RTEMS 6.1
This source file contains the implementation of rtems_event_system_receive(). More...
#include <rtems/rtems/eventimpl.h>#include <rtems/rtems/tasksdata.h>#include <rtems/score/statesimpl.h>#include <rtems/score/threadimpl.h>Functions | |
| rtems_status_code | rtems_event_system_receive (rtems_event_set event_in, rtems_option option_set, rtems_interval ticks, rtems_event_set *event_out) |
| Receives or gets a system event set from the executing task. | |
| rtems_status_code rtems_event_system_receive | ( | rtems_event_set | event_in, |
| rtems_option | option_set, | ||
| rtems_interval | ticks, | ||
| rtems_event_set * | event_out | ||
| event_in | is the event set of interest. Use RTEMS_PENDING_EVENTS to get the pending events. |
| option_set | is the option set. |
| ticks | is the timeout in clock ticks if the RTEMS_WAIT option was set. Use RTEMS_NO_TIMEOUT to wait potentially forever. |
| event_out | is the pointer to an event set. The received or pending events are stored in the referenced event set if the operation was successful. |
This directive performs the same actions as the rtems_event_receive() directive except that it operates with a different set of events for each task.
The following constraints apply to this directive:
