RTEMS 6.1
Files | Data Structures | Macros | Typedefs | Enumerations | Functions
Chain Handler
This group contains the Chain Handler implementation. More...
file  chain.h
 This header file provides interfaces of the Chain Handler which are used by the implementation and the API.
file  chainimpl.h
 This header file provides interfaces of the Chain Handler which are only used by the implementation.
file  chain.c
 This source file contains the implementation of _Chain_Initialize().
file  chainnodecount.c
 This source file contains the implementation of _Chain_Node_count_unprotected().
struct  Chain_Node
 This structure represents a chain node. More...
union  Chain_Control
 This union represents a chain control block. More...
struct  Chain_Iterator
 A chain iterator which is updated during node extraction if it is properly registered. More...
struct  Chain_Iterator_registry
 A registry for chain iterators. More...
#define CHAIN_INITIALIZER_EMPTY(name)    { { { &(name).Tail.Node, NULL }, &(name).Head.Node } }
 Chain initializer for an empty chain with designator name.
#define CHAIN_INITIALIZER_ONE_NODE(node)    { { { (node), NULL }, (node) } }
 Chain initializer for a chain with one node.
#define CHAIN_NODE_INITIALIZER_ONE_NODE_CHAIN(chain)    { &(chain)->Tail.Node, &(chain)->Head.Node }
 Chain node initializer for a chain containing exactly this node.
#define CHAIN_DEFINE_EMPTY(name)    Chain_Control name = CHAIN_INITIALIZER_EMPTY(name)
 Chain definition for an empty chain with designator name.
#define CHAIN_ITERATOR_REGISTRY_INITIALIZER(name)    { CHAIN_INITIALIZER_EMPTY( name.Iterators ) }
 Chain iterator registry initializer for static initialization.
typedef struct Chain_Node Chain_Node
typedef bool(* Chain_Node_order) (const void *key, const Chain_Node *left, const Chain_Node *right)
 Chain node order.
enum  Chain_Iterator_direction { CHAIN_ITERATOR_FORWARD , CHAIN_ITERATOR_BACKWARD }
 The chain iterator direction. More...
void _Chain_Initialize (Chain_Control *the_chain, void *starting_address, size_t number_nodes, size_t node_size)
 Initializes a chain header.
size_t _Chain_Node_count_unprotected (const Chain_Control *chain)
 Returns the node count of the chain.
The Chain Handler is used to manage sets of entities. This handler provides two data structures. The Chain Node data structure is included as the first part of every data structure that will be placed on a chain. The second data structure is Chain Control which is used to manage a set of Chain Nodes.
◆ CHAIN_INITIALIZER_ONE_NODE
#define CHAIN_INITIALIZER_ONE_NODE (   node)     { { { (node), NULL }, (node) } }
See also
CHAIN_NODE_INITIALIZER_ONE_NODE_CHAIN().
◆ CHAIN_ITERATOR_REGISTRY_INITIALIZER
#define CHAIN_ITERATOR_REGISTRY_INITIALIZER (   name)     { CHAIN_INITIALIZER_EMPTY( name.Iterators ) }
Parameters
nameThe designator of the chain iterator registry.
◆ CHAIN_NODE_INITIALIZER_ONE_NODE_CHAIN
#define CHAIN_NODE_INITIALIZER_ONE_NODE_CHAIN (   chain)     { &(chain)->Tail.Node, &(chain)->Head.Node }
See also
CHAIN_INITIALIZER_ONE_NODE().
Typedef Documentation
◆ Chain_Node
This is used to manage each element (node) which is placed on a chain.
Note
Typically, a more complicated structure will use the chain package. The more complicated structure will include a chain node as the first element in its control structure. It will then call the chain package with a pointer to that node element. The node pointer and the higher level structure start at the same address so the user can cast the pointers back and forth.
◆ Chain_Node_order
Chain node order.
Parameters
leftThe left hand side.
rightThe right hand side.
Return values
trueAccording to the order the left node precedes the right node.
falseOtherwise.
◆ Chain_Iterator_direction
Iteration from head to tail.
Iteration from tail to head.
◆ _Chain_Initialize()
void _Chain_Initialize ( Chain_Control the_chain,
void *  starting_address,
size_t  node_size
This routine initializes the_chain structure to manage the contiguous array of number_nodes nodes which starts at starting_address. Each node is of node_size bytes.
Parameters
[out]the_chainSpecifies the chain to initialize.
starting_addressThe starting address of the array of elements.
number_nodesThe number of nodes that will be in the chain.
node_sizeThe size of each node.
◆ _Chain_Node_count_unprotected()
size_t _Chain_Node_count_unprotected ( const Chain_Control chain)
Parameters
chainThe chain to return the node count from.
Note
It does NOT disable interrupts to ensure the atomicity of the operation.
Returns
The node count of the chain.
