Tests a fatal error.
More...
This test case performs the following actions:
- The test action is carried out by providing a thread-local storage object of sufficient size with respect to the application configuration of the test suite.
- Check that the expected fatal source is present.
- Check that the expected fatal code is present.
- Check that the CONFIGURE_MAXIMUM_THREAD_LOCAL_STORAGE_SIZE application configuration option resulted in the expected system setting.
◆ AcfgValFatalTooLargeTlsSize_Run()
Runs the parameterized test case.
- Parameters
| source | is fatal source. |
| code | is fatal code. |
