RTEMS 6.1
| #define | WATCHDOG_DRIVER_TABLE_ENTRY { Watchdog_initialize, NULL, NULL, NULL, NULL, Watchdog_control } |
| rtems_device_driver | Watchdog_initialize (rtems_device_major_number major, rtems_device_minor_number minor, void *arguments) |
| Watchdog Driver Initialization. | |
| rtems_device_driver | Watchdog_control (rtems_device_major_number major, rtems_device_minor_number minor, void *arguments) |
| Watchdog Driver IO Control. | |
This file describes the Watchdog Driver for all boards. A watchdog is a hardware device that will reset the board if not touched in a specific way at a regular interval. It is a simple, yet important, part of many embedded systems.
| #define WATCHDOG_DRIVER_TABLE_ENTRY { Watchdog_initialize, NULL, NULL, NULL, NULL, Watchdog_control } |
This macro defines the watchdog device driver entry points.
| rtems_device_driver Watchdog_control | ( | rtems_device_major_number | major, |
| rtems_device_minor_number | minor, | ||
| void * | arguments | ||
This method implements the IO Control device driver entry point for the watchdog hardware device.
| [in] | major | is the watchdog device major number |
| [in] | minor | is the watchdog device minor number |
| [in] | arguments | points to device driver arguments |
| rtems_device_driver Watchdog_initialize | ( | rtems_device_major_number | major, |
This method initializes the watchdog hardware device. The device should be initialized as DISABLED since BSP initialization may take longer than the timeout period for the watchdog.
