RTEMS 6.1
trng.c File Reference
#include "chip.h"
void TRNG_Enable (void)
 Enables the TRNG to provide Random Values.
void TRNG_Disable (void)
 Disables the TRNG to provide Random Values.
void TRNG_EnableIt (void)
 Data Ready Interrupt enable.
void TRNG_DisableIt (void)
 Data Ready Interrupt Disable.
uint32_t TRNG_GetStatus (void)
 Get the current status register of the given TRNG peripheral.
uint32_t TRNG_GetRandData (void)
 Get the 32-bit Output Data from TRNG peripheral.
Implementation of True Random Number Generator (TRNG)
◆ TRNG_Disable()
void TRNG_Disable ( void  )
Parameters
keyThis key is to be written when the DISABLE bit is set.
◆ TRNG_Enable()
void TRNG_Enable ( void  )
Parameters
keyThis key is to be written when the ENABLE bit is set.
◆ TRNG_GetRandData()
uint32_t TRNG_GetRandData ( void  )
Returns
TRNG output data.
◆ TRNG_GetStatus()
uint32_t TRNG_GetStatus ( void  )
Returns
TRNG status register.
