RTEMS 6.1
tr-fatal-too-large-tls-size.h
2
9/*
10 * Copyright (C) 2021 embedded brains GmbH & Co. KG
11 *
12 * Redistribution and use in source and binary forms, with or without
13 * modification, are permitted provided that the following conditions
14 * are met:
15 * 1. Redistributions of source code must retain the above copyright
16 * notice, this list of conditions and the following disclaimer.
17 * 2. Redistributions in binary form must reproduce the above copyright
18 * notice, this list of conditions and the following disclaimer in the
19 * documentation and/or other materials provided with the distribution.
20 *
21 * THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS "AS IS"
22 * AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE
23 * IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE
24 * ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT OWNER OR CONTRIBUTORS BE
25 * LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR
26 * CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF
27 * SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS
28 * INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN
29 * CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE)
30 * ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE
31 * POSSIBILITY OF SUCH DAMAGE.
32 */
33
34/*
35 * This file is part of the RTEMS quality process and was automatically
36 * generated. If you find something that needs to be fixed or
37 * worded better please post a report or patch to an RTEMS mailing list
38 * or raise a bug report:
39 *
40 * https://www.rtems.org/bugs.html
41 *
42 * For information on updating and regenerating please refer to the How-To
43 * section in the Software Requirements Engineering chapter of the
44 * RTEMS Software Engineering manual. The manual is provided as a part of
45 * a release. For development sources please refer to the online
46 * documentation at:
47 *
48 * https://docs.rtems.org
49 */
50
51#ifndef _TR_FATAL_TOO_LARGE_TLS_SIZE_H
52#define _TR_FATAL_TOO_LARGE_TLS_SIZE_H
53
54#include <rtems.h>
55
56#ifdef __cplusplus
57extern "C" {
58#endif
59
74 rtems_fatal_source source,
76);
77
80#ifdef __cplusplus
81}
82#endif
83
84#endif /* _TR_FATAL_TOO_LARGE_TLS_SIZE_H */
void AcfgValFatalTooLargeTlsSize_Run(rtems_fatal_source source, rtems_fatal_code code)
Runs the parameterized test case.
Definition: tr-fatal-too-large-tls-size.c:159
Internal_errors_t rtems_fatal_code
This integer type represents system termination codes.
Definition: extension.h:162
Internal_errors_Source
This type lists the possible sources from which an error can be reported.
Definition: interr.h:63
Definition: inftrees.h:24
