RTEMS 6.1
#include <bdpart.h>
Data Fields | |
| rtems_bdpart_format_type | type |
| struct { | |
| rtems_bdpart_format_type type | |
| uint32_t disk_id | |
| bool dos_compatibility | |
| } | mbr |
| struct { | |
| uuid_t disk_id | |
| } | gpt |
Disk format description.
| uint32_t rtems_bdpart_format::disk_id |
Disk ID in MBR at offset 440.
| uuid_t rtems_bdpart_format::disk_id |
Disk ID in GPT header.
| bool rtems_bdpart_format::dos_compatibility |
This option is used for partition table creation and validation checks before a write to the disk. It ensures that the first primary partition and the logical partitions start at head one and sector one under the virtual one head and 63 sectors geometry. Each begin and end of a partition will be aligned to the virtual cylinder boundary.
| struct { ... } rtems_bdpart_format::gpt |
GPT format fields.
| struct { ... } rtems_bdpart_format::mbr |
MBR format fields.
| rtems_bdpart_format_type rtems_bdpart_format::type |
Format type.
