RTEMS 6.1
rtems_rtl_unresolv_symbol Struct Reference
#include <rtl-unresolved.h>
uint16_t refs
uint16_t flags
uint16_t length
const char name []
Unresolved externals symbols. The symbols are reference counted and separate from the relocation records because a number of records could reference the same symbol.
The name is extended in the allocator of the record in the unresolved data block. The 10 is a minimum that is added to by joining more than one record.
Field Documentation
◆ flags
uint16_t rtems_rtl_unresolv_symbol::flags
Flags to manage the symbol.
◆ length
uint16_t rtems_rtl_unresolv_symbol::length
The length of this name.
◆ name
const char rtems_rtl_unresolv_symbol::name[]
The symbol name.
◆ refs
uint16_t rtems_rtl_unresolv_symbol::refs
The number of references to this name.
