RTEMS 6.1
rtems_telnetd_config_table Struct Reference
Telnet configuration structure. More...
#include <telnetd.h>
rtems_telnetd_command command
 Function invoked for each Telnet connection.
void * arg
 Argument for command function.
rtems_task_priority priority
 Task priority.
size_t stack_size
 Task stack size.
rtems_shell_login_check_t login_check
 Login check function.
bool keep_stdio
 This is an obsolete configuration option.
uint16_t client_maximum
 Maximum number of clients which can connect to the system at a time.
uint16_t port
 Server port number in host byte order.
Field Documentation
◆ client_maximum
uint16_t rtems_telnetd_config_table::client_maximum
Use 0 for the default value.
◆ command
rtems_telnetd_command rtems_telnetd_config_table::command
The first parameter contains the device name. The second parameter contains the argument pointer of this configuration table.
◆ keep_stdio
bool rtems_telnetd_config_table::keep_stdio
It must be set to false, otherwise rtems_telnetd_start() will do nothing and returns with a status of RTEMS_NOT_IMPLEMENTED.
◆ login_check
rtems_shell_login_check_t rtems_telnetd_config_table::login_check
Method used for login checks. Use NULL to disable a login check.
◆ port
uint16_t rtems_telnetd_config_table::port
◆ priority
rtems_task_priority rtems_telnetd_config_table::priority
Task priority.
◆ stack_size
size_t rtems_telnetd_config_table::stack_size
Task stack size.
