RTEMS 6.1
xdmad.h
6/* */
7/* All rights reserved. */
8/* */
11/* */
14/* */
17/* */
29
30#ifndef _XDMAD_H
31#define _XDMAD_H
32
33
34/*----------------------------------------------------------------------------
35 * Includes
36 *----------------------------------------------------------------------------*/
37
38#include "chip.h"
39#include <assert.h>
40
41
44/*----------------------------------------------------------------------------
45 * Consts
46 *----------------------------------------------------------------------------*/
47#define XDMAD_TRANSFER_MEMORY 0xFF
48#define XDMAD_ALLOC_FAILED 0xFFFF
50#define XDMAD_TRANSFER_TX 0
51#define XDMAD_TRANSFER_RX 1
52
53/* XDMA_MBR_UBC */
54#define XDMA_UBC_NDE (0x1u << 24)
55#define XDMA_UBC_NDE_FETCH_DIS (0x0u << 24)
56#define XDMA_UBC_NDE_FETCH_EN (0x1u << 24)
57#define XDMA_UBC_NSEN (0x1u << 25)
58#define XDMA_UBC_NSEN_UNCHANGED (0x0u << 25)
59#define XDMA_UBC_NSEN_UPDATED (0x1u << 25)
60#define XDMA_UBC_NDEN (0x1u << 26)
61#define XDMA_UBC_NDEN_UNCHANGED (0x0u << 26)
62#define XDMA_UBC_NDEN_UPDATED (0x1u << 26)
63#define XDMA_UBC_NVIEW_Pos 27
64#define XDMA_UBC_NVIEW_Msk (0x3u << XDMA_UBC_NVIEW_Pos)
65#define XDMA_UBC_NVIEW_NDV0 (0x0u << XDMA_UBC_NVIEW_Pos)
66#define XDMA_UBC_NVIEW_NDV1 (0x1u << XDMA_UBC_NVIEW_Pos)
67#define XDMA_UBC_NVIEW_NDV2 (0x2u << XDMA_UBC_NVIEW_Pos)
68#define XDMA_UBC_NVIEW_NDV3 (0x3u << XDMA_UBC_NVIEW_Pos)
69
70/*----------------------------------------------------------------------------
71 * MACRO
72 *----------------------------------------------------------------------------*/
73
76/*----------------------------------------------------------------------------
77 * Types
78 *----------------------------------------------------------------------------*/
83typedef enum _XdmadStatus {
85 XDMAD_PARTIAL_DONE,
86 XDMAD_DONE,
90} eXdmadStatus, eXdmadRC;
91
93typedef enum _XdmadState {
101
103typedef enum _XdmadProgState {
104 XDMAD_SINGLE = 0,
105 XDMAD_MULTI,
106 XDMAD_LLI,
108
110typedef void (*XdmadTransferCallback)(uint32_t Channel, void *pArg, uint32_t status);
111
113typedef struct _XdmadChannel {
115 void *pArg;
116 uint8_t bIrqOwner;
117 uint8_t bSrcPeriphID;
118 uint8_t bDstPeriphID;
119 uint8_t bSrcTxIfID;
120 uint8_t bSrcRxIfID;
121 uint8_t bDstTxIfID;
122 uint8_t bDstRxIfID;
123 volatile uint8_t state;
125
127typedef struct _Xdmad {
128 Xdmac *pXdmacs;
129 sXdmadChannel XdmaChannels[XDMACCHID_NUMBER];
130 uint8_t numControllers;
131 uint8_t numChannels;
132 uint8_t xdmaMutex;
134
135typedef struct _XdmadCfg {
137 uint32_t mbr_ubc;
139 uint32_t mbr_sa;
141 uint32_t mbr_da;
143 uint32_t mbr_cfg;
145 uint32_t mbr_bc;
147 uint32_t mbr_ds;
149 uint32_t mbr_sus;
151 uint32_t mbr_dus;
152} sXdmadCfg;
153
158 uint32_t mbr_nda;
160 uint32_t mbr_ubc;
162 uint32_t mbr_ta;
164
169 uint32_t mbr_nda;
171 uint32_t mbr_ubc;
173 uint32_t mbr_sa;
175 uint32_t mbr_da;
177
182 uint32_t mbr_nda;
184 uint32_t mbr_ubc;
186 uint32_t mbr_sa;
188 uint32_t mbr_da;
190 uint32_t mbr_cfg;
192
197 uint32_t mbr_nda;
199 uint32_t mbr_ubc;
201 uint32_t mbr_sa;
203 uint32_t mbr_da;
205 uint32_t mbr_cfg;
207 uint32_t mbr_bc;
209 uint32_t mbr_ds;
211 uint32_t mbr_sus;
213 uint32_t mbr_dus;
215
218extern sXdmad XDMAD_Instance;
219
220/*----------------------------------------------------------------------------
221 * Exported functions
222 *----------------------------------------------------------------------------*/
225extern uint32_t XDMAD_AllocateChannel(sXdmad *pXdmad,
226 uint8_t bSrcID, uint8_t bDstID);
227extern eXdmadRC XDMAD_FreeChannel(sXdmad *pXdmad, uint32_t dwChannel);
228
229extern eXdmadRC XDMAD_ConfigureTransfer(sXdmad *pXdmad,
230 uint32_t dwChannel,
231 sXdmadCfg *pXdmaParam,
232 uint32_t dwXdmaDescCfg,
233 uint32_t dwXdmaDescAddr,
234 uint32_t dwXdmaIntEn);
235
236extern eXdmadRC XDMAD_PrepareChannel(sXdmad *pXdmad, uint32_t dwChannel);
237
238extern eXdmadRC XDMAD_IsTransferDone(sXdmad *pXdmad, uint32_t dwChannel);
239
240extern eXdmadRC XDMAD_StartTransfer(sXdmad *pXdmad, uint32_t dwChannel);
241
242extern void XDMAD_DoNothingCallback(uint32_t Channel, void *pArg, uint32_t status);
243
244extern bool XDMAD_UpdateStatusFromCallback(sXdmad *pXdmad,
245 uint32_t Channel,
246 uint32_t status);
247
248extern eXdmadRC XDMAD_SetCallback(sXdmad *pXdmad,
249 uint32_t dwChannel,
250 XdmadTransferCallback fCallback,
251 void *pArg);
252
253extern eXdmadRC XDMAD_StopTransfer(sXdmad *pXdmad, uint32_t dwChannel);
256#endif //#ifndef _XDMAD_H
257
This header file provides the interfaces of the Assert Handler.
eXdmadRC XDMAD_ConfigureTransfer(sXdmad *pXdmad, uint32_t dwChannel, sXdmadCfg *pXdmaParam, uint32_t dwXdmaDescCfg, uint32_t dwXdmaDescAddr, uint32_t dwXdmaIntEn)
Configure DMA for a single transfer.
Definition: xdmad.c:396
Start xDMA transfer.
Definition: xdmad.c:457
Free the specified xDMA channel.
Definition: xdmad.c:263
Enable clock of the xDMA peripheral, Enable the dma peripheral, configure configuration register for ...
Definition: xdmad.c:323
Stop DMA transfer.
Definition: xdmad.c:489
eXdmadRC XDMAD_SetCallback(sXdmad *pXdmad, uint32_t dwChannel, XdmadTransferCallback fCallback, void *pArg)
Set the callback function for xDMA channel transfer.
Definition: xdmad.c:293
uint32_t XDMAD_AllocateChannel(sXdmad *pXdmad, uint8_t bSrcID, uint8_t bDstID)
Allocate a XDMA channel for upper layer.
Definition: xdmad.c:244
struct _LinkedListDescriporView2 LinkedListDescriporView2
Structure for storing parameters for DMA view2 that can be performed by the DMA Master transfer.
enum _XdmadState eXdmadState
enum _XdmadProgState eXdmadProgState
struct _XdmadChannel sXdmadChannel
void(* XdmadTransferCallback)(uint32_t Channel, void *pArg, uint32_t status)
Definition: xdmad.h:110
_XdmadState
Definition: xdmad.h:93
enum _XdmadStatus eXdmadStatus
struct _LinkedListDescriporView0 LinkedListDescriporView0
Structure for storing parameters for DMA view0 that can be performed by the DMA Master transfer.
struct _Xdmad sXdmad
struct _LinkedListDescriporView3 LinkedListDescriporView3
Structure for storing parameters for DMA view3 that can be performed by the DMA Master transfer.
struct _LinkedListDescriporView1 LinkedListDescriporView1
Structure for storing parameters for DMA view1 that can be performed by the DMA Master transfer.
_XdmadProgState
Definition: xdmad.h:103
_XdmadStatus
Definition: xdmad.h:83
@ XDMAD_STATE_HALTED
Definition: xdmad.h:99
@ XDMAD_STATE_IN_XFR
Definition: xdmad.h:97
@ XDMAD_STATE_FREE
Definition: xdmad.h:94
@ XDMAD_STATE_ALLOCATED
Definition: xdmad.h:95
@ XDMAD_STATE_DONE
Definition: xdmad.h:98
@ XDMAD_STATE_START
Definition: xdmad.h:96
@ XDMAD_CANCELED
Definition: xdmad.h:89
@ XDMAD_BUSY
Definition: xdmad.h:87
@ XDMAD_ERROR
Definition: xdmad.h:88
@ XDMAD_OK
Definition: xdmad.h:84
Definition: component_xdmac.h:60
Definition: xdmad.h:156
uint32_t mbr_nda
Definition: xdmad.h:158
uint32_t mbr_ta
Definition: xdmad.h:162
uint32_t mbr_ubc
Definition: xdmad.h:160
Definition: xdmad.h:167
uint32_t mbr_da
Definition: xdmad.h:175
uint32_t mbr_nda
Definition: xdmad.h:169
uint32_t mbr_sa
Definition: xdmad.h:173
uint32_t mbr_ubc
Definition: xdmad.h:171
Definition: xdmad.h:180
uint32_t mbr_da
Definition: xdmad.h:188
uint32_t mbr_cfg
Definition: xdmad.h:190
uint32_t mbr_sa
Definition: xdmad.h:186
uint32_t mbr_ubc
Definition: xdmad.h:184
uint32_t mbr_nda
Definition: xdmad.h:182
Definition: xdmad.h:195
uint32_t mbr_cfg
Definition: xdmad.h:205
uint32_t mbr_dus
Definition: xdmad.h:213
uint32_t mbr_nda
Definition: xdmad.h:197
uint32_t mbr_ds
Definition: xdmad.h:209
uint32_t mbr_sa
Definition: xdmad.h:201
uint32_t mbr_sus
Definition: xdmad.h:211
uint32_t mbr_bc
Definition: xdmad.h:207
uint32_t mbr_ubc
Definition: xdmad.h:199
uint32_t mbr_da
Definition: xdmad.h:203
Definition: xdmad.h:135
uint32_t mbr_sus
Definition: xdmad.h:149
uint32_t mbr_bc
Definition: xdmad.h:145
uint32_t mbr_dus
Definition: xdmad.h:151
uint32_t mbr_sa
Definition: xdmad.h:139
uint32_t mbr_ds
Definition: xdmad.h:147
uint32_t mbr_cfg
Definition: xdmad.h:143
uint32_t mbr_da
Definition: xdmad.h:141
uint32_t mbr_ubc
Definition: xdmad.h:137
Definition: xdmad.h:113
uint8_t bDstRxIfID
Definition: xdmad.h:122
Definition: xdmad.h:123
Definition: xdmad.h:118
uint8_t bSrcTxIfID
Definition: xdmad.h:119
Definition: xdmad.h:117
uint8_t bDstTxIfID
Definition: xdmad.h:121
uint8_t bIrqOwner
Definition: xdmad.h:116
Definition: xdmad.h:114
void * pArg
Definition: xdmad.h:115
uint8_t bSrcRxIfID
Definition: xdmad.h:120
Definition: xdmad.h:127
