| RTEMS_LINKER_RWSET_ITEM_DECLARE (_Sysinit, rtems_sysinit_item, _Sysinit_Verbose) |
| SYSINIT_VERBOSE (BSP_EARLY) |
| SYSINIT_VERBOSE (MEMORY) |
| SYSINIT_VERBOSE (DIRTY_MEMORY) |
| SYSINIT_VERBOSE (ZERO_MEMORY) |
| SYSINIT_VERBOSE (ISR_STACK) |
| SYSINIT_VERBOSE (PER_CPU_DATA) |
| SYSINIT_VERBOSE (SBRK) |
| SYSINIT_VERBOSE (STACK_ALLOCATOR) |
| SYSINIT_VERBOSE (WORKSPACE) |
| SYSINIT_VERBOSE (MALLOC) |
| SYSINIT_VERBOSE (BSP_START) |
| SYSINIT_VERBOSE (CPU_COUNTER) |
| SYSINIT_VERBOSE (TARGET_HASH) |
| SYSINIT_VERBOSE (INITIAL_EXTENSIONS) |
| SYSINIT_VERBOSE (MP_EARLY) |
| SYSINIT_VERBOSE (DATA_STRUCTURES) |
| SYSINIT_VERBOSE (MP) |
| SYSINIT_VERBOSE (USER_EXTENSIONS) |
| SYSINIT_VERBOSE (CLASSIC_TASKS) |
| SYSINIT_VERBOSE (CLASSIC_TASKS_MP) |
| SYSINIT_VERBOSE (CLASSIC_TIMER) |
| SYSINIT_VERBOSE (CLASSIC_SIGNAL_MP) |
| SYSINIT_VERBOSE (CLASSIC_EVENT_MP) |
| SYSINIT_VERBOSE (CLASSIC_MESSAGE_QUEUE) |
| SYSINIT_VERBOSE (CLASSIC_MESSAGE_QUEUE_MP) |
| SYSINIT_VERBOSE (CLASSIC_SEMAPHORE) |
| SYSINIT_VERBOSE (CLASSIC_SEMAPHORE_MP) |
| SYSINIT_VERBOSE (CLASSIC_PARTITION) |
| SYSINIT_VERBOSE (CLASSIC_PARTITION_MP) |
| SYSINIT_VERBOSE (CLASSIC_REGION) |
| SYSINIT_VERBOSE (CLASSIC_DUAL_PORTED_MEMORY) |
| SYSINIT_VERBOSE (CLASSIC_RATE_MONOTONIC) |
| SYSINIT_VERBOSE (CLASSIC_BARRIER) |
| SYSINIT_VERBOSE (POSIX_SIGNALS) |
| SYSINIT_VERBOSE (POSIX_THREADS) |
| SYSINIT_VERBOSE (POSIX_MESSAGE_QUEUE) |
| SYSINIT_VERBOSE (POSIX_SEMAPHORE) |
| SYSINIT_VERBOSE (POSIX_TIMER) |
| SYSINIT_VERBOSE (POSIX_SHM) |
| SYSINIT_VERBOSE (POSIX_KEYS) |
| SYSINIT_VERBOSE (POSIX_CLEANUP) |
| SYSINIT_VERBOSE (IDLE_THREADS) |
| SYSINIT_VERBOSE (LIBIO) |
| SYSINIT_VERBOSE (USER_ENVIRONMENT) |
| SYSINIT_VERBOSE (ROOT_FILESYSTEM) |
| SYSINIT_VERBOSE (DRVMGR) |
| SYSINIT_VERBOSE (MP_SERVER) |
| SYSINIT_VERBOSE (BSP_PRE_DRIVERS) |
| SYSINIT_VERBOSE (DRVMGR_LEVEL_1) |
| SYSINIT_VERBOSE (DEVICE_DRIVERS) |
| SYSINIT_VERBOSE (DRVMGR_LEVEL_2) |
| SYSINIT_VERBOSE (DRVMGR_LEVEL_3) |
| SYSINIT_VERBOSE (DRVMGR_LEVEL_4) |
| SYSINIT_VERBOSE (MP_FINALIZE) |
| SYSINIT_VERBOSE (CLASSIC_USER_TASKS) |
| SYSINIT_VERBOSE (POSIX_USER_THREADS) |
| SYSINIT_VERBOSE (STD_FILE_DESCRIPTORS) |
| SYSINIT_VERBOSE (LAST) |
void | _Sysinit_Verbose (void) |
| | Enables a verbose system initialization.
This source file contains the implementation of _Sysinit_Verbose().
