RTEMS 6.1
Data Structures | Typedefs | Variables
userextimpl.h File Reference
This header file provides interfaces of the User Extensions Handler which are only used by the implementation. More...
#include <rtems/score/userextdata.h>
#include <rtems/score/isrlock.h>
struct  User_extensions_Iterator
 Chain iterator for dynamic user extensions. More...
struct  User_extensions_List
struct  User_extensions_Thread_create_context
struct  User_extensions_Fatal_context
typedef struct User_extensions_Iterator User_extensions_Iterator
User_extensions_List _User_extensions_List
 List of active extensions.
Chain_Control _User_extensions_Switches_list
 List of active task switch extensions.
Extension Maintainance
typedef void(* User_extensions_Visitor) (Thread_Control *executing, void *arg, const User_extensions_Table *callouts)
 User extension visitor.
void _User_extensions_Handler_initialization (void)
 Initializes the user extensions handler.
void _User_extensions_Add_set (User_extensions_Control *extension)
 Adds a user extension.
void _User_extensions_Remove_set (User_extensions_Control *extension)
 Removes a user extension.
void _User_extensions_Thread_create_visitor (Thread_Control *executing, void *arg, const User_extensions_Table *callouts)
 Creates a visitor.
void _User_extensions_Thread_delete_visitor (Thread_Control *executing, void *arg, const User_extensions_Table *callouts)
 Deletes a visitor.
void _User_extensions_Thread_start_visitor (Thread_Control *executing, void *arg, const User_extensions_Table *callouts)
 Starts a visitor.
void _User_extensions_Thread_restart_visitor (Thread_Control *executing, void *arg, const User_extensions_Table *callouts)
 Restarts a visitor.
void _User_extensions_Thread_begin_visitor (Thread_Control *executing, void *arg, const User_extensions_Table *callouts)
 Calls the begin function of the thread callout for the visitor.
void _User_extensions_Thread_exitted_visitor (Thread_Control *executing, void *arg, const User_extensions_Table *callouts)
 Calls the exitted function of the thread callout for the visitor.
void _User_extensions_Fatal_visitor (Thread_Control *executing, void *arg, const User_extensions_Table *callouts)
 Calls the fatal function of the thread callout for the visitor.
void _User_extensions_Thread_terminate_visitor (Thread_Control *executing, void *arg, const User_extensions_Table *callouts)
 Terminates a visitor.
void _User_extensions_Iterate (void *arg, User_extensions_Visitor visitor, Chain_Iterator_direction direction)
 Iterates through all user extensions and calls the visitor for each.
