XNANDPSU_PROG_RD_UNQ_ID_MASK   0x00000800U
#define XNANDPSU_PROG_RD_STS_ENH_MASK   0x00001000U
#define XNANDPSU_PROG_RD_INTRLVD_MASK   0x00002000U
#define XNANDPSU_PROG_CHNG_RD_COL_ENH_MASK   0x00004000U
#define XNANDPSU_PROG_COPY_BACK_INTRLVD_MASK   0x00008000U
#define XNANDPSU_PROG_RD_CACHE_START_MASK   0x00010000U
#define XNANDPSU_PROG_RD_CACHE_SEQ_MASK   0x00020000U
#define XNANDPSU_PROG_RD_CACHE_RAND_MASK   0x00040000U
#define XNANDPSU_PROG_RD_CACHE_END_MASK   0x00080000U
#define XNANDPSU_PROG_SMALL_DATA_MOVE_MASK   0x00100000U
#define XNANDPSU_PROG_CHNG_ROW_ADDR_MASK   0x00200000U
#define XNANDPSU_PROG_CHNG_ROW_ADDR_END_MASK   0x00400000U
#define XNANDPSU_PROG_RST_LUN_MASK   0x00800000U
#define XNANDPSU_PROG_PGM_PG_CLR_MASK   0x01000000U
#define XNANDPSU_PROG_VOL_SEL_MASK   0x02000000U
#define XNANDPSU_PROG_ODT_CONF_MASK   0x04000000U
Interrupt Status Enable Register bit definitions and masks
#define XNANDPSU_INTR_STS_EN_BUFF_WR_RDY_STS_EN_MASK   0x00000001U
#define XNANDPSU_INTR_STS_EN_BUFF_RD_RDY_STS_EN_MASK   0x00000002U
#define XNANDPSU_INTR_STS_EN_TRANS_COMP_STS_EN_MASK   0x00000004U
#define XNANDPSU_INTR_STS_EN_MUL_BIT_ERR_STS_EN_MASK   0x00000008U
#define XNANDPSU_INTR_STS_EN_ERR_INTR_STS_EN_MASK   0x00000010U
#define XNANDPSU_INTR_STS_EN_DMA_INT_STS_EN_MASK   0x00000040U
#define XNANDPSU_INTR_STS_EN_ERR_AHB_STS_EN_MASK   0x00000080U
Interrupt Signal Enable Register bit definitions and masks
#define XNANDPSU_INTR_SIG_EN_BUFF_WR_RDY_STS_EN_MASK   0x00000001U
#define XNANDPSU_INTR_SIG_EN_BUFF_RD_RDY_STS_EN_MASK   0x00000002U
#define XNANDPSU_INTR_SIG_EN_TRANS_COMP_STS_EN_MASK   0x00000004U
#define XNANDPSU_INTR_SIG_EN_MUL_BIT_ERR_STS_EN_MASK   0x00000008U
#define XNANDPSU_INTR_SIG_EN_ERR_INTR_STS_EN_MASK   0x00000010U
#define XNANDPSU_INTR_SIG_EN_DMA_INT_STS_EN_MASK   0x00000040U
#define XNANDPSU_INTR_SIG_EN_ERR_AHB_STS_EN_MASK   0x00000080U
Interrupt Status Register bit definitions and masks
#define XNANDPSU_INTR_STS_BUFF_WR_RDY_STS_EN_MASK   0x00000001U
#define XNANDPSU_INTR_STS_BUFF_RD_RDY_STS_EN_MASK   0x00000002U
#define XNANDPSU_INTR_STS_TRANS_COMP_STS_EN_MASK   0x00000004U
#define XNANDPSU_INTR_STS_MUL_BIT_ERR_STS_EN_MASK   0x00000008U
#define XNANDPSU_INTR_STS_ERR_INTR_STS_EN_MASK   0x00000010U
#define XNANDPSU_INTR_STS_DMA_INT_STS_EN_MASK   0x00000040U
#define XNANDPSU_INTR_STS_ERR_AHB_STS_EN_MASK   0x00000080U
Interrupt bit definitions and masks
#define XNANDPSU_INTR_BUFF_WR_RDY_STS_EN_MASK   0x00000001U
#define XNANDPSU_INTR_BUFF_RD_RDY_STS_EN_MASK   0x00000002U
#define XNANDPSU_INTR_TRANS_COMP_STS_EN_MASK   0x00000004U
#define XNANDPSU_INTR_MUL_BIT_ERR_STS_EN_MASK   0x00000008U
#define XNANDPSU_INTR_ERR_INTR_STS_EN_MASK   0x00000010U
#define XNANDPSU_INTR_DMA_INT_STS_EN_MASK   0x00000040U
#define XNANDPSU_INTR_ERR_AHB_STS_EN_MASK   0x00000080U
ID2 Register bit definitions and masks
#define XNANDPSU_ID2_DEVICE_ID2_MASK   0x000000FFU
Flash Status Register bit definitions and masks
#define XNANDPSU_FLASH_STS_FLASH_STS_MASK   0x0000FFFFU
Timing Register bit definitions and masks
#define XNANDPSU_TIMING_TCCS_TIME_MASK   0x00000003U
#define XNANDPSU_TIMING_SLOW_FAST_TCAD_MASK   0x00000004U
#define XNANDPSU_TIMING_DQS_BUFF_SEL_MASK   0x00000078U
#define XNANDPSU_TIMING_TADL_TIME_MASK   0x00007F80U
ECC Register bit definitions and masks
#define XNANDPSU_ECC_ADDR_MASK   0x0000FFFFU
#define XNANDPSU_ECC_SIZE_MASK   0x01FF0000U
#define XNANDPSU_ECC_HAMMING_BCH_MASK   0x02000000U
ECC Error Count Register bit definitions and masks
#define XNANDPSU_ECC_ERR_CNT_PKT_BND_ERR_CNT_MASK   0x000000FFU
#define XNANDPSU_ECC_ERR_CNT_PG_BND_ERR_CNT_MASK   0x0000FF00U
ECC Spare Command Register bit definitions and masks
#define XNANDPSU_ECC_SPR_CMD_SPR_CMD_MASK   0x000000FFU
#define XNANDPSU_ECC_SPR_CMD_ECC_ADDR_CYCLES_MASK   0x70000000U
Data Interface Register bit definitions and masks
#define XNANDPSU_DATA_INTF_SDR_MASK   0x00000007U
#define XNANDPSU_DATA_INTF_NVDDR_MASK   0x00000038U
#define XNANDPSU_DATA_INTF_NVDDR2_MASK   0x000001C0U
#define XNANDPSU_DATA_INTF_DATA_INTF_MASK   0x00000600U
#define XNANDPSU_DATA_INTF_NVDDR_SHIFT   3U
#define XNANDPSU_DATA_INTF_DATA_INTF_SHIFT   9U
DMA Buffer Boundary Register bit definitions and masks
#define XNANDPSU_DMA_BUF_BND_BND_MASK   0x00000007U
#define XNANDPSU_DMA_BUF_BND_4K   0x0U
#define XNANDPSU_DMA_BUF_BND_8K   0x1U
#define XNANDPSU_DMA_BUF_BND_16K   0x2U
#define XNANDPSU_DMA_BUF_BND_32K   0x3U
#define XNANDPSU_DMA_BUF_BND_64K   0x4U
#define XNANDPSU_DMA_BUF_BND_128K   0x5U
#define XNANDPSU_DMA_BUF_BND_256K   0x6U
#define XNANDPSU_DMA_BUF_BND_512K   0x7U
Slave DMA Configuration Register bit definitions and masks
#define XNANDPSU_SLV_DMA_CONF_SDMA_TX_RX_MASK   0x00000001U
#define XNANDPSU_SLV_DMA_CONF_DMA_TRANS_CNT_MASK   0x001FFFFEU
#define XNANDPSU_SLV_DMA_CONF_DMA_BURST_SIZE_MASK   0x00E00000U
#define XNANDPSU_SLV_DMA_CONF_DMA_TMOUT_CNT_VAL_MASK   0x0F000000U
#define XNANDPSU_SLV_DMA_CONF_SDMA_EN_MASK   0x10000000U
#define XNandPsu_ReadReg(BaseAddress, RegOffset)    Xil_In32((BaseAddress) + (RegOffset))
#define XNandPsu_WriteReg(BaseAddress, RegOffset, Data)    Xil_Out32(((BaseAddress) + (RegOffset)), (Data))
Device Base Address
Below macros gives QSPI, QSPIPSU base address.
#define XQSPIPS_BASEADDR   0XFF0F0000U
#define XQSPIPSU_BASEADDR   0xFF0F0100U
#define XQSPIPSU_OFFSET   0x100U
XQSPIPS Enable Register information
QSPIPSU Enable Register
#define XQSPIPS_EN_REG   ( ( XQSPIPS_BASEADDR ) + 0X00000014U )
#define XQSPIPS_EN_SHIFT   0U
#define XQSPIPS_EN_WIDTH   1U
#define XQSPIPS_EN_MASK   0X00000001U
XQSPIPSU configuration Register information
This register contains bits for configuring GQSPI controller
#define XQSPIPSU_CFG_OFFSET   0X00000000U
#define XQSPIPSU_CFG_MODE_EN_SHIFT   30U
#define XQSPIPSU_CFG_MODE_EN_WIDTH   2U
#define XQSPIPSU_CFG_MODE_EN_MASK   0XC0000000U
#define XQSPIPSU_CFG_MODE_EN_DMA_MASK   0X80000000U
#define XQSPIPSU_CFG_GEN_FIFO_START_MODE_SHIFT   29U
#define XQSPIPSU_CFG_GEN_FIFO_START_MODE_WIDTH   1U
#define XQSPIPSU_CFG_GEN_FIFO_START_MODE_MASK   0X20000000U
#define XQSPIPSU_CFG_START_GEN_FIFO_SHIFT   28U
#define XQSPIPSU_CFG_START_GEN_FIFO_WIDTH   1U
#define XQSPIPSU_CFG_START_GEN_FIFO_MASK   0X10000000U
#define XQSPIPSU_CFG_ENDIAN_SHIFT   26U
#define XQSPIPSU_CFG_ENDIAN_WIDTH   1U
#define XQSPIPSU_CFG_ENDIAN_MASK   0X04000000U
#define XQSPIPSU_CFG_EN_POLL_TO_SHIFT   20U
#define XQSPIPSU_CFG_EN_POLL_TO_WIDTH   1U
#define XQSPIPSU_CFG_EN_POLL_TO_MASK   0X00100000U
#define XQSPIPSU_CFG_WP_HOLD_SHIFT   19U
#define XQSPIPSU_CFG_WP_HOLD_WIDTH   1U
#define XQSPIPSU_CFG_WP_HOLD_MASK   0X00080000U
#define XQSPIPSU_CFG_BAUD_RATE_DIV_SHIFT   3U
#define XQSPIPSU_CFG_BAUD_RATE_DIV_WIDTH   3U
#define XQSPIPSU_CFG_BAUD_RATE_DIV_MASK   0X00000038U
#define XQSPIPSU_CFG_CLK_PHA_SHIFT   2U
#define XQSPIPSU_CFG_CLK_PHA_WIDTH   1U
#define XQSPIPSU_CFG_CLK_PHA_MASK   0X00000004U
#define XQSPIPSU_CFG_CLK_POL_SHIFT   1U
#define XQSPIPSU_CFG_CLK_POL_WIDTH   1U
#define XQSPIPSU_CFG_CLK_POL_MASK   0X00000002U
XQSPIPSU LQSPI Register information
This register contains bits for configuring LQSPI
#define XQSPIPSU_LQSPI_CR_OFFSET   0X000000A0U
#define XQSPIPSU_LQSPI_CR_LINEAR_MASK   0x80000000U
#define XQSPIPSU_LQSPI_CR_TWO_MEM_MASK   0x40000000U
#define XQSPIPSU_LQSPI_CR_SEP_BUS_MASK   0x20000000U
#define XQSPIPSU_LQSPI_CR_U_PAGE_MASK   0x10000000U
#define XQSPIPSU_LQSPI_CR_ADDR_32BIT_MASK   0x01000000U
#define XQSPIPSU_LQSPI_CR_MODE_EN_MASK   0x02000000U
#define XQSPIPSU_LQSPI_CR_MODE_ON_MASK   0x01000000U
#define XQSPIPSU_LQSPI_CR_MODE_BITS_MASK   0x00FF0000U
#define XQSPIPS_LQSPI_CR_INST_MASK   0x000000FFU
#define XQSPIPS_LQSPI_CR_RST_STATE   0x80000003U
#define XQSPIPS_LQSPI_CR_4_BYTE_STATE   0x88000013U
#define XQSPIPS_LQSPI_CFG_RST_STATE   0x800238C1U
XQSPIPSU Interrupt Status Register information
#define XQSPIPSU_ISR_OFFSET   0X00000004U
#define XQSPIPSU_ISR_RXEMPTY_SHIFT   11U
#define XQSPIPSU_ISR_RXEMPTY_WIDTH   1U
#define XQSPIPSU_ISR_RXEMPTY_MASK   0X00000800U
#define XQSPIPSU_ISR_GENFIFOFULL_SHIFT   10U
#define XQSPIPSU_ISR_GENFIFOFULL_WIDTH   1U
#define XQSPIPSU_ISR_GENFIFOFULL_MASK   0X00000400U
#define XQSPIPSU_ISR_GENFIFONOT_FULL_SHIFT   9U
#define XQSPIPSU_ISR_GENFIFONOT_FULL_WIDTH   1U
#define XQSPIPSU_ISR_GENFIFONOT_FULL_MASK   0X00000200U
#define XQSPIPSU_ISR_TXEMPTY_SHIFT   8U
#define XQSPIPSU_ISR_TXEMPTY_WIDTH   1U
#define XQSPIPSU_ISR_TXEMPTY_MASK   0X00000100U
#define XQSPIPSU_ISR_GENFIFOEMPTY_SHIFT   7U
#define XQSPIPSU_ISR_GENFIFOEMPTY_WIDTH   1U
#define XQSPIPSU_ISR_GENFIFOEMPTY_MASK   0X00000080U
#define XQSPIPSU_ISR_RXFULL_SHIFT   5U
#define XQSPIPSU_ISR_RXFULL_WIDTH   1U
#define XQSPIPSU_ISR_RXFULL_MASK   0X00000020U
#define XQSPIPSU_ISR_RXNEMPTY_SHIFT   4U
#define XQSPIPSU_ISR_RXNEMPTY_WIDTH   1U
#define XQSPIPSU_ISR_RXNEMPTY_MASK   0X00000010U
#define XQSPIPSU_ISR_TXFULL_SHIFT   3U
#define XQSPIPSU_ISR_TXFULL_WIDTH   1U
#define XQSPIPSU_ISR_TXFULL_MASK   0X00000008U
#define XQSPIPSU_ISR_TXNOT_FULL_SHIFT   2U
#define XQSPIPSU_ISR_TXNOT_FULL_WIDTH   1U
#define XQSPIPSU_ISR_TXNOT_FULL_MASK   0X00000004U
#define XQSPIPSU_ISR_POLL_TIME_EXPIRE_SHIFT   1U
#define XQSPIPSU_ISR_POLL_TIME_EXPIRE_WIDTH   1U
#define XQSPIPSU_ISR_POLL_TIME_EXPIRE_MASK   0X00000002U
#define XQSPIPSU_ISR_WR_TO_CLR_MASK   0X00000002U
XQSPIPSU Interrupt Enable Register information
This register bits for enabling interrupts
#define XQSPIPSU_IER_OFFSET   0X00000008U
#define XQSPIPSU_IER_RXEMPTY_SHIFT   11U
#define XQSPIPSU_IER_RXEMPTY_WIDTH   1U
#define XQSPIPSU_IER_RXEMPTY_MASK   0X00000800U
#define XQSPIPSU_IER_GENFIFOFULL_SHIFT   10U
#define XQSPIPSU_IER_GENFIFOFULL_WIDTH   1U
#define XQSPIPSU_IER_GENFIFOFULL_MASK   0X00000400U
#define XQSPIPSU_IER_GENFIFONOT_FULL_SHIFT   9U
#define XQSPIPSU_IER_GENFIFONOT_FULL_WIDTH   1U
#define XQSPIPSU_IER_GENFIFONOT_FULL_MASK   0X00000200U
#define XQSPIPSU_IER_TXEMPTY_SHIFT   8U
#define XQSPIPSU_IER_TXEMPTY_WIDTH   1U
#define XQSPIPSU_IER_TXEMPTY_MASK   0X00000100U
#define XQSPIPSU_IER_GENFIFOEMPTY_SHIFT   7U
#define XQSPIPSU_IER_GENFIFOEMPTY_WIDTH   1U
#define XQSPIPSU_IER_GENFIFOEMPTY_MASK   0X00000080U
#define XQSPIPSU_IER_RXFULL_SHIFT   5U
#define XQSPIPSU_IER_RXFULL_WIDTH   1U
#define XQSPIPSU_IER_RXFULL_MASK   0X00000020U
#define XQSPIPSU_IER_RXNEMPTY_SHIFT   4U
#define XQSPIPSU_IER_RXNEMPTY_WIDTH   1U
#define XQSPIPSU_IER_RXNEMPTY_MASK   0X00000010U
#define XQSPIPSU_IER_TXFULL_SHIFT   3U
#define XQSPIPSU_IER_TXFULL_WIDTH   1U
#define XQSPIPSU_IER_TXFULL_MASK   0X00000008U
#define XQSPIPSU_IER_TXNOT_FULL_SHIFT   2U
#define XQSPIPSU_IER_TXNOT_FULL_WIDTH   1U
#define XQSPIPSU_IER_TXNOT_FULL_MASK   0X00000004U
#define XQSPIPSU_IER_POLL_TIME_EXPIRE_SHIFT   1U
#define XQSPIPSU_IER_POLL_TIME_EXPIRE_WIDTH   1U
#define XQSPIPSU_IER_POLL_TIME_EXPIRE_MASK   0X00000002U
XQSPIPSU Interrupt Disable Register information
This register bits for disabling interrupts
#define XQSPIPSU_IDR_OFFSET   0X0000000CU
#define XQSPIPSU_IDR_RXEMPTY_SHIFT   11U
#define XQSPIPSU_IDR_RXEMPTY_WIDTH   1U
#define XQSPIPSU_IDR_RXEMPTY_MASK   0X00000800U
#define XQSPIPSU_IDR_GENFIFOFULL_SHIFT   10U
#define XQSPIPSU_IDR_GENFIFOFULL_WIDTH   1U
#define XQSPIPSU_IDR_GENFIFOFULL_MASK   0X00000400U
#define XQSPIPSU_IDR_GENFIFONOT_FULL_SHIFT   9U
#define XQSPIPSU_IDR_GENFIFONOT_FULL_WIDTH   1U
#define XQSPIPSU_IDR_GENFIFONOT_FULL_MASK   0X00000200U
#define XQSPIPSU_IDR_TXEMPTY_SHIFT   8U
#define XQSPIPSU_IDR_TXEMPTY_WIDTH   1U
#define XQSPIPSU_IDR_TXEMPTY_MASK   0X00000100U
#define XQSPIPSU_IDR_GENFIFOEMPTY_SHIFT   7U
#define XQSPIPSU_IDR_GENFIFOEMPTY_WIDTH   1U
#define XQSPIPSU_IDR_GENFIFOEMPTY_MASK   0X00000080U
#define XQSPIPSU_IDR_RXFULL_SHIFT   5U
#define XQSPIPSU_IDR_RXFULL_WIDTH   1U
#define XQSPIPSU_IDR_RXFULL_MASK   0X00000020U
#define XQSPIPSU_IDR_RXNEMPTY_SHIFT   4U
#define XQSPIPSU_IDR_RXNEMPTY_WIDTH   1U
#define XQSPIPSU_IDR_RXNEMPTY_MASK   0X00000010U
#define XQSPIPSU_IDR_TXFULL_SHIFT   3U
#define XQSPIPSU_IDR_TXFULL_WIDTH   1U
#define XQSPIPSU_IDR_TXFULL_MASK   0X00000008U
#define XQSPIPSU_IDR_TXNOT_FULL_SHIFT   2U
#define XQSPIPSU_IDR_TXNOT_FULL_WIDTH   1U
#define XQSPIPSU_IDR_TXNOT_FULL_MASK   0X00000004U
#define XQSPIPSU_IDR_POLL_TIME_EXPIRE_SHIFT   1U
#define XQSPIPSU_IDR_POLL_TIME_EXPIRE_WIDTH   1U
#define XQSPIPSU_IDR_POLL_TIME_EXPIRE_MASK   0X00000002U
#define XQSPIPSU_IDR_ALL_MASK   0X0FBEU
XQSPIPSU Interrupt Mask Register information
This register bits for masking interrupts
#define XQSPIPSU_IMR_OFFSET   0X00000010U
#define XQSPIPSU_IMR_RXEMPTY_SHIFT   11U
#define XQSPIPSU_IMR_RXEMPTY_WIDTH   1U
#define XQSPIPSU_IMR_RXEMPTY_MASK   0X00000800U
#define XQSPIPSU_IMR_GENFIFOFULL_SHIFT   10U
#define XQSPIPSU_IMR_GENFIFOFULL_WIDTH   1U
#define XQSPIPSU_IMR_GENFIFOFULL_MASK   0X00000400U
#define XQSPIPSU_IMR_GENFIFONOT_FULL_SHIFT   9U
#define XQSPIPSU_IMR_GENFIFONOT_FULL_WIDTH   1U
#define XQSPIPSU_IMR_GENFIFONOT_FULL_MASK   0X00000200U
#define XQSPIPSU_IMR_TXEMPTY_SHIFT   8U
#define XQSPIPSU_IMR_TXEMPTY_WIDTH   1U
#define XQSPIPSU_IMR_TXEMPTY_MASK   0X00000100U
#define XQSPIPSU_IMR_GENFIFOEMPTY_SHIFT   7U
#define XQSPIPSU_IMR_GENFIFOEMPTY_WIDTH   1U
#define XQSPIPSU_IMR_GENFIFOEMPTY_MASK   0X00000080U
#define XQSPIPSU_IMR_RXFULL_SHIFT   5U
#define XQSPIPSU_IMR_RXFULL_WIDTH   1U
#define XQSPIPSU_IMR_RXFULL_MASK   0X00000020U
#define XQSPIPSU_IMR_RXNEMPTY_SHIFT   4U
#define XQSPIPSU_IMR_RXNEMPTY_WIDTH   1U
#define XQSPIPSU_IMR_RXNEMPTY_MASK   0X00000010U
#define XQSPIPSU_IMR_TXFULL_SHIFT   3U
#define XQSPIPSU_IMR_TXFULL_WIDTH   1U
#define XQSPIPSU_IMR_TXFULL_MASK   0X00000008U
#define XQSPIPSU_IMR_TXNOT_FULL_SHIFT   2U
#define XQSPIPSU_IMR_TXNOT_FULL_WIDTH   1U
#define XQSPIPSU_IMR_TXNOT_FULL_MASK   0X00000004U
#define XQSPIPSU_IMR_POLL_TIME_EXPIRE_SHIFT   1U
#define XQSPIPSU_IMR_POLL_TIME_EXPIRE_WIDTH   1U
#define XQSPIPSU_IMR_POLL_TIME_EXPIRE_MASK   0X00000002U
XQSPIPSU Enable Register information
This register bits for enabling QSPI controller
#define XQSPIPSU_EN_OFFSET   0X00000014U
#define XQSPIPSU_EN_SHIFT   0U
#define XQSPIPSU_EN_WIDTH   1U
#define XQSPIPSU_EN_MASK   0X00000001U
XQSPIPSU TX Data Register information
This register bits for configuring TXFIFO
#define XQSPIPSU_TXD_OFFSET   0X0000001CU
#define XQSPIPSU_TXD_SHIFT   0U
#define XQSPIPSU_TXD_WIDTH   32U
#define XQSPIPSU_TXD_MASK   0XFFFFFFFFU
#define XQSPIPSU_TXD_DEPTH   64
XQSPIPSU RX Data Register information
This register bits for configuring RXFIFO
#define XQSPIPSU_RXD_OFFSET   0X00000020U
#define XQSPIPSU_RXD_SHIFT   0U
#define XQSPIPSU_RXD_WIDTH   32U
#define XQSPIPSU_RXD_MASK   0XFFFFFFFFU
XQSPIPSU TX/RX Threshold Register information
This register bits for configuring TX/RX Threshold
#define XQSPIPSU_TX_THRESHOLD_OFFSET   0X00000028U
#define XQSPIPSU_TX_FIFO_THRESHOLD_SHIFT   0U
#define XQSPIPSU_TX_FIFO_THRESHOLD_WIDTH   6U
#define XQSPIPSU_TX_FIFO_THRESHOLD_MASK   0X0000003FU
#define XQSPIPSU_TX_FIFO_THRESHOLD_RESET_VAL   0X01U
#define XQSPIPSU_RX_THRESHOLD_OFFSET   0X0000002CU
#define XQSPIPSU_RX_FIFO_THRESHOLD_SHIFT   0U
#define XQSPIPSU_RX_FIFO_THRESHOLD_WIDTH   6U
#define XQSPIPSU_RX_FIFO_THRESHOLD_MASK   0X0000003FU
#define XQSPIPSU_RX_FIFO_THRESHOLD_RESET_VAL   0X01U
#define XQSPIPSU_RXFIFO_THRESHOLD_OPT   32U
XQSPIPSU GPIO Register information
#define XQSPIPSU_GPIO_OFFSET   0X00000030U
#define XQSPIPSU_GPIO_WP_N_SHIFT   0U
#define XQSPIPSU_GPIO_WP_N_WIDTH   1U
#define XQSPIPSU_GPIO_WP_N_MASK   0X00000001U
XQSPIPSU Loopback Master Clock Delay Adjustment Register information
This register contains bits for configuring loopback
#define XQSPIPSU_LPBK_DLY_ADJ_OFFSET   0X00000038U
#define XQSPIPSU_LPBK_DLY_ADJ_USE_LPBK_SHIFT   5U
#define XQSPIPSU_LPBK_DLY_ADJ_USE_LPBK_WIDTH   1U
#define XQSPIPSU_LPBK_DLY_ADJ_USE_LPBK_MASK   0X00000020U
#define XQSPIPSU_LPBK_DLY_ADJ_DLY1_SHIFT   3U
#define XQSPIPSU_LPBK_DLY_ADJ_DLY1_WIDTH   2U
#define XQSPIPSU_LPBK_DLY_ADJ_DLY1_MASK   0X00000018U
#define XQSPIPSU_LPBK_DLY_ADJ_DLY0_SHIFT   0U
#define XQSPIPSU_LPBK_DLY_ADJ_DLY0_WIDTH   3U
#define XQSPIPSU_LPBK_DLY_ADJ_DLY0_MASK   0X00000007U
XQSPIPSU GEN_FIFO Register information
This register contains bits for configuring GENFIFO
#define XQSPIPSU_GEN_FIFO_OFFSET   0X00000040U
#define XQSPIPSU_GEN_FIFO_DATA_SHIFT   0U
#define XQSPIPSU_GEN_FIFO_DATA_WIDTH   20U
#define XQSPIPSU_GEN_FIFO_DATA_MASK   0X000FFFFFU
XQSPIPSU Select Register information
This register contains bits for selection GQSPI/LQSPI controller
#define XQSPIPSU_SEL_OFFSET   0X00000044U
#define XQSPIPSU_SEL_SHIFT   0U
#define XQSPIPSU_SEL_WIDTH   1U
#define XQSPIPSU_SEL_LQSPI_MASK   0X0U
#define XQSPIPSU_SEL_GQSPI_MASK   0X00000001U
XQSPIPSU FIFO Control Register information
This register contains bits for controlling TXFIFO and RXFIFO
#define XQSPIPSU_FIFO_CTRL_OFFSET   0X0000004CU
#define XQSPIPSU_FIFO_CTRL_RST_RX_FIFO_SHIFT   2U
#define XQSPIPSU_FIFO_CTRL_RST_RX_FIFO_WIDTH   1U
#define XQSPIPSU_FIFO_CTRL_RST_RX_FIFO_MASK   0X00000004U
#define XQSPIPSU_FIFO_CTRL_RST_TX_FIFO_SHIFT   1U
#define XQSPIPSU_FIFO_CTRL_RST_TX_FIFO_WIDTH   1U
#define XQSPIPSU_FIFO_CTRL_RST_TX_FIFO_MASK   0X00000002U
#define XQSPIPSU_FIFO_CTRL_RST_GEN_FIFO_SHIFT   0U
#define XQSPIPSU_FIFO_CTRL_RST_GEN_FIFO_WIDTH   1U
#define XQSPIPSU_FIFO_CTRL_RST_GEN_FIFO_MASK   0X00000001U
XQSPIPSU GENFIFO Threshold Register information
This register contains bits for configuring GENFIFO threshold
#define XQSPIPSU_GF_THRESHOLD_OFFSET   0X00000050U
#define XQSPIPSU_GEN_FIFO_THRESHOLD_SHIFT   0U
#define XQSPIPSU_GEN_FIFO_THRESHOLD_WIDTH   5U
#define XQSPIPSU_GEN_FIFO_THRESHOLD_MASK   0X0000001FU
#define XQSPIPSU_GEN_FIFO_THRESHOLD_RESET_VAL   0X10U
XQSPIPSU Poll configuration Register information
This register contains bits for configuring Poll feature
#define XQSPIPSU_POLL_CFG_OFFSET   0X00000054U
#define XQSPIPSU_POLL_CFG_EN_MASK_UPPER_SHIFT   31U
#define XQSPIPSU_POLL_CFG_EN_MASK_UPPER_WIDTH   1U
#define XQSPIPSU_POLL_CFG_EN_MASK_UPPER_MASK   0X80000000U
#define XQSPIPSU_POLL_CFG_EN_MASK_LOWER_SHIFT   30U
#define XQSPIPSU_POLL_CFG_EN_MASK_LOWER_WIDTH   1U
#define XQSPIPSU_POLL_CFG_EN_MASK_LOWER_MASK   0X40000000U
#define XQSPIPSU_POLL_CFG_MASK_EN_SHIFT   8U
#define XQSPIPSU_POLL_CFG_MASK_EN_WIDTH   8U
#define XQSPIPSU_POLL_CFG_MASK_EN_MASK   0X0000FF00U
#define XQSPIPSU_POLL_CFG_DATA_VALUE_SHIFT   0U
#define XQSPIPSU_POLL_CFG_DATA_VALUE_WIDTH   8U
#define XQSPIPSU_POLL_CFG_DATA_VALUE_MASK   0X000000FFU
#define XQSPIPSU_P_TO_OFFSET   0X00000058U
#define XQSPIPSU_P_TO_VALUE_SHIFT   0U
#define XQSPIPSU_P_TO_VALUE_WIDTH   32U
#define XQSPIPSU_P_TO_VALUE_MASK   0XFFFFFFFFU
XQSPIPSU Transfer Status Register information
This register contains bits for transfer status
#define XQSPIPSU_XFER_STS_OFFSET   0X0000005CU
#define XQSPIPSU_XFER_STS_PEND_BYTES_SHIFT   0U
#define XQSPIPSU_XFER_STS_PEND_BYTES_WIDTH   32U
#define XQSPIPSU_XFER_STS_PEND_BYTES_MASK   0XFFFFFFFFU
XQSPIPSU GEN_FIFO Snapshot Register information
#define XQSPIPSU_GF_SNAPSHOT_OFFSET   0X00000060U
#define XQSPIPSU_GF_SNAPSHOT_SHIFT   0U
#define XQSPIPSU_GF_SNAPSHOT_WIDTH   20U
#define XQSPIPSU_GF_SNAPSHOT_MASK   0X000FFFFFU
XQSPIPSU Receive Data Copy Register information
#define XQSPIPSU_RX_COPY_OFFSET   0X00000064U
#define XQSPIPSU_RX_COPY_UPPER_SHIFT   8U
#define XQSPIPSU_RX_COPY_UPPER_WIDTH   8U
#define XQSPIPSU_RX_COPY_UPPER_MASK   0X0000FF00U
#define XQSPIPSU_RX_COPY_LOWER_SHIFT   0U
#define XQSPIPSU_RX_COPY_LOWER_WIDTH   8U
#define XQSPIPSU_RX_COPY_LOWER_MASK   0X000000FFU
XQSPIPSU Module Identification Register information
#define XQSPIPSU_MOD_ID_OFFSET   0X000000FCU
#define XQSPIPSU_MOD_ID_SHIFT   0U
#define XQSPIPSU_MOD_ID_WIDTH   32U
#define XQSPIPSU_MOD_ID_MASK   0XFFFFFFFFU
XQSPIPSU DMA Transfer Register information
This register contains bits for configuring DMA
#define XQSPIPSU_QSPIDMA_DST_ADDR_OFFSET   0X00000700U
#define XQSPIPSU_QSPIDMA_DST_ADDR_SHIFT   2U
#define XQSPIPSU_QSPIDMA_DST_ADDR_WIDTH   30U
#define XQSPIPSU_QSPIDMA_DST_ADDR_MASK   0XFFFFFFFCU
#define XQSPIPSU_QSPIDMA_DST_SIZE_OFFSET   0X00000704U
#define XQSPIPSU_QSPIDMA_DST_SIZE_SHIFT   2U
#define XQSPIPSU_QSPIDMA_DST_SIZE_WIDTH   27U
#define XQSPIPSU_QSPIDMA_DST_SIZE_MASK   0X1FFFFFFCU
#define XQSPIPSU_QSPIDMA_DST_STS_OFFSET   0X00000708U
#define XQSPIPSU_QSPIDMA_DST_STS_DONE_CNT_SHIFT   13U
#define XQSPIPSU_QSPIDMA_DST_STS_DONE_CNT_WIDTH   3U
#define XQSPIPSU_QSPIDMA_DST_STS_DONE_CNT_MASK   0X0000E000U
#define XQSPIPSU_QSPIDMA_DST_STS_DST_FIFO_LEVEL_SHIFT   5U
#define XQSPIPSU_QSPIDMA_DST_STS_DST_FIFO_LEVEL_WIDTH   8U
#define XQSPIPSU_QSPIDMA_DST_STS_DST_FIFO_LEVEL_MASK   0X00001FE0U
#define XQSPIPSU_QSPIDMA_DST_STS_WR_OUTSTANDING_SHIFT   1U
#define XQSPIPSU_QSPIDMA_DST_STS_WR_OUTSTANDING_WIDTH   4U
#define XQSPIPSU_QSPIDMA_DST_STS_WR_OUTSTANDING_MASK   0X0000001EU
#define XQSPIPSU_QSPIDMA_DST_STS_BUSY_SHIFT   0U
#define XQSPIPSU_QSPIDMA_DST_STS_BUSY_WIDTH   1U
#define XQSPIPSU_QSPIDMA_DST_STS_BUSY_MASK   0X00000001U
#define XQSPIPSU_QSPIDMA_DST_STS_WTC   0xE000U
#define XQSPIPSU_QSPIDMA_DST_CTRL_OFFSET   0X0000070CU
#define XQSPIPSU_QSPIDMA_DST_CTRL_FIFO_LVL_HIT_THRESHOLD_SHIFT   25U
#define XQSPIPSU_QSPIDMA_DST_CTRL_FIFO_LVL_HIT_THRESHOLD_WIDTH   7U
#define XQSPIPSU_QSPIDMA_DST_CTRL_FIFO_LVL_HIT_THRESHOLD_MASK   0XFE000000U
#define XQSPIPSU_QSPIDMA_DST_CTRL_APB_ERR_RESP_SHIFT   24U
#define XQSPIPSU_QSPIDMA_DST_CTRL_APB_ERR_RESP_WIDTH   1U
#define XQSPIPSU_QSPIDMA_DST_CTRL_APB_ERR_RESP_MASK   0X01000000U
#define XQSPIPSU_QSPIDMA_DST_CTRL_ENDIAN_SHIFT   23U
#define XQSPIPSU_QSPIDMA_DST_CTRL_ENDIAN_WIDTH   1U
#define XQSPIPSU_QSPIDMA_DST_CTRL_ENDIAN_MASK   0X00800000U
#define XQSPIPSU_QSPIDMA_DST_CTRL_AXI_BRST_TYPE_SHIFT   22U
#define XQSPIPSU_QSPIDMA_DST_CTRL_AXI_BRST_TYPE_WIDTH   1U
#define XQSPIPSU_QSPIDMA_DST_CTRL_AXI_BRST_TYPE_MASK   0X00400000U
#define XQSPIPSU_QSPIDMA_DST_CTRL_TO_VAL_SHIFT   10U
#define XQSPIPSU_QSPIDMA_DST_CTRL_TO_VAL_WIDTH   12U
#define XQSPIPSU_QSPIDMA_DST_CTRL_TO_VAL_MASK   0X003FFC00U
#define XQSPIPSU_QSPIDMA_DST_CTRL_FIFO_THRESHOLD_SHIFT   2U
#define XQSPIPSU_QSPIDMA_DST_CTRL_FIFO_THRESHOLD_WIDTH   8U
#define XQSPIPSU_QSPIDMA_DST_CTRL_FIFO_THRESHOLD_MASK   0X000003FCU
#define XQSPIPSU_QSPIDMA_DST_CTRL_PAUSE_STRM_SHIFT   1U
#define XQSPIPSU_QSPIDMA_DST_CTRL_PAUSE_STRM_WIDTH   1U
#define XQSPIPSU_QSPIDMA_DST_CTRL_PAUSE_STRM_MASK   0X00000002U
#define XQSPIPSU_QSPIDMA_DST_CTRL_PAUSE_MEM_SHIFT   0U
#define XQSPIPSU_QSPIDMA_DST_CTRL_PAUSE_MEM_WIDTH   1U
#define XQSPIPSU_QSPIDMA_DST_CTRL_PAUSE_MEM_MASK   0X00000001U
#define XQSPIPSU_QSPIDMA_DST_CTRL_RESET_VAL   0x403FFA00U
#define XQSPIPSU_QSPIDMA_DST_I_STS_OFFSET   0X00000714U
#define XQSPIPSU_QSPIDMA_DST_I_STS_FIFO_OF_SHIFT   7U
#define XQSPIPSU_QSPIDMA_DST_I_STS_FIFO_OF_WIDTH   1U
#define XQSPIPSU_QSPIDMA_DST_I_STS_FIFO_OF_MASK   0X00000080U
#define XQSPIPSU_QSPIDMA_DST_I_STS_INVALID_APB_SHIFT   6U
#define XQSPIPSU_QSPIDMA_DST_I_STS_INVALID_APB_WIDTH   1U
#define XQSPIPSU_QSPIDMA_DST_I_STS_INVALID_APB_MASK   0X00000040U
#define XQSPIPSU_QSPIDMA_DST_I_STS_THRESHOLD_HIT_SHIFT   5U
#define XQSPIPSU_QSPIDMA_DST_I_STS_THRESHOLD_HIT_WIDTH   1U
#define XQSPIPSU_QSPIDMA_DST_I_STS_THRESHOLD_HIT_MASK   0X00000020U
#define XQSPIPSU_QSPIDMA_DST_I_STS_TO_MEM_SHIFT   4U
#define XQSPIPSU_QSPIDMA_DST_I_STS_TO_MEM_WIDTH   1U
#define XQSPIPSU_QSPIDMA_DST_I_STS_TO_MEM_MASK   0X00000010U
#define XQSPIPSU_QSPIDMA_DST_I_STS_TO_STRM_SHIFT   3U
#define XQSPIPSU_QSPIDMA_DST_I_STS_TO_STRM_WIDTH   1U
#define XQSPIPSU_QSPIDMA_DST_I_STS_TO_STRM_MASK   0X00000008U
#define XQSPIPSU_QSPIDMA_DST_I_STS_AXI_BRESP_ERR_SHIFT   2U
#define XQSPIPSU_QSPIDMA_DST_I_STS_AXI_BRESP_ERR_WIDTH   1U
#define XQSPIPSU_QSPIDMA_DST_I_STS_AXI_BRESP_ERR_MASK   0X00000004U
#define XQSPIPSU_QSPIDMA_DST_I_STS_DONE_SHIFT   1U
#define XQSPIPSU_QSPIDMA_DST_I_STS_DONE_WIDTH   1U
#define XQSPIPSU_QSPIDMA_DST_I_STS_DONE_MASK   0X00000002U
#define XQSPIPSU_QSPIDMA_DST_INTR_ERR_MASK   0X000000FCU
#define XQSPIPSU_QSPIDMA_DST_INTR_ALL_MASK   0X000000FEU
#define XQSPIPSU_QSPIDMA_DST_I_EN_OFFSET   0X00000718U
#define XQSPIPSU_QSPIDMA_DST_I_EN_FIFO_OF_SHIFT   7U
#define XQSPIPSU_QSPIDMA_DST_I_EN_FIFO_OF_WIDTH   1U
#define XQSPIPSU_QSPIDMA_DST_I_EN_FIFO_OF_MASK   0X00000080U
#define XQSPIPSU_QSPIDMA_DST_I_EN_INVALID_APB_SHIFT   6U
#define XQSPIPSU_QSPIDMA_DST_I_EN_INVALID_APB_WIDTH   1U
#define XQSPIPSU_QSPIDMA_DST_I_EN_INVALID_APB_MASK   0X00000040U
#define XQSPIPSU_QSPIDMA_DST_I_EN_THRESHOLD_HIT_SHIFT   5U
#define XQSPIPSU_QSPIDMA_DST_I_EN_THRESHOLD_HIT_WIDTH   1U
#define XQSPIPSU_QSPIDMA_DST_I_EN_THRESHOLD_HIT_MASK   0X00000020U
#define XQSPIPSU_QSPIDMA_DST_I_EN_TO_MEM_SHIFT   4U
#define XQSPIPSU_QSPIDMA_DST_I_EN_TO_MEM_WIDTH   1U
#define XQSPIPSU_QSPIDMA_DST_I_EN_TO_MEM_MASK   0X00000010U
#define XQSPIPSU_QSPIDMA_DST_I_EN_TO_STRM_SHIFT   3U
#define XQSPIPSU_QSPIDMA_DST_I_EN_TO_STRM_WIDTH   1U
#define XQSPIPSU_QSPIDMA_DST_I_EN_TO_STRM_MASK   0X00000008U
#define XQSPIPSU_QSPIDMA_DST_I_EN_AXI_BRESP_ERR_SHIFT   2U
#define XQSPIPSU_QSPIDMA_DST_I_EN_AXI_BRESP_ERR_WIDTH   1U
#define XQSPIPSU_QSPIDMA_DST_I_EN_AXI_BRESP_ERR_MASK   0X00000004U
#define XQSPIPSU_QSPIDMA_DST_I_EN_DONE_SHIFT   1U
#define XQSPIPSU_QSPIDMA_DST_I_EN_DONE_WIDTH   1U
#define XQSPIPSU_QSPIDMA_DST_I_EN_DONE_MASK   0X00000002U
#define XQSPIPSU_QSPIDMA_DST_I_DIS_OFFSET   0X0000071CU
#define XQSPIPSU_QSPIDMA_DST_I_DIS_FIFO_OF_SHIFT   7U
#define XQSPIPSU_QSPIDMA_DST_I_DIS_FIFO_OF_WIDTH   1U
#define XQSPIPSU_QSPIDMA_DST_I_DIS_FIFO_OF_MASK   0X00000080U
#define XQSPIPSU_QSPIDMA_DST_I_DIS_INVALID_APB_SHIFT   6U
#define XQSPIPSU_QSPIDMA_DST_I_DIS_INVALID_APB_WIDTH   1U
#define XQSPIPSU_QSPIDMA_DST_I_DIS_INVALID_APB_MASK   0X00000040U
#define XQSPIPSU_QSPIDMA_DST_I_DIS_THRESHOLD_HIT_SHIFT   5U
#define XQSPIPSU_QSPIDMA_DST_I_DIS_THRESHOLD_HIT_WIDTH   1U
#define XQSPIPSU_QSPIDMA_DST_I_DIS_THRESHOLD_HIT_MASK   0X00000020U
#define XQSPIPSU_QSPIDMA_DST_I_DIS_TO_MEM_SHIFT   4U
#define XQSPIPSU_QSPIDMA_DST_I_DIS_TO_MEM_WIDTH   1U
#define XQSPIPSU_QSPIDMA_DST_I_DIS_TO_MEM_MASK   0X00000010U
#define XQSPIPSU_QSPIDMA_DST_I_DIS_TO_STRM_SHIFT   3U
#define XQSPIPSU_QSPIDMA_DST_I_DIS_TO_STRM_WIDTH   1U
#define XQSPIPSU_QSPIDMA_DST_I_DIS_TO_STRM_MASK   0X00000008U
#define XQSPIPSU_QSPIDMA_DST_I_DIS_AXI_BRESP_ERR_SHIFT   2U
#define XQSPIPSU_QSPIDMA_DST_I_DIS_AXI_BRESP_ERR_WIDTH   1U
#define XQSPIPSU_QSPIDMA_DST_I_DIS_AXI_BRESP_ERR_MASK   0X00000004U
#define XQSPIPSU_QSPIDMA_DST_I_DIS_DONE_SHIFT   1U
#define XQSPIPSU_QSPIDMA_DST_I_DIS_DONE_WIDTH   1U
#define XQSPIPSU_QSPIDMA_DST_I_DIS_DONE_MASK   0X00000002U
#define XQSPIPSU_QSPIDMA_DST_IMR_OFFSET   0X00000720U
#define XQSPIPSU_QSPIDMA_DST_IMR_FIFO_OF_SHIFT   7U
#define XQSPIPSU_QSPIDMA_DST_IMR_FIFO_OF_WIDTH   1U
#define XQSPIPSU_QSPIDMA_DST_IMR_FIFO_OF_MASK   0X00000080U
#define XQSPIPSU_QSPIDMA_DST_IMR_INVALID_APB_SHIFT   6U
#define XQSPIPSU_QSPIDMA_DST_IMR_INVALID_APB_WIDTH   1U
#define XQSPIPSU_QSPIDMA_DST_IMR_INVALID_APB_MASK   0X00000040U
#define XQSPIPSU_QSPIDMA_DST_IMR_THRESHOLD_HIT_SHIFT   5U
#define XQSPIPSU_QSPIDMA_DST_IMR_THRESHOLD_HIT_WIDTH   1U
#define XQSPIPSU_QSPIDMA_DST_IMR_THRESHOLD_HIT_MASK   0X00000020U
#define XQSPIPSU_QSPIDMA_DST_IMR_TO_MEM_SHIFT   4U
#define XQSPIPSU_QSPIDMA_DST_IMR_TO_MEM_WIDTH   1U
#define XQSPIPSU_QSPIDMA_DST_IMR_TO_MEM_MASK   0X00000010U
#define XQSPIPSU_QSPIDMA_DST_IMR_TO_STRM_SHIFT   3U
#define XQSPIPSU_QSPIDMA_DST_IMR_TO_STRM_WIDTH   1U
#define XQSPIPSU_QSPIDMA_DST_IMR_TO_STRM_MASK   0X00000008U
#define XQSPIPSU_QSPIDMA_DST_IMR_AXI_BRESP_ERR_SHIFT   2U
#define XQSPIPSU_QSPIDMA_DST_IMR_AXI_BRESP_ERR_WIDTH   1U
#define XQSPIPSU_QSPIDMA_DST_IMR_AXI_BRESP_ERR_MASK   0X00000004U
#define XQSPIPSU_QSPIDMA_DST_IMR_DONE_SHIFT   1U
#define XQSPIPSU_QSPIDMA_DST_IMR_DONE_WIDTH   1U
#define XQSPIPSU_QSPIDMA_DST_IMR_DONE_MASK   0X00000002U
#define XQSPIPSU_QSPIDMA_DST_CTRL2_OFFSET   0X00000724U
#define XQSPIPSU_QSPIDMA_DST_CTRL2_RAM_EMASA_SHIFT   27U
#define XQSPIPSU_QSPIDMA_DST_CTRL2_RAM_EMASA_WIDTH   1U
#define XQSPIPSU_QSPIDMA_DST_CTRL2_RAM_EMASA_MASK   0X08000000U
#define XQSPIPSU_QSPIDMA_DST_CTRL2_AWCACHE_SHIFT   24U
#define XQSPIPSU_QSPIDMA_DST_CTRL2_AWCACHE_WIDTH   3U
#define XQSPIPSU_QSPIDMA_DST_CTRL2_AWCACHE_MASK   0X07000000U
#define XQSPIPSU_QSPIDMA_DST_CTRL2_TO_EN_SHIFT   22U
#define XQSPIPSU_QSPIDMA_DST_CTRL2_TO_EN_WIDTH   1U
#define XQSPIPSU_QSPIDMA_DST_CTRL2_TO_EN_MASK   0X00400000U
#define XQSPIPSU_QSPIDMA_DST_CTRL2_RAM_EMAB_SHIFT   19U
#define XQSPIPSU_QSPIDMA_DST_CTRL2_RAM_EMAB_WIDTH   3U
#define XQSPIPSU_QSPIDMA_DST_CTRL2_RAM_EMAB_MASK   0X00380000U
#define XQSPIPSU_QSPIDMA_DST_CTRL2_RAM_EMAA_SHIFT   16U
#define XQSPIPSU_QSPIDMA_DST_CTRL2_RAM_EMAA_WIDTH   3U
#define XQSPIPSU_QSPIDMA_DST_CTRL2_RAM_EMAA_MASK   0X00070000U
#define XQSPIPSU_QSPIDMA_DST_CTRL2_TO_PRE_SHIFT   4U
#define XQSPIPSU_QSPIDMA_DST_CTRL2_TO_PRE_WIDTH   12U
#define XQSPIPSU_QSPIDMA_DST_CTRL2_TO_PRE_MASK   0X0000FFF0U
#define XQSPIPSU_QSPIDMA_DST_CTRL2_MAX_OUTS_CMDS_SHIFT   0U
#define XQSPIPSU_QSPIDMA_DST_CTRL2_MAX_OUTS_CMDS_WIDTH   4U
#define XQSPIPSU_QSPIDMA_DST_CTRL2_MAX_OUTS_CMDS_MASK   0X0000000FU
#define XQSPIPSU_QSPIDMA_DST_ADDR_MSB_OFFSET   0X00000728U
#define XQSPIPSU_QSPIDMA_DST_ADDR_MSB_SHIFT   0U
#define XQSPIPSU_QSPIDMA_DST_ADDR_MSB_WIDTH   12U
#define XQSPIPSU_QSPIDMA_DST_ADDR_MSB_MASK   0X00000FFFU
#define XQSPIPSU_QSPIDMA_FUTURE_ECO_OFFSET   0X00000EFCU
#define XQSPIPSU_QSPIDMA_FUTURE_ECO_VAL_SHIFT   0U
#define XQSPIPSU_QSPIDMA_FUTURE_ECO_VAL_WIDTH   32U
#define XQSPIPSU_QSPIDMA_FUTURE_ECO_VAL_MASK   0XFFFFFFFFU
XQSPIPSU Generic FIFO masks information
#define XQSPIPSU_GENFIFO_IMM_DATA_MASK   0xFFU
#define XQSPIPSU_GENFIFO_DATA_XFER   0x100U
#define XQSPIPSU_GENFIFO_EXP   0x200U
#define XQSPIPSU_GENFIFO_MODE_SPI   0x400U
#define XQSPIPSU_GENFIFO_MODE_DUALSPI   0x800U
#define XQSPIPSU_GENFIFO_MODE_QUADSPI   0xC00U
#define XQSPIPSU_GENFIFO_MODE_MASK   0xC00U /* And with ~MASK first */
#define XQSPIPSU_GENFIFO_CS_LOWER   0x1000U
#define XQSPIPSU_GENFIFO_CS_UPPER   0x2000U
#define XQSPIPSU_GENFIFO_BUS_LOWER   0x4000U
#define XQSPIPSU_GENFIFO_BUS_UPPER   0x8000U
#define XQSPIPSU_GENFIFO_BUS_BOTH   0xC000U /* inverse is no bus */
#define XQSPIPSU_GENFIFO_BUS_MASK   0xC000U /* And with ~MASK first */
#define XQSPIPSU_GENFIFO_TX   0x10000U /* inverse is zero pump */
#define XQSPIPSU_GENFIFO_RX   0x20000U /* inverse is RX discard */
#define XQSPIPSU_GENFIFO_STRIPE   0x40000U
#define XQSPIPSU_GENFIFO_POLL   0x80000U
XQSPIPSU RX Data Delay Register information
#define XQSPIPSU_DATA_DLY_ADJ_OFFSET   0X000000F8U
#define XQSPIPSU_DATA_DLY_ADJ_USE_DATA_DLY_SHIFT   31U
#define XQSPIPSU_DATA_DLY_ADJ_USE_DATA_DLY_WIDTH   1U
#define XQSPIPSU_DATA_DLY_ADJ_USE_DATA_DLY_MASK   0X80000000U
#define XQSPIPSU_DATA_DLY_ADJ_DLY_SHIFT   28U
#define XQSPIPSU_DATA_DLY_ADJ_DLY_WIDTH   3U
#define XQSPIPSU_DATA_DLY_ADJ_DLY_MASK   0X70000000U
TAPDLY Bypass register information
#define IOU_TAPDLY_BYPASS_OFFSET   0X00000390U
#define IOU_TAPDLY_BYPASS_LQSPI_RX_SHIFT   0X02U
#define IOU_TAPDLY_BYPASS_LQSPI_RX_WIDTH   0X01U
#define IOU_TAPDLY_BYPASS_LQSPI_RX_MASK   0x00000004U
#define IOU_TAPDLY_RESET_STATE   0x7U
This file implements a driver to support Arasan NAND controller present in Zynq Ultrascale Mp.
Driver Initialization
The function call XNandPsu_CfgInitialize() should be called by the application before any other function in the driver. The initialization function takes device specific data (like device id, instance id, and base address) and initializes the XNandPsu instance with the device specific data.
Device Geometry
NAND flash device is memory device and it is segmented into areas called Logical Unit(s) (LUN) and further in to blocks and pages. A NAND flash device can have multiple LUN. LUN is sequential raw of multiple blocks of the same size. A block is the smallest erasable unit of data within the Flash array of a LUN. The size of each block is based on a power of 2. There is no restriction on the number of blocks within the LUN. A block contains a number of pages. A page is the smallest addressable unit for read and program operations. The arrangement of LUN, blocks, and pages is referred to by this module as the part's geometry.
The cells within the part can be programmed from a logic 1 to a logic 0 and not the other way around. To change a cell back to a logic 1, the entire block containing that cell must be erased. When a block is erased all bytes contain the value 0xFF. The number of times a block can be erased is finite. Eventually the block will wear out and will no longer be capable of erasure. As of this writing, the typical flash block can be erased 100,000 or more times.
The jobs done by this driver typically are:
Write Operation
The write call can be used to write a minimum of one byte and a maximum entire flash. If the address offset specified to write is out of flash or if the number of bytes specified from the offset exceed flash boundaries an error is reported back to the user. The write is blocking in nature in that the control is returned back to user only after the write operation is completed successfully or an error is reported.
Read Operation
The read call can be used to read a minimum of one byte and maximum of entire flash. If the address offset specified to read is out of flash or if the number of bytes specified from the offset exceed flash boundaries an error is reported back to the user. The read is blocking in nature in that the control is returned back to user only after the read operation is completed successfully or an error is reported.
Erase Operation
The erase operations are provided to erase a Block in the Flash memory. The erase call is blocking in nature in that the control is returned back to user only after the erase operation is completed successfully or an error is reported.
Note
Driver has been renamed to nandpsu after change in naming convention.
This driver is intended to be RTOS and processor independent. It works with physical addresses only. Any needs for dynamic memory management, threads, mutual exclusion, virtual memory, cache control, or HW write protection management must be satisfied by the layer above this driver.
  MODIFICATION HISTORY:
  Ver   Who    Date    Changes
  1.0   nm     05/06/2014  First release
  2.0   sb     01/12/2015  Removed Null checks for Buffer passed
               as parameter to Read API's
This file implements the Bad Block Management(BBM) functionality. This is
similar to the Bad Block Management which is a part of the MTD subsystem in
Linux.  The factory marked bad blocks are scanned initially and a Bad Block
Table(BBT) is created in the memory.  This table is also written to the flash
so that upon reboot, the BBT is read back from the flash and loaded into the
memory instead of scanning every time. The Bad Block Table(BBT) is written
into one of the the last four blocks in the flash memory. The last four
blocks are marked as Reserved so that user can't erase/program those blocks.
There are two bad block tables, a primary table and a mirror table. The
tables are versioned and incrementing version number is used to detect and
recover from interrupted updates. Each table is stored in a separate block,
beginning in the first page of that block. Only two blocks would be necessary
in the absence of bad blocks within the last four; the range of four provides
a little slack in case one or two of those blocks is bad. These blocks are
marked as reserved and cannot be programmed by the user. A NAND Flash device
with 3 or more factory bad blocks in the last 4 cannot be used. The bad block
table signature is written into the spare data area of the pages containing
bad block table so that upon rebooting the bad block table signature is
searched and the bad block table is loaded into RAM. The signature is "Bbt0"
for primary Bad Block Table and "1tbB" for Mirror Bad Block Table. The
version offset follows the signature offset in the spare data area. The
version number increments on every update to the bad block table and the
version wraps at 0xff.
Each block in the Bad Block Table(BBT) is represented by 2 bits.
The two bits are encoded as follows in RAM BBT.
0'b00 -> Good Block
0'b01 -> Block is bad due to wear
0'b10 -> Reserved block
0'b11 -> Factory marked bad block
While writing to the flash the two bits are encoded as follows.
0'b00 -> Factory marked bad block
0'b01 -> Reserved block
0'b10 -> Block is bad due to wear
0'b11 -> Good Block
The user can check for the validity of the block using the API
XNandPsu_IsBlockBad and take the action based on the return value. Also user
can update the bad block table using XNandPsu_MarkBlockBad API.
Note
None
2.0   sb     01/12/2015  Added support for writing BBT signature and version
           in page section by enabling XNANDPSU_BBT_NO_OOB.
           Modified Bbt Signature and Version Offset value for
           Oob and No-Oob region.
This file contains identifiers and low-level macros/functions for the Arasan
NAND flash controller driver.
See xnandpsu.h for more information.
Note
None
1.0   nm     05/06/2014  First Release
2.0   sb     11/04/2014  Changed XNANDPSU_ECC_SLC_MLC_MASK to
           XNANDPSU_ECC_HAMMING_BCH_MASK.
1.7 akm    09/03/20    Updated the Makefile to support parallel make
               execution.
This file defines all the ONFI 3.1 specific commands and values.
Note
None
1.4 nsk    04/10/2018  Added ICCARM compiler support.
This section explains the implementation the functions required to use the
QSPIPSU hardware to perform a transfer. These are accessible to the user
via xqspipsu.h.
Generic QSPI interface allows for communication to any QSPI slave device.
GQSPI contains a GENFIFO into which the bus transfers required are to be
pushed with appropriate configuration. The controller provides TX and RX
FIFO's and a DMA to be used for RX transfers. The controller executes each
GENFIFO entry noting the configuration and places data on the bus as required
The different options in GENFIFO are as follows:
GENFIFO has manual and auto start options.
All DMA requests need a 4-byte aligned destination address buffer and
size of transfer should also be a multiple of 4.
This driver supports DMA RX and IO RX.
Initialization & Configuration
This driver uses the GQSPI controller with RX DMA. It supports both
interrupt and polled transfers. Manual start of GENFIFO is used.
XQspiPsu_CfgInitialize() initializes the instance variables.
Additional setting can be done using SetOptions/ClearOptions functions
and SelectSlave function.
Transfer
Polled or Interrupt transfers can be done. The transfer function needs the
message(s) to be transmitted in the form of an array of type XQspiPsu_Msg.
This is supposed to contain the byte count and any TX/RX buffers as required.
Flags can be used indicate further information such as whether the message
should be striped. The transfer functions form and write GENFIFO entries,
check the status of the transfer and report back to the application
when done.
1.0   hk  08/21/14 First release
      sk  03/13/15 Added IO mode support.
      hk  03/18/15 Switch to I/O mode before clearing RX FIFO.
                   Clear and disable DMA interrupts/status in abort.
                   Use DMA DONE bit instead of BUSY as recommended.
      sk  04/24/15 Modified the code according to MISRAC-2012.
      sk  06/17/15 Removed NULL checks for Rx/Tx buffers. As
                   writing/reading from 0x0 location is permitted.
1.1   sk  04/12/16 Added debug message prints.
1.2 nsk 07/01/16 Added LQSPI support
                 Modified XQspiPsu_Select() macro in xqspipsu.h
                 Added XQspiPsu_GetLqspiConfigReg() in xqspipsu.h
                 Added required macros in xqspipsu_hw.h
                 Modified XQspiPsu_SetOptions() to support
                 LQSPI options and updated OptionsTable in
                 xqspipsu_options.c
      rk  07/15/16 Added support for TapDelays at different frequencies.
    nsk 08/05/16 Added example support PollData and PollTimeout
                 Added  XQSPIPSU_MSG_FLAG_POLL macro in xqspipsu.h
                 Added XQspiPsu_Create_PollConfigData and
                 XQspiPsu_PollData() functions in xqspipsu.c
1.3 nsk 09/16/16 Update PollData and Polltimeout support for dual parallel
                 configuration. Updated XQspiPsu_PollData() and
                 XQspiPsu_Create_PollConfigData() functions in xqspipsu.c
                   and also modified the polldata example
      ms  03/17/17 Added readme.txt file in examples folder for doxygen
                   generation.
      ms  04/05/17 Modified Comment lines in functions of qspipsu
                   examples to recognize it as documentation block
                   and modified filename tag to include them in
                   doxygen examples.
1.4 tjs 05/26/17 Added support for accessing upper DDR (0x800000000)
                 while booting images from QSPI
1.5 tjs 08/08/17 Added index.html file for importing examples
                 from system.mss
1.5 nsk 08/14/17 Added CCI support
1.5 tjs 09/14/17 Modified the checks for 4 byte addressing and commands.
1.6 tjs 10/16/17 Flow for accessing flash is made similar to u-boot
                 and linux For CR-984966
1.6   tjs 11/02/17 Resolved the compilation errors for ICCARM. CR-988625
1.7   tjs 11/16/17 Removed the unsupported 4 Byte write and sector erase
                   commands.
1.7 tjs 12/01/17 Added support for MT25QL02G Flash from Micron. CR-990642
1.7 tjs 12/19/17 Added support for S25FL064L from Spansion. CR-990724
1.7 tjs 01/11/18 Added support for MX66L1G45G flash from Macronix CR-992367
1.7 tjs 01/16/18 Removed the check for DMA MSB to be written. (CR#992560)
1.7 tjs 01/17/18 Added support to toggle the WP pin of flash. (PR#2448)
                   Added XQspiPsu_SetWP() in xqspipsu_options.c
                   Added XQspiPsu_WriteProtectToggle() in xqspipsu.c and
                   also added write protect example.
1.7 tjs 03/14/18 Added support in EL1 NS mode (CR#974882)
1.7 tjs 26/03/18 In dual parallel mode enable both CS when issuing Write
                    enable command. CR-998478
1.8 tjs 05/02/18 Added support for IS25LP064 and IS25WP064.
1.8 tjs 06/26/18 Added an example for accessing 64bit dma within
                 32 bit application. CR#1004701
1.8 tjs 06/26/18 Removed checkpatch warnings
1.8 tjs 07/09/19 Fixed cppcheck, doxygen and gcc warnings.
1.8 tjs 07/18/18 Setup64BRxDma() should be called only if the RxAddress is
                 greater than 32 bit address space. (CR#1006862)
1.8 tjs 07/18/18 Added support for the low density ISSI flash parts.
1.8 tjs 09/06/18 Fixed the code in XQspiPsu_GenFifoEntryData() for data
                 transfer length up to 255 for reducing the extra loop.
1.9 tjs 11/22/17 Added the check for A72 and R5 processors (CR-987075)
1.9 tjs 04/17/18 Updated register addresses as per the latest revision
        of versal (CR#999610)
1.9  aru 01/17/19 Fixed the violations for  MISRAC-2012
                 in safety mode .Done changes such as added U suffix,
                 Declared pointer param as const.
1.9  nsk 02/01/19 Clear DMA_DST_ADDR_MSB register on 32bit machine, if the
         address is of only 32bit (CR#1020031)
1.9  nsk 02/01/19 Added QSPI idling support
1.9 akm 03/08/19 Set recommended clock and data tap delay values for 40MHZ,
                 100MHZ and 150MHZ frequencies(CR#1023187)
1.9  nsk 03/27/19 Update 64bit dma support
         (CR#1018102).
1.9  akm 04/03/19 Fixed data alignment warnings on IAR compiler.
1.9  akm 04/03/19 Fixed compilation error in XQspiPsu_LqspiRead()
                    function on IAR compiler.
1.10 sk  08/20/19 Fixed issues in poll timeout feature.
1.10 akm 08/22/19 Set recommended tap delay values for 37.5MHZ, 100MHZ and
         150MHZ frequencies in Versal.
1.10 akm 09/05/19 Added Multi Die Erase and Muti Die Read support.
1.11 akm 11/07/19 Removed LQSPI register access in Versal.
1.11    akm 11/15/19 Fixed Coverity deadcode warning in
                XQspipsu_Calculate_Tapdelay().
1.11 akm 02/19/20 Added XQspiPsu_StartDmaTransfer() and XQspiPsu_CheckDmaDone()
             APIs for non-blocking transfer.
1.11 sd  01/02/20 Added clocking support
1.11 akm 03/09/20 Reorganize the source code, enable qspi controller and
         interrupts in XQspiPsu_CfgInitialize() API.
1.11 akm 03/26/20 Fixed issue by updating XQspiPsu_CfgInitialize to return
         XST_DEVICE_IS_STARTED instead of asserting, when the
         instance is already configured(CR#1058525).
1.12    akm 09/02/20 Updated the Makefile to support parallel make execution.
1.13 akm 01/04/21 Fix MISRA-C violations.
1.13 sne 04/23/21 Fixed doxygen warnings.
1.14 akm 06/24/21 Allow enough time for the controller to reset the FIFOs.
1.14 akm 08/12/21 Perform Dcache invalidate at the end of the DMA transfer.
This is the header file for the implementation of QSPIPSU driver.
1.11   akm  03/09/20 First release
1.15   akm  03/03/22 Enable tapdelay settings for applications on
             Microblaze platform.
This file contains low level access functions using the base address
directly without an instance.
      hk  03/18/15 Add DMA status register masks required.
1.2 nsk 07/01/16 Added LQSPI supported Masks
1.7 tjs 03/14/18 Added support in EL1 NS mode.
1.15    akm 12/02/21 Fix Doxygen warnings.
This file contains the implementation of the interface functions for
XNandPsu driver. Refer to the header file xnandpsu.h for more detailed
information.
This module supports for NAND flash memory devices that conform to the
"Open NAND Flash Interface" (ONFI) 3.0 Specification. This modules
implements basic flash operations like read, write and erase.
Note
  • XNandPsu_Read()
  • XNandPsu_ReadPage Modified
  • XNandPsu_SetFeature()
  • XNandPsu_GetFeature() and made them public. Removed Failure Return for BCF Error check in XNandPsu_ReadPage() and added BCH_Error counter in the instance pointer structure. Added XNandPsu_Prepare_Cmd API Replaced
  • XNandPsu_IntrStsEnable
  • XNandPsu_IntrStsClear
  • XNandPsu_IntrClear
  • XNandPsu_SetProgramReg with XNandPsu_WriteReg call Modified xnandpsu.c file API's with above changes. Corrected the program command for Set Feature API. Modified
  • XNandPsu_OnfiReadStatus
  • XNandPsu_SetFeature to add support for DDR mode. Changed Convention for SLC/MLC SLC --> HAMMING MLC --> BCH SlcMlc --> IsBCH Removed extra DMA mode initialization from the XNandPsu_CfgInitialize API. Modified
  • XNandPsu_SetEccAddrSize ECC address now is calculated based upon the size of spare area Modified Block Erase API, removed clearing of packet register before erase. Clearing Data Interface Register before XNandPsu_OnfiReset call. Modified XNandPsu_ChangeTimingMode API supporting SDR and NVDDR interface for timing modes 0 to 5. Modified Bbt Signature and Version Offset value for Oob and No-Oob region. 1.0 kpc 17/6/2015 Added timer based timeout intsead of sw counter. 1.1 mi 09/16/16 Removed compilation warnings with extra compiler flags. 1.1 nsk 11/07/16 Change memcpy to Xil_MemCpy to handle word aligned data access. 1.2 nsk 01/19/17 Fix for the failure of reading nand first redundant parameter page. CR#966603 1.3 nsk 08/14/17 Added CCI support 1.4 nsk 04/10/18 Added ICCARM compiler support. CR#997552. 1.5 mus 11/05/18 Support 64 bit DMA addresses for Microblaze-X platform. 1.5 mus 11/05/18 Updated XNandPsu_ChangeClockFreq to fix compilation warnings. 1.6 sd 06/02/20 Added Clock support 1.6 sd 20/03/20 Added compilation flag 1.8 sg 03/18/21 Added validation check for parameter page. 1.9 akm 07/15/21 Initialize NandInstPtr with Data Interface & Timing mode info. 1.10 akm 10/20/21 Fix gcc warnings. 1.10 akm 12/21/21 Validate input parameters before use. 1.10 akm 01/05/22 Remove assert checks form static and internal APIs. 1.11 akm 03/31/22 Fix unused parameter warning. 1.11 akm 03/31/22 Fix misleading-indentation warning.
This file implements the Bad Block Management (BBM) functionality.
See xnandpsu_bbm.h for more details.
Note
None
                     data access.
This file contains the implementation of ONFI specific functions.
Note
None
This file implements the functions required to use the QSPIPSU hardware to
perform a transfer. These are accessible to the user via xqspipsu.h.
1.2 nsk 07/01/16 Changed XQspiPsu_Select to support GQSPI and LQSPI
                 selection.
1.3 nsk 09/16/16 Update PollData and PollTimeout support for dual
                 parallel configurations, modified XQspiPsu_PollData()
                 and XQspiPsu_Create_PollConfigData()
1,5 nsk 08/14/17 Added CCI support
1.7 tjs 01/17/18 Added a support to toggle WP pin of the flash.
1.8 tjs 06/26/18 Removed checkpatch warnings.
1.8 tjs 07/09/18 Fixed cppcheck and doxygen warnings. (CR#1006336)
1.8  mus 11/05/18 Support 64 bit DMA addresses for Microblaze-X platform.
1.9  aru 01/17/19 Fixes violations according to MISRAC-2012
                 in safety mode and modified the code such as
                 Added UNITPTR inplace of INTPTR,Declared the pointer param
        as Pointer to const .
1.9  nsk 02/01/19 Added QSPI idling support.
1.9  rama 03/13/19 Fixed MISRA violations related to UR data anamoly,
                  expression is not a boolean
         instance is already configured.
1.15 akm 10/21/21 Fix MISRA-C violations.
This file contains intermediate control functions used by functions
in xqspipsu.c and xqspipsu_options.c files.
This file contains functions to reads RXFifo, writes TXFifo and setup
RX DMA operation, used by xqspipsu_control.c and xqspipsu_lowlevel.c files.
        mn  03/30/20 Add xil_smc.h include for Xil_Smc calls
1.15   akm  11/16/21 Typecast function parameter with appropriate
            data type.
1.15   akm  11/30/21 Fix compilation warnings reported with -Wundef flag
This file implements functions to configure the QSPIPSU component,
specifically some optional settings, clock and flash related information.
1.2 nsk 07/01/16 Modified XQspiPsu_SetOptions() to support
1.7 tjs 03/14/18 Added support in EL1 NS mode. (CR#974882)
1.8  tjs 07/26/18 Resolved cppcheck errors. (CR#1006336)
                 Added Xil_MemCpy inplace of memcpy,Declared the pointer param
                 as Pointer to const, declared XQspi_Set_TapDelay() as static.
1.15 akm 03/03/22 Enable tapdelay settings for applications on Microblaze
             platform.
◆ BYTES1024_PER_PAGE
1024 Bytes per Page
◆ BYTES256_PER_PAGE
Definitions for Intel, STM, Winbond and Spansion Serial Flash Device geometry. 256 Bytes per Page
◆ BYTES512_PER_PAGE
512 Bytes per Page
◆ IOU_TAPDLY_BYPASS_OFFSET
Tapdelay Bypass register
◆ IS_ONFI
#define IS_ONFI (   Buff)
Value:
((Buff)[0] == (u8)'O') && ((Buff)[1] == (u8)'N') && \
((Buff)[2] == (u8)'F') && ((Buff)[3] == (u8)'I')
This macro checks for the ONFI ID.
Parameters
Buffis the buffer holding ONFI ID
Note
none.
◆ MAX_DELAY_CNT
Max delay count
◆ NUM_OF_SECTORS1024
1024 Sectors
◆ NUM_OF_SECTORS128
128 Sectors
◆ NUM_OF_SECTORS16
16 Sectors
◆ NUM_OF_SECTORS2
2 Sectors
◆ NUM_OF_SECTORS2048
2048 Sectors
◆ NUM_OF_SECTORS256
256 Sectors
◆ NUM_OF_SECTORS32
32 Sectors
◆ NUM_OF_SECTORS4
4 Sectors
◆ NUM_OF_SECTORS4096
4096 Sectors
◆ NUM_OF_SECTORS512
512 Sectors
◆ NUM_OF_SECTORS64
64 Sectors
◆ NUM_OF_SECTORS8
8 Sector
◆ NUM_OF_SECTORS8192
8192 Sectors
◆ ONFI_CMD_BLK_ERASE1
#define ONFI_CMD_BLK_ERASE1   0x60U
Block Erase (1st cycle)
◆ ONFI_CMD_BLK_ERASE2
#define ONFI_CMD_BLK_ERASE2   0xD0U
Block Erase (2nd cycle)
◆ ONFI_CMD_BLK_ERASE_INTRLVD2
#define ONFI_CMD_BLK_ERASE_INTRLVD2   0xD1U
Block Erase Interleaved (2nd cycle)
◆ ONFI_CMD_CHNG_RD_COL1
#define ONFI_CMD_CHNG_RD_COL1   0x05U
Change Read Column (1st cycle)
◆ ONFI_CMD_CHNG_RD_COL2
#define ONFI_CMD_CHNG_RD_COL2   0xE0U
Change Read Column (2nd cycle)
◆ ONFI_CMD_CHNG_RD_COL_ENHCD1
#define ONFI_CMD_CHNG_RD_COL_ENHCD1   0x06U
Change Read Column Enhanced (1st cycle)
◆ ONFI_CMD_CHNG_RD_COL_ENHCD2
#define ONFI_CMD_CHNG_RD_COL_ENHCD2   0xE0U
Change Read Column Enhanced (2nd cycle)
◆ ONFI_CMD_CHNG_ROW_ADDR
#define ONFI_CMD_CHNG_ROW_ADDR   0x85U
Change Row Address
◆ ONFI_CMD_CHNG_WR_COL
#define ONFI_CMD_CHNG_WR_COL   0x85U
Change Write Column
◆ ONFI_CMD_CPBK_PROG1
#define ONFI_CMD_CPBK_PROG1   0x85U
Copyback Program (1st cycle)
◆ ONFI_CMD_CPBK_PROG2
#define ONFI_CMD_CPBK_PROG2   0x10U
Copyback Program (2nd cycle)
◆ ONFI_CMD_CPBK_RD1
#define ONFI_CMD_CPBK_RD1   0x00U
Copyback Read (1st cycle)
◆ ONFI_CMD_CPBK_RD2
#define ONFI_CMD_CPBK_RD2   0x35U
Copyback Read (2nd cycle)
◆ ONFI_CMD_GET_FEATURES
#define ONFI_CMD_GET_FEATURES   0xEEU
Get Features
◆ ONFI_CMD_INVALID
#define ONFI_CMD_INVALID   0x00U
Invalid Command
◆ ONFI_CMD_LUN_GET_FEATURES
#define ONFI_CMD_LUN_GET_FEATURES   0xD4U
LUN Get Features
◆ ONFI_CMD_LUN_SET_FEATURES
#define ONFI_CMD_LUN_SET_FEATURES   0xD5U
LUN Set Features
◆ ONFI_CMD_MUL_BLK_ERASE1
#define ONFI_CMD_MUL_BLK_ERASE1   0x60U
Multiplane Block Erase (1st cycle)
◆ ONFI_CMD_MUL_BLK_ERASE2
#define ONFI_CMD_MUL_BLK_ERASE2   0xD1U
Multiplane Block Erase (2nd cycle)
◆ ONFI_CMD_MUL_CPBK_PROG1
#define ONFI_CMD_MUL_CPBK_PROG1   0x85U
Multiplane Copyback Program (1st cycle)
◆ ONFI_CMD_MUL_CPBK_PROG2
#define ONFI_CMD_MUL_CPBK_PROG2   0x10U
Multiplane Copyback Program (2nd cycle)
◆ ONFI_CMD_MUL_PG_PROG1
#define ONFI_CMD_MUL_PG_PROG1   0x80U
Multiplane Page Program (1st cycle)
◆ ONFI_CMD_MUL_PG_PROG2
#define ONFI_CMD_MUL_PG_PROG2   0x11U
Multiplane Page Program (2nd cycle)
◆ ONFI_CMD_MUL_RD1
#define ONFI_CMD_MUL_RD1   0x00U
Multiplane Read (1st cycle)
◆ ONFI_CMD_MUL_RD2
#define ONFI_CMD_MUL_RD2   0x32U
Multiplane Read (2nd cycle)
◆ ONFI_CMD_ODT_CONF
#define ONFI_CMD_ODT_CONF   0xE2U
ODT Configure
◆ ONFI_CMD_PG_CACHE_PROG1
#define ONFI_CMD_PG_CACHE_PROG1   0x80U
Page Cache Program (1st cycle)
◆ ONFI_CMD_PG_CACHE_PROG2
#define ONFI_CMD_PG_CACHE_PROG2   0x15U
Page Cache Program (2nd cycle)
◆ ONFI_CMD_PG_PROG1
#define ONFI_CMD_PG_PROG1   0x80U
Page Program(1st cycle)
◆ ONFI_CMD_PG_PROG2
#define ONFI_CMD_PG_PROG2   0x10U
Page Program(2nd cycle)
◆ ONFI_CMD_RD1
#define ONFI_CMD_RD1   0x00U
Read (1st cycle)
◆ ONFI_CMD_RD2
#define ONFI_CMD_RD2   0x30U
Read (2nd cycle)
◆ ONFI_CMD_RD_CACHE_END
#define ONFI_CMD_RD_CACHE_END   0x3FU
Read Cache End
◆ ONFI_CMD_RD_CACHE_RND1
#define ONFI_CMD_RD_CACHE_RND1   0x00U
Read Cache Random (1st cycle)
◆ ONFI_CMD_RD_CACHE_RND2
#define ONFI_CMD_RD_CACHE_RND2   0x31U
Read Cache Random (2nd cycle)
◆ ONFI_CMD_RD_CACHE_SEQ
#define ONFI_CMD_RD_CACHE_SEQ   0x31U
Read Cache Sequential
◆ ONFI_CMD_RD_ID
#define ONFI_CMD_RD_ID   0x90U
Read ID
◆ ONFI_CMD_RD_PRM_PG
#define ONFI_CMD_RD_PRM_PG   0xECU
Read Parameter Page
◆ ONFI_CMD_RD_STS
#define ONFI_CMD_RD_STS   0x70U
Read Status
◆ ONFI_CMD_RD_STS_ENHCD
#define ONFI_CMD_RD_STS_ENHCD   0x78U
Read Status Enhanced
◆ ONFI_CMD_RD_UNIQID
#define ONFI_CMD_RD_UNIQID   0xEDU
Read Unique ID
◆ ONFI_CMD_RST
#define ONFI_CMD_RST   0xFFU
Reset
◆ ONFI_CMD_RST_LUN
#define ONFI_CMD_RST_LUN   0xFAU
Reset LUN
◆ ONFI_CMD_SET_FEATURES
#define ONFI_CMD_SET_FEATURES   0xEFU
Set Features
◆ ONFI_CMD_SMALL_DATA_MV1
#define ONFI_CMD_SMALL_DATA_MV1   0x85U
Small Data Move (1st cycle)
◆ ONFI_CMD_SMALL_DATA_MV2
#define ONFI_CMD_SMALL_DATA_MV2   0x10U
Small Data Move (2nd cycle)
◆ ONFI_CMD_SYN_RST
#define ONFI_CMD_SYN_RST   0xFCU
Synchronous Reset
◆ ONFI_CMD_VOL_SEL
#define ONFI_CMD_VOL_SEL   0xE1U
Volume Select
◆ ONFI_CRC_LEN
#define ONFI_CRC_LEN   254U
ONFI CRC Buf Length
◆ ONFI_MND_PRM_PGS
#define ONFI_MND_PRM_PGS   3U
Number of mandatory parameter pages
◆ ONFI_PRM_PG_ADDR_CYCLES
#define ONFI_PRM_PG_ADDR_CYCLES   1U
ONFI Read Parameter page address cycles
◆ ONFI_PRM_PG_LEN
#define ONFI_PRM_PG_LEN   256U
Parameter Page Length
◆ ONFI_READ_ID_ADDR
#define ONFI_READ_ID_ADDR   0x20U
ONFI Read ID Address
◆ ONFI_READ_ID_ADDR_CYCLES
#define ONFI_READ_ID_ADDR_CYCLES   1U
ONFI Read ID Address cycles
◆ ONFI_READ_ID_LEN
#define ONFI_READ_ID_LEN   4U
ONFI ID length
◆ ONFI_SIG_LEN
#define ONFI_SIG_LEN   4U
Signature Length
◆ ONFI_STS_ARDY
#define ONFI_STS_ARDY   0x20U
ARDY
◆ ONFI_STS_CSP
#define ONFI_STS_CSP   0x08U
CSP
◆ ONFI_STS_FAIL
#define ONFI_STS_FAIL   0x01U
FAIL
◆ ONFI_STS_FAILC
#define ONFI_STS_FAILC   0x02U
FAILC
◆ ONFI_STS_RDY
#define ONFI_STS_RDY   0x40U
RDY
◆ ONFI_STS_VSP
#define ONFI_STS_VSP   0x10U
VSP
◆ ONFI_STS_WP
#define ONFI_STS_WP   0x80U
WP_n
◆ PAGES1024_PER_SECTOR
#define PAGES1024_PER_SECTOR   1024U
1024 Pages per Sector
◆ PAGES128_PER_SECTOR
#define PAGES128_PER_SECTOR   128U
128 Pages per Sector
◆ PAGES16_PER_SECTOR
#define PAGES16_PER_SECTOR   16U
16 Pages per Sector
◆ PAGES256_PER_SECTOR
#define PAGES256_PER_SECTOR   256U
256 Pages per Sector
◆ PAGES512_PER_SECTOR
#define PAGES512_PER_SECTOR   512U
512 Pages per Sector
◆ SECTOR_SIZE_128K
#define SECTOR_SIZE_128K   0X20000U
128K Sector
◆ SECTOR_SIZE_256K
#define SECTOR_SIZE_256K   0X40000U
256K Sector
◆ SECTOR_SIZE_512K
#define SECTOR_SIZE_512K   0X80000U
512K Sector
◆ SECTOR_SIZE_64K
#define SECTOR_SIZE_64K   0X10000U
64K Sector
◆ XNANDPSU_BB_PATTERN
#define XNANDPSU_BB_PATTERN   0xFFU
Bad block pattern to search in a page
◆ XNANDPSU_BB_PTRN_LEN_LARGE_PAGE
#define XNANDPSU_BB_PTRN_LEN_LARGE_PAGE   2U
Bad block pattern length
◆ XNANDPSU_BB_PTRN_LEN_SML_PAGE
#define XNANDPSU_BB_PTRN_LEN_SML_PAGE   1U
◆ XNANDPSU_BB_PTRN_OFF_LARGE_PAGE
#define XNANDPSU_BB_PTRN_OFF_LARGE_PAGE   0U
Bad block pattern offset in a large page
◆ XNANDPSU_BB_PTRN_OFF_SML_PAGE
#define XNANDPSU_BB_PTRN_OFF_SML_PAGE   5U
Bad block pattern offset in a page
◆ XNANDPSU_BBT_BLOCK_SHIFT
#define XNANDPSU_BBT_BLOCK_SHIFT   2U
Block shift value for a block in BBT
◆ XNANDPSU_BBT_BUF_LENGTH
#define XNANDPSU_BBT_BUF_LENGTH
Value:
XNANDPSU_BBT_SIG_LENGTH + \
XNANDPSU_BBT_VERSION_LENGTH))
#define XNANDPSU_BBT_DESC_SIG_OFFSET
Definition: xnandpsu_bbm.h:101
#define XNANDPSU_MAX_BLOCKS
Definition: xnandpsu.h:210
Definition: xnandpsu_bbm.h:116
◆ XNANDPSU_BBT_DESC_MAX_BLOCKS
#define XNANDPSU_BBT_DESC_MAX_BLOCKS   64U
Bad block Table max blocks
◆ XNANDPSU_BBT_DESC_PAGE_OFFSET
#define XNANDPSU_BBT_DESC_PAGE_OFFSET   0U
Page offset of Bad Block Table Desc
◆ XNANDPSU_BBT_DESC_SIG_LEN
#define XNANDPSU_BBT_DESC_SIG_LEN   4U
Bad block Table signature length
◆ XNANDPSU_BBT_DESC_SIG_OFFSET
#define XNANDPSU_BBT_DESC_SIG_OFFSET   8U
Bad Block Table signature offset
◆ XNANDPSU_BBT_DESC_VER_OFFSET
#define XNANDPSU_BBT_DESC_VER_OFFSET   12U
Bad block Table version offset
◆ XNANDPSU_BBT_ENTRY_NUM_BLOCKS
#define XNANDPSU_BBT_ENTRY_NUM_BLOCKS   4U
Num of blocks in one BBT entry
◆ XNANDPSU_BBT_SCAN_2ND_PAGE
#define XNANDPSU_BBT_SCAN_2ND_PAGE   0x00000001U
Scan the second page for bad block information
◆ XNandPsu_BbtBlockShift
#define XNandPsu_BbtBlockShift (   Block)     (u8)(((Block) * 2U) & XNANDPSU_BLOCK_SHIFT_MASK)
This macro returns the Block shift value corresponding to a Block.
Parameters
Blockis the block number.
Returns
Block shift value
Note
None.
◆ XNANDPSU_BCH
#define XNANDPSU_BCH   0x2U
BCH Flash
◆ XNANDPSU_BLOCK_BAD
#define XNANDPSU_BLOCK_BAD   0x1U
Block is bad
◆ XNANDPSU_BLOCK_FACTORY_BAD
#define XNANDPSU_BLOCK_FACTORY_BAD   0x3U
◆ XNANDPSU_BLOCK_GOOD
#define XNANDPSU_BLOCK_GOOD   0x0U
Block is good
◆ XNANDPSU_BLOCK_RESERVED
#define XNANDPSU_BLOCK_RESERVED   0x2U
Reserved block
◆ XNANDPSU_BLOCK_SHIFT_MASK
#define XNANDPSU_BLOCK_SHIFT_MASK   0x06U
Block shift mask for a Bad Block Table entry byte
◆ XNANDPSU_BLOCK_TYPE_MASK
#define XNANDPSU_BLOCK_TYPE_MASK   0x03U
Block type mask
◆ XNANDPSU_BUF_DATA_PORT_OFFSET
#define XNANDPSU_BUF_DATA_PORT_OFFSET   0x30U
Buffer Data Port Register
◆ XNandPsu_ClrBits
#define XNandPsu_ClrBits (   InstancePtr,
  RegOffset,
  BitMask
Value:
XNandPsu_WriteReg((InstancePtr)->Config.BaseAddress, \
(RegOffset), \
((u32)(XNandPsu_ReadReg((InstancePtr)->Config.BaseAddress, \
(RegOffset)) & ~(BitMask))))
Definition: xnandpsu_hw.h:475
Definition: xnandpsu_hw.h:457
This macro clears the bitmask in the register.
Parameters
InstancePtris a pointer to the XNandPsu instance of the controller.
RegOffsetis the register offset.
BitMaskis the bitmask.
Note
C-style signature: void XNandPsu_ClrBits(XNandPsu *InstancePtr, u32 RegOffset, u32 BitMask)
◆ XNANDPSU_CMD_ADDR_CYCLES_MASK
Number of Address Cycles
◆ XNANDPSU_CMD_ADDR_CYCLES_SHIFT
Number of Address Cycles Shift
◆ XNANDPSU_CMD_CMD1_MASK
1st Cycle Command
◆ XNANDPSU_CMD_CMD2_MASK
2nd Cycle Command
◆ XNANDPSU_CMD_CMD2_SHIFT
2nd Cycle Command Shift
◆ XNANDPSU_CMD_DMA_EN_MASK
DMA Enable Mode
◆ XNANDPSU_CMD_DMA_EN_SHIFT
DMA Enable Shift
◆ XNANDPSU_CMD_ECC_ON_MASK
ECC ON/OFF
◆ XNANDPSU_CMD_ECC_ON_SHIFT
ECC ON/OFF
◆ XNANDPSU_CMD_OFFSET
#define XNANDPSU_CMD_OFFSET   0x0CU
Command Register
◆ XNANDPSU_CMD_PG_SIZE_MASK
Page Size
◆ XNANDPSU_CMD_PG_SIZE_SHIFT
Page Size Shift
◆ XNANDPSU_CPU_REL_OFFSET
#define XNANDPSU_CPU_REL_OFFSET   0x58U
CPU Release Register
◆ XNANDPSU_DATA_INTF_DATA_INTF_MASK
Data Interface
◆ XNANDPSU_DATA_INTF_DATA_INTF_SHIFT
Data Interface Shift
◆ XNANDPSU_DATA_INTF_NVDDR2_MASK
NVDDR2 mode
◆ XNANDPSU_DATA_INTF_NVDDR_MASK
NVDDR mode
◆ XNANDPSU_DATA_INTF_NVDDR_SHIFT
NVDDR mode shift
◆ XNANDPSU_DATA_INTF_OFFSET
#define XNANDPSU_DATA_INTF_OFFSET   0x6CU
◆ XNANDPSU_DATA_INTF_SDR_MASK
SDR mode
◆ XNANDPSU_DMA_BUF_BND_BND_MASK
DMA buffer boundary
◆ XNANDPSU_DMA_BUF_BND_OFFSET
#define XNANDPSU_DMA_BUF_BND_OFFSET   0x54U
◆ XNANDPSU_DMA_SYS_ADDR0_OFFSET
#define XNANDPSU_DMA_SYS_ADDR0_OFFSET   0x50U
DMA System Address 0 Register
◆ XNANDPSU_DMA_SYS_ADDR1_OFFSET
#define XNANDPSU_DMA_SYS_ADDR1_OFFSET   0x24U
DMA System Address 1 Register
◆ XNANDPSU_ECC_ADDR_MASK
ECC address
◆ XNANDPSU_ECC_CNT_1BIT_OFFSET
#define XNANDPSU_ECC_CNT_1BIT_OFFSET   0x40U
Error Count 1bit Register
◆ XNANDPSU_ECC_CNT_2BIT_OFFSET
#define XNANDPSU_ECC_CNT_2BIT_OFFSET   0x44U
Error Count 2bit Register
◆ XNANDPSU_ECC_CNT_3BIT_OFFSET
#define XNANDPSU_ECC_CNT_3BIT_OFFSET   0x48U
Error Count 3bit Register
◆ XNANDPSU_ECC_CNT_4BIT_OFFSET
#define XNANDPSU_ECC_CNT_4BIT_OFFSET   0x4CU
Error Count 4bit Register
◆ XNANDPSU_ECC_CNT_5BIT_OFFSET
#define XNANDPSU_ECC_CNT_5BIT_OFFSET   0x5CU
Error Count 5bit Register
◆ XNANDPSU_ECC_CNT_6BIT_OFFSET
#define XNANDPSU_ECC_CNT_6BIT_OFFSET   0x60U
Error Count 6bit Register
◆ XNANDPSU_ECC_CNT_7BIT_OFFSET
#define XNANDPSU_ECC_CNT_7BIT_OFFSET   0x64U
Error Count 7bit Register
◆ XNANDPSU_ECC_CNT_8BIT_OFFSET
#define XNANDPSU_ECC_CNT_8BIT_OFFSET   0x68U
Error Count 8bit Register
◆ XNANDPSU_ECC_ERR_CNT_OFFSET
#define XNANDPSU_ECC_ERR_CNT_OFFSET   0x38U
◆ XNANDPSU_ECC_ERR_CNT_PG_BND_ERR_CNT_MASK
Page bound error count
◆ XNANDPSU_ECC_ERR_CNT_PKT_BND_ERR_CNT_MASK
Packet bound error count
◆ XNANDPSU_ECC_HAMMING_BCH_MASK
Hamming/BCH support
◆ XNANDPSU_ECC_OFFSET
#define XNANDPSU_ECC_OFFSET   0x34U
ECC Register
◆ XNANDPSU_ECC_SIZE_MASK
ECC size
◆ XNANDPSU_ECC_SPR_CMD_ECC_ADDR_CYCLES_MASK
Number of ECC/ spare address cycles
◆ XNANDPSU_ECC_SPR_CMD_OFFSET
#define XNANDPSU_ECC_SPR_CMD_OFFSET   0x3CU
◆ XNANDPSU_ECC_SPR_CMD_SPR_CMD_MASK
ECC spare command
◆ XNANDPSU_FLASH_BLOCK_BAD
#define XNANDPSU_FLASH_BLOCK_BAD   0x2U
Block is bad
◆ XNANDPSU_FLASH_BLOCK_FAC_BAD
#define XNANDPSU_FLASH_BLOCK_FAC_BAD   0x0U
◆ XNANDPSU_FLASH_BLOCK_GOOD
#define XNANDPSU_FLASH_BLOCK_GOOD   0x3U
Block is good
◆ XNANDPSU_FLASH_BLOCK_RESERVED
#define XNANDPSU_FLASH_BLOCK_RESERVED   0x1U
Reserved block
◆ XNANDPSU_FLASH_STS_FLASH_STS_MASK
Flash Status Value
◆ XNANDPSU_FLASH_STS_OFFSET
#define XNANDPSU_FLASH_STS_OFFSET   0x28U
◆ XNANDPSU_HAMMING
#define XNANDPSU_HAMMING   0x1U
Hamming Flash
◆ XNANDPSU_ID2_DEVICE_ID2_MASK
MSB Device ID
◆ XNANDPSU_INTR_BUFF_RD_RDY_STS_EN_MASK
Buffer Read Ready Status Enable
◆ XNANDPSU_INTR_BUFF_WR_RDY_STS_EN_MASK
Buffer Write Ready Status Enable
◆ XNANDPSU_INTR_DMA_INT_STS_EN_MASK
DMA Status Enable
◆ XNANDPSU_INTR_ERR_AHB_STS_EN_MASK
Error AHB Status Enable
◆ XNANDPSU_INTR_ERR_INTR_STS_EN_MASK
Single Bit Error Status Enable, BCH Detect Error Status Enable
◆ XNANDPSU_INTR_MUL_BIT_ERR_STS_EN_MASK
Multi Bit Error Status Enable
◆ XNANDPSU_INTR_SIG_EN_BUFF_RD_RDY_STS_EN_MASK
Buffer Read Ready Signal Enable
◆ XNANDPSU_INTR_SIG_EN_BUFF_WR_RDY_STS_EN_MASK
Buffer Write Ready Signal Enable
◆ XNANDPSU_INTR_SIG_EN_DMA_INT_STS_EN_MASK
DMA Signal Enable
◆ XNANDPSU_INTR_SIG_EN_ERR_AHB_STS_EN_MASK
Error AHB Signal Enable
◆ XNANDPSU_INTR_SIG_EN_ERR_INTR_STS_EN_MASK
Single Bit Error Signal Enable, BCH Detect Error Signal Enable
◆ XNANDPSU_INTR_SIG_EN_MUL_BIT_ERR_STS_EN_MASK
Multi Bit Error Signal Enable
◆ XNANDPSU_INTR_SIG_EN_OFFSET
#define XNANDPSU_INTR_SIG_EN_OFFSET   0x18U
Interrupt Signal Enable Register
◆ XNANDPSU_INTR_SIG_EN_TRANS_COMP_STS_EN_MASK
#define XNANDPSU_INTR_SIG_EN_TRANS_COMP_STS_EN_MASK   0x00000004U
Transfer Complete Signal Enable
◆ XNANDPSU_INTR_STS_BUFF_RD_RDY_STS_EN_MASK
Buffer Read Ready
◆ XNANDPSU_INTR_STS_BUFF_WR_RDY_STS_EN_MASK
#define XNANDPSU_INTR_STS_BUFF_WR_RDY_STS_EN_MASK   0x00000001U
Buffer Write Ready
◆ XNANDPSU_INTR_STS_DMA_INT_STS_EN_MASK
DMA Interrupt
◆ XNANDPSU_INTR_STS_EN_BUFF_RD_RDY_STS_EN_MASK
#define XNANDPSU_INTR_STS_EN_BUFF_RD_RDY_STS_EN_MASK   0x00000002U
◆ XNANDPSU_INTR_STS_EN_BUFF_WR_RDY_STS_EN_MASK
#define XNANDPSU_INTR_STS_EN_BUFF_WR_RDY_STS_EN_MASK   0x00000001U
◆ XNANDPSU_INTR_STS_EN_DMA_INT_STS_EN_MASK
#define XNANDPSU_INTR_STS_EN_DMA_INT_STS_EN_MASK   0x00000040U
DMA Status Enable
◆ XNANDPSU_INTR_STS_EN_ERR_AHB_STS_EN_MASK
#define XNANDPSU_INTR_STS_EN_ERR_AHB_STS_EN_MASK   0x00000080U
◆ XNANDPSU_INTR_STS_EN_ERR_INTR_STS_EN_MASK
#define XNANDPSU_INTR_STS_EN_ERR_INTR_STS_EN_MASK   0x00000010U
◆ XNANDPSU_INTR_STS_EN_MUL_BIT_ERR_STS_EN_MASK
#define XNANDPSU_INTR_STS_EN_MUL_BIT_ERR_STS_EN_MASK   0x00000008U
◆ XNANDPSU_INTR_STS_EN_OFFSET
#define XNANDPSU_INTR_STS_EN_OFFSET   0x14U
Interrupt Status Enable Register
◆ XNANDPSU_INTR_STS_EN_TRANS_COMP_STS_EN_MASK
#define XNANDPSU_INTR_STS_EN_TRANS_COMP_STS_EN_MASK   0x00000004U
Transfer Complete Status Enable
◆ XNANDPSU_INTR_STS_ERR_AHB_STS_EN_MASK
#define XNANDPSU_INTR_STS_ERR_AHB_STS_EN_MASK   0x00000080U
Error AHB
◆ XNANDPSU_INTR_STS_ERR_INTR_STS_EN_MASK
#define XNANDPSU_INTR_STS_ERR_INTR_STS_EN_MASK   0x00000010U
Single Bit Error, BCH Detect Error
◆ XNANDPSU_INTR_STS_MUL_BIT_ERR_STS_EN_MASK
#define XNANDPSU_INTR_STS_MUL_BIT_ERR_STS_EN_MASK   0x00000008U
Multi Bit Error
◆ XNANDPSU_INTR_STS_OFFSET
#define XNANDPSU_INTR_STS_OFFSET   0x1CU
◆ XNANDPSU_INTR_STS_TRANS_COMP_STS_EN_MASK
#define XNANDPSU_INTR_STS_TRANS_COMP_STS_EN_MASK   0x00000004U
Transfer Complete
◆ XNANDPSU_INTR_TRANS_COMP_STS_EN_MASK
#define XNANDPSU_INTR_TRANS_COMP_STS_EN_MASK   0x00000004U
◆ XNandPsu_IntrSigClear
#define XNandPsu_IntrSigClear (   InstancePtr,
  Mask
Value:
XNandPsu_ClrBits((InstancePtr), \
(Mask))
Definition: xnandpsu_hw.h:61
#define XNandPsu_ClrBits(InstancePtr, RegOffset, BitMask)
Definition: xnandpsu.h:459
This macro clears bitmask in Interrupt Signal Enable register.
Parameters
Maskis the bitmask.
Note
C-style signature: void XNandPsu_IntrSigClear(XNandPsu *InstancePtr, u32 Mask)
◆ XNandPsu_IntrSigEnable
#define XNandPsu_IntrSigEnable (   InstancePtr,
  Mask
Value:
XNandPsu_SetBits((InstancePtr), \
(Mask))
#define XNandPsu_SetBits(InstancePtr, RegOffset, BitMask)
Definition: xnandpsu.h:439
This macro enables bitmask in Interrupt Signal Enable register.
Parameters
Maskis the bitmask.
Note
C-style signature: void XNandPsu_IntrSigEnable(XNandPsu *InstancePtr, u32 Mask)
◆ XNandPsu_IntrStsEnable
#define XNandPsu_IntrStsEnable (   InstancePtr,
  Mask
Value:
(Mask))
Definition: xnandpsu_hw.h:59
This macro enables bitmask in Interrupt Status Enable register.
Parameters
Maskis the bitmask.
Note
C-style signature: void XNandPsu_IntrStsEnable(XNandPsu *InstancePtr, u32 Mask)
◆ XNANDPSU_MAX_BLOCKS
#define XNANDPSU_MAX_BLOCKS   16384U
Max number of Blocks
◆ XNANDPSU_MAX_LUNS
#define XNANDPSU_MAX_LUNS   8U
Max number of LUNs
◆ XNANDPSU_MAX_PAGE_SIZE
#define XNANDPSU_MAX_PAGE_SIZE   16384U
Max page size supported
◆ XNANDPSU_MAX_PAGES_PER_BLOCK
#define XNANDPSU_MAX_PAGES_PER_BLOCK   512U
Max number pages per block
◆ XNANDPSU_MAX_PKT_COUNT
#define XNANDPSU_MAX_PKT_COUNT   0xFFFU
Max packet count
◆ XNANDPSU_MAX_PKT_SIZE
#define XNANDPSU_MAX_PKT_SIZE   0x7FFU
Max packet size
◆ XNANDPSU_MAX_SPARE_SIZE
#define XNANDPSU_MAX_SPARE_SIZE   0x800U
Max spare bytes of a NAND flash page of 16K
◆ XNANDPSU_MAX_TARGETS
#define XNANDPSU_MAX_TARGETS   1U
ce_n0, ce_n1
◆ XNANDPSU_MEM_ADDR1_COL_ADDR_MASK
#define XNANDPSU_MEM_ADDR1_COL_ADDR_MASK   0x0000FFFFU
Column Address Mask
◆ XNANDPSU_MEM_ADDR1_OFFSET
#define XNANDPSU_MEM_ADDR1_OFFSET   0x04U
Memory Address Register 1
◆ XNANDPSU_MEM_ADDR1_PG_ADDR_MASK
#define XNANDPSU_MEM_ADDR1_PG_ADDR_MASK   0xFFFF0000U
Page, Block Address Mask
◆ XNANDPSU_MEM_ADDR1_PG_ADDR_SHIFT
#define XNANDPSU_MEM_ADDR1_PG_ADDR_SHIFT   16U
Page Shift
◆ XNANDPSU_MEM_ADDR2_BUS_WIDTH_MASK
#define XNANDPSU_MEM_ADDR2_BUS_WIDTH_MASK   0x01000000U
Bus Width
◆ XNANDPSU_MEM_ADDR2_BUS_WIDTH_SHIFT
#define XNANDPSU_MEM_ADDR2_BUS_WIDTH_SHIFT   24U
Bus width shift
◆ XNANDPSU_MEM_ADDR2_CHIP_SEL_MASK
#define XNANDPSU_MEM_ADDR2_CHIP_SEL_MASK   0xC0000000U
Chip Select
◆ XNANDPSU_MEM_ADDR2_CHIP_SEL_SHIFT
#define XNANDPSU_MEM_ADDR2_CHIP_SEL_SHIFT   30U
Chip select shift
◆ XNANDPSU_MEM_ADDR2_MEM_ADDR_MASK
#define XNANDPSU_MEM_ADDR2_MEM_ADDR_MASK   0x000000FFU
Memory Address
◆ XNANDPSU_MEM_ADDR2_MODE_MASK
#define XNANDPSU_MEM_ADDR2_MODE_MASK   0x30000000U
Flash Connection Mode
◆ XNANDPSU_MEM_ADDR2_NFC_BCH_MODE_MASK
#define XNANDPSU_MEM_ADDR2_NFC_BCH_MODE_MASK   0x0E000000U
BCH Mode Value
◆ XNANDPSU_MEM_ADDR2_OFFSET
#define XNANDPSU_MEM_ADDR2_OFFSET   0x08U
Memory Address Register 2
◆ XNANDPSU_NO_OOB_BBT_DESC_SIG_OFFSET
#define XNANDPSU_NO_OOB_BBT_DESC_SIG_OFFSET   0U
Bad Block Table signature offset in page memory
◆ XNANDPSU_NO_OOB_BBT_DESC_VER_OFFSET
#define XNANDPSU_NO_OOB_BBT_DESC_VER_OFFSET   4U
Bad block Table version offset in page memory
◆ XNANDPSU_PAGE_SIZE_16K
#define XNANDPSU_PAGE_SIZE_16K   16384U
16K bytes page
◆ XNANDPSU_PAGE_SIZE_1K_16BIT
#define XNANDPSU_PAGE_SIZE_1K_16BIT   1024U
16-bit 2K bytes page
◆ XNANDPSU_PAGE_SIZE_2K
#define XNANDPSU_PAGE_SIZE_2K   2048U
2K bytes page
◆ XNANDPSU_PAGE_SIZE_4K
#define XNANDPSU_PAGE_SIZE_4K   4096U
4K bytes page
◆ XNANDPSU_PAGE_SIZE_512
#define XNANDPSU_PAGE_SIZE_512   512U
512 bytes page
◆ XNANDPSU_PAGE_SIZE_8K
#define XNANDPSU_PAGE_SIZE_8K   8192U
8K bytes page
◆ XNANDPSU_PKT_OFFSET
#define XNANDPSU_PKT_OFFSET   0x00U
Packet Register
◆ XNANDPSU_PKT_PKT_CNT_MASK
#define XNANDPSU_PKT_PKT_CNT_MASK   0x00FFF000U
Packet Count
◆ XNANDPSU_PKT_PKT_CNT_SHIFT
#define XNANDPSU_PKT_PKT_CNT_SHIFT   12U
Packet Count Shift
◆ XNANDPSU_PKT_PKT_SIZE_MASK
#define XNANDPSU_PKT_PKT_SIZE_MASK   0x000007FFU
Packet Size
◆ XNANDPSU_PROG_BLK_ERASE_MASK
#define XNANDPSU_PROG_BLK_ERASE_MASK   0x00000004U
Block Erase
◆ XNANDPSU_PROG_CHNG_RD_COL_ENH_MASK
#define XNANDPSU_PROG_CHNG_RD_COL_ENH_MASK   0x00004000U
◆ XNANDPSU_PROG_CHNG_ROW_ADDR_END_MASK
#define XNANDPSU_PROG_CHNG_ROW_ADDR_END_MASK   0x00400000U
Change Row Address End
◆ XNANDPSU_PROG_CHNG_ROW_ADDR_MASK
#define XNANDPSU_PROG_CHNG_ROW_ADDR_MASK   0x00200000U
Change Row Address
◆ XNANDPSU_PROG_COPY_BACK_INTRLVD_MASK
#define XNANDPSU_PROG_COPY_BACK_INTRLVD_MASK   0x00008000U
Copy Back Interleaved
◆ XNANDPSU_PROG_GET_FEATURES_MASK
#define XNANDPSU_PROG_GET_FEATURES_MASK   0x00000200U
Get Features
◆ XNANDPSU_PROG_MUL_DIE_MASK
#define XNANDPSU_PROG_MUL_DIE_MASK   0x00000002U
Multi Die
◆ XNANDPSU_PROG_MUL_DIE_RD_MASK
#define XNANDPSU_PROG_MUL_DIE_RD_MASK   0x00000020U
Multi Die Rd
◆ XNANDPSU_PROG_ODT_CONF_MASK
#define XNANDPSU_PROG_ODT_CONF_MASK   0x04000000U
ODT Configure
◆ XNANDPSU_PROG_OFFSET
#define XNANDPSU_PROG_OFFSET   0x10U
Program Register
◆ XNANDPSU_PROG_PG_PROG_MASK
#define XNANDPSU_PROG_PG_PROG_MASK   0x00000010U
Page Program
◆ XNANDPSU_PROG_PGM_PG_CLR_MASK
#define XNANDPSU_PROG_PGM_PG_CLR_MASK   0x01000000U
Enhanced Program Page Register Clear
◆ XNANDPSU_PROG_RD_CACHE_END_MASK
#define XNANDPSU_PROG_RD_CACHE_END_MASK   0x00080000U
Read Cache End
◆ XNANDPSU_PROG_RD_CACHE_RAND_MASK
#define XNANDPSU_PROG_RD_CACHE_RAND_MASK   0x00040000U
Read Cache Random
◆ XNANDPSU_PROG_RD_CACHE_SEQ_MASK
#define XNANDPSU_PROG_RD_CACHE_SEQ_MASK   0x00020000U
◆ XNANDPSU_PROG_RD_CACHE_START_MASK
#define XNANDPSU_PROG_RD_CACHE_START_MASK   0x00010000U
Read Cache Start
◆ XNANDPSU_PROG_RD_ID_MASK
#define XNANDPSU_PROG_RD_ID_MASK   0x00000040U
Read ID
◆ XNANDPSU_PROG_RD_INTRLVD_MASK
#define XNANDPSU_PROG_RD_INTRLVD_MASK   0x00002000U
Read Interleaved
◆ XNANDPSU_PROG_RD_MASK
#define XNANDPSU_PROG_RD_MASK   0x00000001U
Read
◆ XNANDPSU_PROG_RD_PRM_PG_MASK
#define XNANDPSU_PROG_RD_PRM_PG_MASK   0x00000080U
Read Param Page
◆ XNANDPSU_PROG_RD_STS_ENH_MASK
#define XNANDPSU_PROG_RD_STS_ENH_MASK   0x00001000U
◆ XNANDPSU_PROG_RD_STS_MASK
#define XNANDPSU_PROG_RD_STS_MASK   0x00000008U
Read Status
◆ XNANDPSU_PROG_RD_UNQ_ID_MASK
#define XNANDPSU_PROG_RD_UNQ_ID_MASK   0x00000800U
Read Unique ID
◆ XNANDPSU_PROG_RST_LUN_MASK
#define XNANDPSU_PROG_RST_LUN_MASK   0x00800000U
Reset LUN
◆ XNANDPSU_PROG_RST_MASK
#define XNANDPSU_PROG_RST_MASK   0x00000100U
Reset
◆ XNANDPSU_PROG_SET_FEATURES_MASK
#define XNANDPSU_PROG_SET_FEATURES_MASK   0x00000400U
Set Features
◆ XNANDPSU_PROG_SMALL_DATA_MOVE_MASK
#define XNANDPSU_PROG_SMALL_DATA_MOVE_MASK   0x00100000U
Small Data Move
◆ XNANDPSU_PROG_VOL_SEL_MASK
#define XNANDPSU_PROG_VOL_SEL_MASK   0x02000000U
Volume Select
◆ XNandPsu_ReadModifyWrite
#define XNandPsu_ReadModifyWrite (   InstancePtr,
  RegOffset,
  Mask,
  Value
Value:
(RegOffset), \
((u32)((u32)(XNandPsu_ReadReg((InstancePtr)->Config.BaseAddress,\
(u32)(RegOffset)) & (u32)(~(Mask))) | (u32)(Value))))
This macro clears and updates the bitmask in the register.
Parameters
Maskis the bitmask.
Valueis the register value to write.
Note
C-style signature: void XNandPsu_ReadModifyWrite(XNandPsu *InstancePtr, u32 RegOffset, u32 Mask, u32 Val)
◆ XNandPsu_ReadReg
#define XNandPsu_ReadReg (   BaseAddress,
  RegOffset
)     Xil_In32((BaseAddress) + (RegOffset))
This macro reads the given register.
Parameters
BaseAddressis the base address of controller registers.
RegOffsetis the register offset to be read.
Returns
The 32-bit value of the register.
Note
C-style signature: u32 XNandPsu_ReadReg(u32 BaseAddress, u32 RegOffset)
◆ XNANDPSU_READY_BUSY_OFFSET
#define XNANDPSU_READY_BUSY_OFFSET   0x20U
Ready/Busy status Register
◆ XNandPsu_SetBits
#define XNandPsu_SetBits (   InstancePtr,
  RegOffset,
  BitMask
Value:
(RegOffset), \
(RegOffset)) | (BitMask))))
This macro sets the bitmask in the register.
Parameters
Note
C-style signature: void XNandPsu_SetBits(XNandPsu *InstancePtr, u32 RegOffset, u32 BitMask)
◆ XNANDPSU_SLV_DMA_CONF_DMA_BURST_SIZE_MASK
#define XNANDPSU_SLV_DMA_CONF_DMA_BURST_SIZE_MASK   0x00E00000U
Slave DMA Burst Size
◆ XNANDPSU_SLV_DMA_CONF_DMA_TMOUT_CNT_VAL_MASK
#define XNANDPSU_SLV_DMA_CONF_DMA_TMOUT_CNT_VAL_MASK   0x0F000000U
DMA Timeout Counter Value
◆ XNANDPSU_SLV_DMA_CONF_DMA_TRANS_CNT_MASK
#define XNANDPSU_SLV_DMA_CONF_DMA_TRANS_CNT_MASK   0x001FFFFEU
Slave DMA Transfer Count
◆ XNANDPSU_SLV_DMA_CONF_OFFSET
#define XNANDPSU_SLV_DMA_CONF_OFFSET   0x80U
Slave DMA Configuration Register
◆ XNANDPSU_SLV_DMA_CONF_SDMA_EN_MASK
#define XNANDPSU_SLV_DMA_CONF_SDMA_EN_MASK   0x10000000U
Slave DMA Enable
◆ XNANDPSU_SLV_DMA_CONF_SDMA_TX_RX_MASK
#define XNANDPSU_SLV_DMA_CONF_SDMA_TX_RX_MASK   0x00000001U
Slave DMA Transfer Direction
◆ XNANDPSU_TIMING_DQS_BUFF_SEL_MASK
#define XNANDPSU_TIMING_DQS_BUFF_SEL_MASK   0x00000078U
Write/Read data transaction value
◆ XNANDPSU_TIMING_OFFSET
#define XNANDPSU_TIMING_OFFSET   0x2CU
Timing Register
◆ XNANDPSU_TIMING_SLOW_FAST_TCAD_MASK
#define XNANDPSU_TIMING_SLOW_FAST_TCAD_MASK   0x00000004U
Slow/Fast device
◆ XNANDPSU_TIMING_TADL_TIME_MASK
#define XNANDPSU_TIMING_TADL_TIME_MASK   0x00007F80U
Address latch enable to Data loading time
◆ XNANDPSU_TIMING_TCCS_TIME_MASK
#define XNANDPSU_TIMING_TCCS_TIME_MASK   0x00000003U
Change column setup time
◆ XNandPsu_WriteReg
#define XNandPsu_WriteReg (   BaseAddress,
  RegOffset,
  Data
)     Xil_Out32(((BaseAddress) + (RegOffset)), (Data))
This macro writes the given register.
Parameters
BaseAddressis the the base address of controller registers.
RegOffsetis the register offset to be written.
Datais the the 32-bit value to write to the register.
Returns
None.
Note
C-style signature: void XNandPsu_WriteReg(u32 BaseAddress, u32 RegOffset, u32 Data)
◆ XQSPIPS_BASEADDR
#define XQSPIPS_BASEADDR   0XFF0F0000U
QSPI Base Address
◆ XQSPIPS_EN_REG
#define XQSPIPS_EN_REG   ( ( XQSPIPS_BASEADDR ) + 0X00000014U )
Register: XQSPIPS_EN_REG
◆ XQSPIPS_LQSPI_CFG_RST_STATE
#define XQSPIPS_LQSPI_CFG_RST_STATE   0x800238C1U
Default LQSPI CFG value
◆ XQSPIPS_LQSPI_CR_4_BYTE_STATE
#define XQSPIPS_LQSPI_CR_4_BYTE_STATE   0x88000013U
Default 4 Byte LQSPI CR value
◆ XQSPIPS_LQSPI_CR_INST_MASK
#define XQSPIPS_LQSPI_CR_INST_MASK   0x000000FFU
Read instr code
◆ XQSPIPS_LQSPI_CR_RST_STATE
#define XQSPIPS_LQSPI_CR_RST_STATE   0x80000003U
Default LQSPI CR value
◆ XQSPIPSU_CFG_OFFSET
#define XQSPIPSU_CFG_OFFSET   0X00000000U
Register: XQSPIPSU_CFG
◆ XQSPIPSU_CLK_ACTIVE_LOW_OPTION
#define XQSPIPSU_CLK_ACTIVE_LOW_OPTION   0x2U
Clk Active low option
◆ XQSPIPSU_CLK_PHASE_1_OPTION
#define XQSPIPSU_CLK_PHASE_1_OPTION   0x4U
Clk phase 1 option
◆ XQSPIPSU_CLK_PRESCALE_128
#define XQSPIPSU_CLK_PRESCALE_128   0x06U
Clock prescale 128
◆ XQSPIPSU_CLK_PRESCALE_16
#define XQSPIPSU_CLK_PRESCALE_16   0x03U
Clock prescale 16
◆ XQSPIPSU_CLK_PRESCALE_2
#define XQSPIPSU_CLK_PRESCALE_2   0x00U
Clock prescale 2
◆ XQSPIPSU_CLK_PRESCALE_256
#define XQSPIPSU_CLK_PRESCALE_256   0x07U
Clock prescale 256
◆ XQSPIPSU_CLK_PRESCALE_32
#define XQSPIPSU_CLK_PRESCALE_32   0x04U
Clock prescale 32
◆ XQSPIPSU_CLK_PRESCALE_4
#define XQSPIPSU_CLK_PRESCALE_4   0x01U
Clock prescale 4
◆ XQSPIPSU_CLK_PRESCALE_64
#define XQSPIPSU_CLK_PRESCALE_64   0x05U
Clock prescale 64
◆ XQSPIPSU_CLK_PRESCALE_8
#define XQSPIPSU_CLK_PRESCALE_8   0x02U
Clock prescale 8
◆ XQSPIPSU_CONNECTION_MODE_PARALLEL
#define XQSPIPSU_CONNECTION_MODE_PARALLEL   2U
Parallel mode connection
◆ XQSPIPSU_CONNECTION_MODE_SINGLE
#define XQSPIPSU_CONNECTION_MODE_SINGLE   0U
Single mode connection
◆ XQSPIPSU_CONNECTION_MODE_STACKED
#define XQSPIPSU_CONNECTION_MODE_STACKED   1U
Stacked mode connection
◆ XQSPIPSU_CR_PRESC_MAXIMUM
#define XQSPIPSU_CR_PRESC_MAXIMUM   7U
Prescale max
◆ XQSPIPSU_DATA_DLY_ADJ_OFFSET
QSPI Data delay register
◆ XQspiPsu_Disable
#define XQspiPsu_Disable (   InstancePtr)
Value:
XQspiPsu_Out32(((InstancePtr)->Config.BaseAddress) + \
#define XQSPIPSU_EN_OFFSET
Definition: xqspipsu_hw.h:382
#define XQspiPsu_Out32
Definition: xqspipsu_hw.h:967
Disable QSPI controller
◆ XQSPIPSU_DMA_BYTES_MAX
#define XQSPIPSU_DMA_BYTES_MAX   0x10000000U
DMA bytes max
◆ XQSPIPSU_EN_OFFSET
#define XQSPIPSU_EN_OFFSET   0X00000014U
Register: XQSPIPSU_EN_REG
◆ XQspiPsu_Enable
#define XQspiPsu_Enable (   InstancePtr)
Value:
XQSPIPSU_EN_OFFSET, XQSPIPSU_EN_MASK)
Enable QSPI Controller
◆ XQSPIPSU_FIFO_CTRL_OFFSET
Register: XQSPIPSU_FIFO_CTRL
◆ XQSPIPSU_FREQ_100MHZ
#define XQSPIPSU_FREQ_100MHZ   100000000U
Frequency 100 Mhz
◆ XQSPIPSU_FREQ_150MHZ
#define XQSPIPSU_FREQ_150MHZ   150000000U
Frequency 150 Mhz
◆ XQSPIPSU_FREQ_37_5MHZ
#define XQSPIPSU_FREQ_37_5MHZ   37500000U
Frequency 375 Mhz
◆ XQSPIPSU_FREQ_40MHZ
#define XQSPIPSU_FREQ_40MHZ   40000000U
Frequency 40 Mhz
◆ XQSPIPSU_GEN_FIFO_OFFSET
#define XQSPIPSU_GEN_FIFO_OFFSET   0X00000040U
Register: XQSPIPSU_GEN_FIFO
◆ XQSPIPSU_GENFIFO_CS_HOLD
#define XQSPIPSU_GENFIFO_CS_HOLD   0x04U
Chip select hold in GENFIFO
◆ XQSPIPSU_GENFIFO_CS_SETUP
#define XQSPIPSU_GENFIFO_CS_SETUP   0x05U
Chip select setup in GENFIO
◆ XQSPIPSU_GENFIFO_EXP_START
#define XQSPIPSU_GENFIFO_EXP_START   0x100U
Genfifo start
◆ XQSPIPSU_GENFIFO_IMM_DATA_MASK
Generic FIFO masks
◆ XQspiPsu_GetLqspiConfigReg
#define XQspiPsu_GetLqspiConfigReg (   InstancePtr)
Value:
#define XQSPIPSU_LQSPI_CR_OFFSET
Definition: xqspipsu_hw.h:149
Definition: xqspipsu_hw.h:67
#define XQspiPsu_In32
Definition: xqspipsu_hw.h:966
Read Configuration register of LQSPI Controller
◆ XQSPIPSU_GF_SNAPSHOT_OFFSET
Register: XQSPIPSU_GF_SNAPSHOT
◆ XQSPIPSU_GF_THRESHOLD_OFFSET
#define XQSPIPSU_GF_THRESHOLD_OFFSET   0X00000050U
Register: XQSPIPSU_GF_THRESHOLD
◆ XQSPIPSU_GPIO_OFFSET
#define XQSPIPSU_GPIO_OFFSET   0X00000030U
Register: XQSPIPSU_GPIO
◆ XQSPIPSU_H_
#define XQSPIPSU_H_
< prevent circular inclusions by using protection macros
◆ XQSPIPSU_HW_H
#define XQSPIPSU_HW_H
◆ XQSPIPSU_IDR_OFFSET
#define XQSPIPSU_IDR_OFFSET   0X0000000CU
Register: XQSPIPSU_IDR
◆ XQSPIPSU_IER_OFFSET
#define XQSPIPSU_IER_OFFSET   0X00000008U
Register: XQSPIPSU_IER
◆ XQSPIPSU_IMR_OFFSET
#define XQSPIPSU_IMR_OFFSET   0X00000010U
Register: XQSPIPSU_IMR
◆ XQspiPsu_In32
#define XQspiPsu_In32   Xil_In32
Read the 32 bit register value
◆ XQSPIPSU_ISR_OFFSET
#define XQSPIPSU_ISR_OFFSET   0X00000004U
Register: XQSPIPSU_ISR
◆ XQSPIPSU_LPBK_DLY_ADJ_OFFSET
#define XQSPIPSU_LPBK_DLY_ADJ_OFFSET   0X00000038U
Register: XQSPIPSU_LPBK_DLY_ADJ
◆ XQSPIPSU_LQSPI_CR_ADDR_32BIT_MASK
#define XQSPIPSU_LQSPI_CR_ADDR_32BIT_MASK   0x01000000U
Upper memory page
◆ XQSPIPSU_LQSPI_CR_LINEAR_MASK
#define XQSPIPSU_LQSPI_CR_LINEAR_MASK   0x80000000U
LQSPI mode enable
◆ XQSPIPSU_LQSPI_CR_MODE_BITS_MASK
#define XQSPIPSU_LQSPI_CR_MODE_BITS_MASK   0x00FF0000U
Mode value for dual I/O or quad I/O
◆ XQSPIPSU_LQSPI_CR_MODE_EN_MASK
#define XQSPIPSU_LQSPI_CR_MODE_EN_MASK   0x02000000U
Enable mode bits
◆ XQSPIPSU_LQSPI_CR_MODE_ON_MASK
#define XQSPIPSU_LQSPI_CR_MODE_ON_MASK   0x01000000U
Mode on
◆ XQSPIPSU_LQSPI_CR_OFFSET
#define XQSPIPSU_LQSPI_CR_OFFSET   0X000000A0U
Register: XQSPIPSU_LQSPI
◆ XQSPIPSU_LQSPI_CR_SEP_BUS_MASK
#define XQSPIPSU_LQSPI_CR_SEP_BUS_MASK   0x20000000U
Separate memory bus
◆ XQSPIPSU_LQSPI_CR_TWO_MEM_MASK
#define XQSPIPSU_LQSPI_CR_TWO_MEM_MASK   0x40000000U
Both memories or one
◆ XQSPIPSU_LQSPI_CR_U_PAGE_MASK
#define XQSPIPSU_LQSPI_CR_U_PAGE_MASK   0x10000000U
Upper memory page
◆ XQSPIPSU_LQSPI_LESS_THEN_SIXTEENMB
#define XQSPIPSU_LQSPI_LESS_THEN_SIXTEENMB   1U
LQSPI less Than 16 MB
◆ XQSPIPSU_LQSPI_MODE_OPTION
#define XQSPIPSU_LQSPI_MODE_OPTION   0x20U
LQSPI mode option
◆ XQSPIPSU_MANUAL_START_OPTION
#define XQSPIPSU_MANUAL_START_OPTION   0x8U
Manual start option
◆ XQSPIPSU_MOD_ID_OFFSET
#define XQSPIPSU_MOD_ID_OFFSET   0X000000FCU
Register: XQSPIPSU_MOD_ID
◆ XQSPIPSU_MSG_FLAG_POLL
#define XQSPIPSU_MSG_FLAG_POLL   0x8U
POLL Msg flag
◆ XQSPIPSU_MSG_FLAG_RX
#define XQSPIPSU_MSG_FLAG_RX   0x2U
Rx Msg flag
◆ XQSPIPSU_MSG_FLAG_STRIPE
#define XQSPIPSU_MSG_FLAG_STRIPE   0x1U
Stripe Msg flag
◆ XQSPIPSU_MSG_FLAG_TX
#define XQSPIPSU_MSG_FLAG_TX   0x4U
Tx Msg flag
◆ XQSPIPSU_NUM_OPTIONS
#define XQSPIPSU_NUM_OPTIONS   (sizeof(OptionsTable) / sizeof(OptionsMap))
Number of options in option table
◆ XQspiPsu_Out32
#define XQspiPsu_Out32   Xil_Out32
Write the 32 bit register value
◆ XQSPIPSU_POLL_CFG_OFFSET
#define XQSPIPSU_POLL_CFG_OFFSET   0X00000054U
Register: XQSPIPSU_POLL_CFG
◆ XQSPIPSU_QSPIDMA_DST_ADDR_OFFSET
#define XQSPIPSU_QSPIDMA_DST_ADDR_OFFSET   0X00000700U
Register: XQSPIPSU_QSPIDMA_DST_ADDR
◆ XQSPIPSU_READMODE_DMA
#define XQSPIPSU_READMODE_DMA   0x0U
DMA read mode
◆ XQSPIPSU_READMODE_IO
#define XQSPIPSU_READMODE_IO   0x1U
IO read mode
◆ XQspiPsu_ReadReg
#define XQspiPsu_ReadReg (   BaseAddress,
  RegOffset
)    XQspiPsu_In32((BaseAddress) + (RegOffset))
Read a register.
Parameters
BaseAddresscontains the base address of the device.
RegOffsetcontains the offset from the 1st register of the device to the target register.
Returns
The value read from the register.
Note
C-Style signature: u32 XQspiPsu_ReadReg(u32 BaseAddress. s32 RegOffset)
◆ XQSPIPSU_RX_COPY_OFFSET
#define XQSPIPSU_RX_COPY_OFFSET   0X00000064U
Register: XQSPIPSU_RX_COPY
◆ XQSPIPSU_RXADDR_OVER_32BIT
#define XQSPIPSU_RXADDR_OVER_32BIT   0x100000000U
Rx address over 32 bit
◆ XQSPIPSU_RXD_OFFSET
#define XQSPIPSU_RXD_OFFSET   0X00000020U
Register: XQSPIPSU_RXD
◆ XQSPIPSU_SEL_OFFSET
#define XQSPIPSU_SEL_OFFSET   0X00000044U
Register: XQSPIPSU_SEL
◆ XQspiPsu_Select
#define XQspiPsu_Select (   InstancePtr,
  Mask
Value:
Definition: xqspipsu_hw.h:506
select QSPI controller
◆ XQSPIPSU_SELECT_FLASH_BUS_BOTH
#define XQSPIPSU_SELECT_FLASH_BUS_BOTH   0x3U
Select both bus flash
◆ XQSPIPSU_SELECT_FLASH_BUS_LOWER
#define XQSPIPSU_SELECT_FLASH_BUS_LOWER   0x1U
Select lower bus flash
◆ XQSPIPSU_SELECT_FLASH_BUS_UPPER
#define XQSPIPSU_SELECT_FLASH_BUS_UPPER   0x2U
Select upper bus flash
◆ XQSPIPSU_SELECT_FLASH_CS_BOTH
#define XQSPIPSU_SELECT_FLASH_CS_BOTH   0x3U
Select both flash
◆ XQSPIPSU_SELECT_FLASH_CS_LOWER
#define XQSPIPSU_SELECT_FLASH_CS_LOWER   0x1U
Select lower flash
◆ XQSPIPSU_SELECT_FLASH_CS_UPPER
#define XQSPIPSU_SELECT_FLASH_CS_UPPER   0x2U
Select upper flash
◆ XQSPIPSU_SELECT_MODE_DUALSPI
#define XQSPIPSU_SELECT_MODE_DUALSPI   0x2U
Select dual SPI mode
◆ XQSPIPSU_SELECT_MODE_QUADSPI
#define XQSPIPSU_SELECT_MODE_QUADSPI   0x4U
Select quad SPI mode
◆ XQSPIPSU_SELECT_MODE_SPI
#define XQSPIPSU_SELECT_MODE_SPI   0x1U
Select SPI mode
◆ XQSPIPSU_SET_WP
#define XQSPIPSU_SET_WP   1
GQSPI configuration to toggle WP of flash
◆ XQSPIPSU_TX_THRESHOLD_OFFSET
#define XQSPIPSU_TX_THRESHOLD_OFFSET   0X00000028U
Register: XQSPIPSU_TX_THRESHOLD
◆ XQSPIPSU_TXD_OFFSET
#define XQSPIPSU_TXD_OFFSET   0X0000001CU
Register: XQSPIPSU_TXD
◆ XQspiPsu_WriteReg
#define XQspiPsu_WriteReg (   BaseAddress,
  RegOffset,
  RegisterValue
)    XQspiPsu_Out32((BaseAddress) + (RegOffset), (RegisterValue))
Write to a register.
Parameters
RegOffsetcontains the offset from the 1st register of the device to target register.
RegisterValueis the value to be written to the register.
Returns
None.
Note
C-Style signature: void XQspiPsu_WriteReg(u32 BaseAddress, s32 RegOffset, u32 RegisterValue) XQSPIPSU_H
◆ XQSPIPSU_XFER_STS_OFFSET
#define XQSPIPSU_XFER_STS_OFFSET   0X0000005CU
Register: XQSPIPSU_XFER_STS
Typedef Documentation
◆ XQspiPsu_StatusHandler
typedef void(* XQspiPsu_StatusHandler) (const void *CallBackRef, u32 StatusEvent, u32 ByteCount)
The handler data type allows the user to define a callback function to handle the asynchronous processing for the QSPIPSU device. The application using this driver is expected to define a handler of this type to support interrupt driven mode. The handler executes in an interrupt context, so only minimal processing should be performed.
Parameters
CallBackRefis the callback reference passed in by the upper layer when setting the callback functions, and passed back to the upper layer when the callback is invoked. Its type is not important to the driver, so it is a void pointer.
StatusEventholds one or more status events that have occurred. See the XQspiPsu_SetStatusHandler() for details on the status events that can be passed in the callback.
ByteCountindicates how many bytes of data were successfully transferred. This may be less than the number of bytes requested if the status event indicates an error.
◆ OnfiCommandList
This enum defines the ONFI 3.1 commands.
READ
Read
MULTIPLANE_READ
Multiplane Read
COPYBACK_READ
Copyback Read
CHANGE_READ_COLUMN
Change Read Column
CHANGE_READ_COLUMN_ENHANCED
READ_CACHE_RANDOM
Read Cache Random
READ_CACHE_SEQUENTIAL
READ_CACHE_END
Read Cache End
BLOCK_ERASE
Block Erase
MULTIPLANE_BLOCK_ERASE
READ_STATUS
Read Status
READ_STATUS_ENHANCED
PAGE_PROGRAM
Page Program
MULTIPLANE_PAGE_PROGRAM
PAGE_CACHE_PROGRAM
Page Cache Program
COPYBACK_PROGRAM
Copyback Program
MULTIPLANE_COPYBACK_PROGRAM
Multiplance Copyback Program
SMALL_DATA_MOVE
Small Data Move
CHANGE_WRITE_COLUMN
Change Write Column
CHANGE_ROW_ADDR
Change Row Address
READ_ID
Read ID
VOLUME_SELECT
Volume Select
ODT_CONFIGURE
ODT Configure
READ_PARAM_PAGE
Read Parameter Page
READ_UNIQUE_ID
Read Unique ID
GET_FEATURES
Get Features
SET_FEATURES
Set Features
LUN_GET_FEATURES
LUN Get Features
LUN_SET_FEATURES
LUN Set Features
RESET_LUN
Reset LUN
SYN_RESET
Synchronous Reset
RESET
Reset
MAX_CMDS
Dummy Command
◆ XNandPsu_DataInterface
The XNandPsu_DataInterface enum contains flash operating mode.
XNANDPSU_SDR
Single Data Rate
XNANDPSU_NVDDR
Double Data Rate
◆ XNandPsu_DmaMode
The XNandPsu_DmaMode enum contains the controller MDMA mode.
XNANDPSU_PIO
PIO Mode
XNANDPSU_SDMA
SDMA Mode
XNANDPSU_MDMA
MDMA Mode
◆ XNandPsu_EccMode
The XNandPsu_EccMode enum contains ECC functionality.
◆ XNandPsu_SWMode
The XNandPsu_SWMode enum contains the driver operating mode.
XNANDPSU_POLLING
Polling
XNANDPSU_INTERRUPT
Interrupt
◆ XNandPsu_TimingMode
XNandPsu_TimingMode enum contains timing modes.
◆ XNandPsu_CfgInitialize()
s32 XNandPsu_CfgInitialize ( XNandPsu InstancePtr,
XNandPsu_Config ConfigPtr,
u32  EffectiveAddr
This function initializes a specific XNandPsu instance. This function must be called prior to using the NAND flash device to read or write any data.
Parameters
InstancePtris a pointer to the XNandPsu instance.
ConfigPtrpoints to XNandPsu device configuration structure.
EffectiveAddris the base address of NAND flash controller.
Returns
  • XST_SUCCESS if successful.
  • XST_FAILURE if fail.
Note
The user needs to first call the XNandPsu_LookupConfig() API which returns the Configuration structure pointer which is passed as a parameter to the XNandPsu_CfgInitialize() API.
◆ XNandPsu_ChangeTimingMode()
s32 XNandPsu_ChangeTimingMode ( XNandPsu InstancePtr,
XNandPsu_DataInterface  NewIntf,
XNandPsu_TimingMode  NewMode
This function changes the data interface and timing mode.
Parameters
NewIntfis the new data interface.
NewModeis the new timing mode.
Returns
  • XST_FAILURE if failed.
Note
None
◆ XNandPsu_DisableDmaMode()
void XNandPsu_DisableDmaMode ( XNandPsu InstancePtr)
This function disables DMA mode of driver/controller operation.
Parameters
Returns
None
Note
None
◆ XNandPsu_DisableEccMode()
void XNandPsu_DisableEccMode ( XNandPsu InstancePtr)
This function disables ECC mode of driver/controller operation.
Parameters
Returns
None
Note
None
◆ XNandPsu_EnableDmaMode()
void XNandPsu_EnableDmaMode ( XNandPsu InstancePtr)
This function enables DMA mode of controller operation.
Parameters
Returns
None
Note
None
◆ XNandPsu_EnableEccMode()
void XNandPsu_EnableEccMode ( XNandPsu InstancePtr)
This function enables ECC mode of driver/controller operation.
Parameters
Returns
None
Note
None
◆ XNandPsu_Erase()
s32 XNandPsu_Erase ( XNandPsu InstancePtr,
u64  Offset,
u64  Length
This function erases the flash.
Parameters
Offsetis the starting offset of flash to erase.
Lengthis the number of bytes to erase.
Returns
Note
The Offset and Length should be aligned to block size boundary to get better results.
◆ XNandPsu_EraseBlock()
s32 XNandPsu_EraseBlock ( XNandPsu InstancePtr,
u32  Target,
u32  Block
This function sends ONFI block erase command to the flash.
Parameters
Targetis the chip select value.
Blockis the block to erase.
Returns
Note
None
◆ XNandPsu_GetFeature()
s32 XNandPsu_GetFeature ( XNandPsu InstancePtr,
u32  Target,
u8  Feature,
u8 *  Buf
This function sends ONFI Get Feature command to flash.
Parameters
Featureis the feature selector.
Bufis the buffer to fill feature value.
Returns
Note
None
◆ XNandPsu_InitBbtDesc()
void XNandPsu_InitBbtDesc ( XNandPsu InstancePtr)
This function initializes the Bad Block Table(BBT) descriptors with a predefined pattern for searching Bad Block Table(BBT) in flash.
Parameters
Returns
  • NONE
◆ XNandPsu_IsBlockBad()
s32 XNandPsu_IsBlockBad ( XNandPsu InstancePtr,
u32  Block
This function checks whether a block is bad or not.
Parameters
InstancePtris the pointer to the XNandPsu instance.
Returns
◆ XNandPsu_MarkBlockBad()
s32 XNandPsu_MarkBlockBad ( XNandPsu InstancePtr,
u32  Block
This function marks a block as bad in the RAM based Bad Block Table(BBT). It also updates the Bad Block Table(BBT) in the flash.
Parameters
Returns
◆ XNandPsu_OnfiParamPageCrc()
u32 XNandPsu_OnfiParamPageCrc ( u8 *  ParamBuf,
u32  StartOff,
u32  Length
This function calculates ONFI parameter page CRC.
Parameters
ParamBufis a pointer to the ONFI parameter page buffer.
StartOffis the starting offset in buffer to calculate CRC.
Lengthis the number of bytes for which CRC is calculated.
Returns
CRC value.
Note
None.
◆ XNandPsu_Prepare_Cmd()
void XNandPsu_Prepare_Cmd ( XNandPsu InstancePtr,
u8  Cmd1,
u8  Cmd2,
u8  EccState,
u8  DmaMode,
u8  AddrCycles
This function prepares command to be written into command register.
Parameters
Cmd1is the first Onfi Command.
Cmd2is the second Onfi Command.
EccStateis the flag to set Ecc State.
DmaModeis the flag to set DMA mode.
AddrCyclesis the number of Address Cycles.
Returns
None
Note
None
◆ XNandPsu_Read()
s32 XNandPsu_Read ( XNandPsu InstancePtr,
u64  Offset,
u64  Length,
u8 *  DestBuf
This function reads from the flash.
Parameters
Offsetis the starting offset of flash to read.
Lengthis the number of bytes to read.
DestBufis the destination data buffer to fill in.
Returns
Note
None
◆ XNandPsu_ReadSpareBytes()
s32 XNandPsu_ReadSpareBytes ( XNandPsu InstancePtr,
u32  Page,
u8 *  Buf
This function reads spare bytes from flash.
Parameters
Pageis the page address value to read.
Bufis the data buffer to fill in.
Returns
Note
None
◆ XNandPsu_ScanBbt()
s32 XNandPsu_ScanBbt ( XNandPsu InstancePtr)
This function reads the Bad Block Table(BBT) if present in flash. If not it scans the flash for detecting factory marked bad blocks and creates a bad block table and write the Bad Block Table(BBT) into the flash.
Parameters
Returns
◆ XNandPsu_SetFeature()
s32 XNandPsu_SetFeature ( XNandPsu InstancePtr,
u32  Target,
u8  Feature,
u8 *  Buf
This function sends ONFI Set Feature command to flash.
Parameters
Bufis the feature value to send.
Returns
Note
None
◆ XNandPsu_Write()
s32 XNandPsu_Write ( XNandPsu InstancePtr,
u64  Offset,
u64  Length,
u8 *  SrcBuf
This function writes to the flash.
Parameters
Offsetis the starting offset of flash to write.
Lengthis the number of bytes to write.
SrcBufis the source data buffer to write.
Returns
Note
None
◆ XNandPsu_WriteSpareBytes()
s32 XNandPsu_WriteSpareBytes ( XNandPsu InstancePtr,
u32  Page,
u8 *  Buf
This function sends ONFI Program Page command to flash.
Parameters
Pageis the page address value to program.
Bufis the data buffer to program.
Returns
Note
None
◆ XQspiPsu_Abort()
void XQspiPsu_Abort ( XQspiPsu InstancePtr)
Aborts a transfer in progress.
Parameters
InstancePtris a pointer to the XQspiPsu instance.
Returns
None.
Note
None.
◆ XQspiPsu_CfgInitialize()
s32 XQspiPsu_CfgInitialize ( XQspiPsu InstancePtr,
const XQspiPsu_Config ConfigPtr,
UINTPTR  EffectiveAddr
Initializes a specific XQspiPsu instance as such the driver is ready to use.
Parameters
ConfigPtris a reference to a structure containing information about a specific QSPIPSU device. This function initializes an InstancePtr object for a specific device specified by the contents of Config.
EffectiveAddris the device base address in the virtual memory address space. The caller is responsible for keeping the address mapping from EffectiveAddr to the device physical base address unchanged once this function is invoked. Unexpected errors may occur if the address mapping changes after this function is called. If address translation is not used, use ConfigPtr->Config.BaseAddress for this device.
Returns
  • XST_DEVICE_IS_STARTED if the device is already started. It must be stopped to re-initialize.
Note
None.
◆ XQspiPsu_CheckDmaDone()
s32 XQspiPsu_CheckDmaDone ( XQspiPsu InstancePtr)
This function check for DMA transfer complete.
Parameters
Returns
  • XST_SUCCESS if DMA transfer complete.
  • XST_FAILURE if DMA transfer is not completed.
Note
None.
◆ XQspiPsu_ClearOptions()
s32 XQspiPsu_ClearOptions ( XQspiPsu InstancePtr,
u32  Options
This function resets the options for the QSPIPSU device driver.The options control how the device behaves relative to the QSPIPSU bus. The device must be idle rather than busy transferring data before setting these device options.
Parameters
Optionscontains the specified options to be set. This is a bit mask where a 1 indicates the option should be turned OFF and a 0 indicates no action. One or more bit values may be contained in the mask. See the bit definitions named XQSPIPSU_*_OPTIONS in the file xqspipsu.h.
Returns
  • XST_SUCCESS if options are successfully set.
  • XST_DEVICE_BUSY if the device is currently transferring data. The transfer must complete or be aborted before setting options.
Note
This function is not thread-safe.
◆ XQspiPsu_CreatePollDataConfig()
u32 XQspiPsu_CreatePollDataConfig ( const XQspiPsu InstancePtr,
const XQspiPsu_Msg FlashMsg
This function creates Poll config register data to write
Parameters
FlashMsgis a pointer to the structure containing transfer data.
Returns
None
Note
None.
◆ XQspiPsu_FillTxFifo()
void XQspiPsu_FillTxFifo ( XQspiPsu InstancePtr,
XQspiPsu_Msg Msg,
u32  Size
Fills the TX FIFO as long as there is room in the FIFO or the bytes required to be transmitted.
Parameters
Sizeis the number of bytes to be transmitted.
Returns
None
Note
None.
◆ XQspiPsu_GenFifoEntryData()
void XQspiPsu_GenFifoEntryData ( XQspiPsu InstancePtr,
XQspiPsu_Msg Msg
This function writes the GENFIFO entries to transmit the messages requested.
Parameters
Returns
  • XST_FAILURE if transfer fails.
  • XST_DEVICE_BUSY if a transfer is already in progress.
Note
None.
◆ XQspiPsu_GenFifoEntryDataLen()
void XQspiPsu_GenFifoEntryDataLen ( XQspiPsu InstancePtr,
XQspiPsu_Msg Msg,
u32 *  GenFifoEntry
This function writes the Data length to GENFIFO entries that need to be transmitted or received.
Parameters
GenFifoEntryis index of the current message to be handled.
Returns
Note
None.
◆ XQspiPsu_GetOptions()
u32 XQspiPsu_GetOptions ( const XQspiPsu InstancePtr)
This function gets the options for the QSPIPSU device. The options control how the device behaves relative to the QSPIPSU bus.
Parameters
Returns
Options contains the specified options currently set. This is a bit value where a 1 means the option is on, and a 0 means the option is off. See the bit definitions named XQSPIPSU_*_OPTIONS in file xqspipsu.h.
Note
None.
◆ XQspiPsu_Idle()
void XQspiPsu_Idle ( const XQspiPsu InstancePtr)
Stops the transfer of data to internal DST FIFO from stream interface and also stops the issuing of new write commands to memory.
By calling this API, any ongoing Dma transfers will be paused and DMA will not issue AXI write commands to memory
Parameters
Returns
None.
Note
None.
◆ XQspiPsu_InterruptHandler()
s32 XQspiPsu_InterruptHandler ( XQspiPsu InstancePtr)
Handles interrupt based transfers by acting on GENFIFO and DMA interurpts.
Parameters
Returns
Note
None.
◆ XQspiPsu_InterruptTransfer()
s32 XQspiPsu_InterruptTransfer ( XQspiPsu InstancePtr,
XQspiPsu_Msg Msg,
u32  NumMsg
This function initiates a transfer on the bus and enables interrupts. The transfer is completed by the interrupt handler. The messages passed are all transferred on the bus between one CS assert and de-assert.
Parameters
NumMsgis the number of messages to be transferred.
Returns
Note
None.
◆ XQspiPsu_IORead()
void XQspiPsu_IORead ( XQspiPsu InstancePtr,
XQspiPsu_Msg Msg,
u32  StatusReg
This function reads data from RXFifo in IO mode.
Parameters
StatusRegis the Interrupt status Register value.
Returns
None.
Note
None.
◆ XQspiPsu_PollDataConfig()
void XQspiPsu_PollDataConfig ( XQspiPsu InstancePtr,
This function enables the polling functionality of controller
Parameters
Returns
None
Note
None.
◆ XQspiPsu_PollDataHandler()
void XQspiPsu_PollDataHandler ( XQspiPsu InstancePtr,
u32  StatusReg
This is the handler for polling functionality of controller. It reads data from RXFIFO, since when data from the flash device (status data) matched with configured value in poll_cfg, then controller writes the matched data into RXFIFO.
Parameters
Returns
None.
Note
None.
◆ XQspiPsu_PolledTransfer()
s32 XQspiPsu_PolledTransfer ( XQspiPsu InstancePtr,
XQspiPsu_Msg Msg,
u32  NumMsg
This function performs a transfer on the bus in polled mode. The messages passed are all transferred on the bus between one CS assert and de-assert.
Parameters
Returns
Note
None.
◆ XQspiPsu_ReadRxFifo()
void XQspiPsu_ReadRxFifo ( XQspiPsu InstancePtr,
XQspiPsu_Msg Msg,
s32  Size
Read the specified number of bytes from RX FIFO
Parameters
Sizeis the number of bytes to be read.
Returns
None
Note
None.
◆ XQspiPsu_Reset()
void XQspiPsu_Reset ( XQspiPsu InstancePtr)
Resets the QSPIPSU device. Reset must only be called after the driver has been initialized. Any data transfer that is in progress is aborted.
The upper layer software is responsible for re-configuring (if necessary) and restarting the QSPIPSU device after the reset.
Parameters
Returns
None.
Note
None.
◆ XQspiPsu_RXSetup()
void XQspiPsu_RXSetup ( XQspiPsu InstancePtr,
XQspiPsu_Msg Msg
This function checks the RX buffers in the message and setup the RX DMA as required.
Parameters
Returns
None
Note
None.
◆ XQspiPsu_SelectFlash()
void XQspiPsu_SelectFlash ( XQspiPsu InstancePtr,
u8  FlashCS,
u8  FlashBus
This function should be used to tell the QSPIPSU driver the HW flash configuration being used. This API should be called at least once in the application. If desired, it can be called multiple times when switching between communicating to different flahs devices/using different configs.
Parameters
FlashCS- Flash Chip Select.
FlashBus- Flash Bus (Upper, Lower or Both).
Returns
Note
If this function is not called at least once in the application, the driver assumes there is a single flash connected to the lower bus and CS line.
◆ XQspiPsu_SelectSpiMode()
u32 XQspiPsu_SelectSpiMode ( u8  SpiMode)
Selects SPI mode - x1 or x2 or x4.
Parameters
SpiMode- spi or dual or quad.
Returns
Mask to set desired SPI mode in GENFIFO entry.
Note
None.
◆ XQspiPsu_SetClkPrescaler()
s32 XQspiPsu_SetClkPrescaler ( const XQspiPsu InstancePtr,
u8  Prescaler
Configures the clock according to the prescaler passed.
Parameters
Prescaler- clock prescaler to be set.
Returns
  • XST_DEVICE_BUSY if the device is currently transferring data. It must be stopped to re-initialize.
Note
None.
◆ XQspiPsu_SetDefaultConfig()
void XQspiPsu_SetDefaultConfig ( XQspiPsu InstancePtr)
Enable and initialize DMA Mode, set little endain, disable poll timeout, clear prescalar bits and reset thresholds
Parameters
Returns
None.
Note
None.
◆ XQspiPsu_SetIOMode()
u32 XQspiPsu_SetIOMode ( XQspiPsu InstancePtr,
XQspiPsu_Msg Msg
This function reads remaining bytes, after the completion of a DMA transfer, using IO mode
Parameters
Returns
Note
None.
◆ XQspiPsu_SetOptions()
s32 XQspiPsu_SetOptions ( XQspiPsu InstancePtr,
u32  Options
This function sets the options for the QSPIPSU device driver.The options control how the device behaves relative to the QSPIPSU bus. The device must be idle rather than busy transferring data before setting these device options.
Parameters
Optionscontains the specified options to be set. This is a bit mask where a 1 indicates the option should be turned ON and a 0 indicates no action. One or more bit values may be contained in the mask. See the bit definitions named XQSPIPSU_*_OPTIONS in the file xqspipsu.h.
Returns
Note
◆ XQspiPsu_SetReadMode()
s32 XQspiPsu_SetReadMode ( XQspiPsu InstancePtr,
u32  Mode
This function sets the Read mode for the QSPIPSU device driver.The device must be idle rather than busy transferring data before setting Read mode options.
Parameters
Modecontains the specified Mode to be set. See the bit definitions named XQSPIPSU_READMODE_* in the file xqspipsu.h.
Returns
  • XST_DEVICE_BUSY if the device is currently transferring data. The transfer must complete or be aborted before setting Mode.
Note
◆ XQspiPsu_SetStatusHandler()
void XQspiPsu_SetStatusHandler ( XQspiPsu InstancePtr,
void *  CallBackRef,
XQspiPsu_StatusHandler  FuncPointer
Sets the status callback function, the status handler, which the driver calls when it encounters conditions that should be reported to upper layer software. The handler executes in an interrupt context, so it must minimize the amount of processing performed. One of the following status events is passed to the status handler.
XST_SPI_TRANSFER_DONE       The requested data transfer is done
XST_SPI_TRANSMIT_UNDERRUN   As a slave device, the master clocked data
            but there were none available in the transmit
            register/FIFO. This typically means the slave
            application did not issue a transfer request
            fast enough, or the processor/driver could not
            fill the transmit register/FIFO fast enough.
XST_SPI_RECEIVE_OVERRUN The QSPIPSU device lost data. Data was received
            but the receive data register/FIFO was full.
Parameters
CallBackRefis the upper layer callback reference passed back when the callback function is invoked.
FuncPointeris the pointer to the callback function.
Returns
None.
Note
The handler is called within interrupt context, so it should do its work quickly and queue potentially time-consuming work to a task-level thread.
◆ XQspiPsu_Setup64BRxDma()
void XQspiPsu_Setup64BRxDma ( const XQspiPsu InstancePtr,
XQspiPsu_Msg Msg
This function sets up the RX DMA operation on a 32bit Machine For 64bit Dma transfers.
Parameters
Returns
None
Note
None.
◆ XQspiPsu_SetupRxDma()
void XQspiPsu_SetupRxDma ( const XQspiPsu InstancePtr,
XQspiPsu_Msg Msg
This function sets up the RX DMA operation.
Parameters
Returns
None
Note
None.
◆ XQspiPsu_SetWP()
void XQspiPsu_SetWP ( const XQspiPsu InstancePtr,
u8  Value
This function sets the Write Protect and Hold options for the QSPIPSU device driver.The device must be idle rather than busy transferring data before setting Write Protect and Hold options.
Parameters
Valueof the WP_HOLD bit in configuration register
Returns
None
Note
This function is not thread-safe. This function can only be used with single flash configuration and x1/x2 data mode. This function cannot be used with x4 data mode and dual parallel and stacked flash configuration.
◆ XQspiPsu_StartDmaTransfer()
s32 XQspiPsu_StartDmaTransfer ( XQspiPsu InstancePtr,
XQspiPsu_Msg Msg,
u32  NumMsg
This function start a DMA transfer.
Parameters
Returns
  • XST_FAILURE if ByteCount is greater than XQSPIPSU_DMA_BYTES_MAX.
Note
None.
◆ XQspiPsu_TXRXSetup()
void XQspiPsu_TXRXSetup ( XQspiPsu InstancePtr,
XQspiPsu_Msg Msg,
u32 *  GenFifoEntry
This function checks the TX/RX buffers in the message and setups up the GENFIFO entries, TX FIFO or RX DMA as required.
Parameters
GenFifoEntryis pointer to the variable in which GENFIFO mask is returned to calling function
Returns
None
Note
None.
◆ XQspiPsu_TXSetup()
void XQspiPsu_TXSetup ( XQspiPsu InstancePtr,
XQspiPsu_Msg Msg
This function checks the TX buffer in the message and setup the TX FIFO as required.
Parameters
Returns
None
Note
None.
◆ XQspiPsu_WriteProtectToggle()
void XQspiPsu_WriteProtectToggle ( const XQspiPsu InstancePtr,
u32  Toggle
This API enables/ disables Write Protect pin on the flash parts.
Parameters
InstancePtris a pointer to the QSPIPSU driver component to use.
Toggleis a value of the GPIO pin
Returns
None
Note
By default WP pin as per the QSPI controller is driven High which means no write protection. Calling this function once will enable the protection.
Variable Documentation
◆ XQspiPsu_ConfigTable
XQspiPsu_Config XQspiPsu_ConfigTable[XPAR_XQSPIPSU_NUM_INSTANCES]
extern
This table contains configuration information for each QSPIPSU device in the system.
