RTEMS 6.1
rtems_rap_data_s Struct Reference
pthread_once_t once
rtems_mutex lock
rtems_chain_control apps
int last_errno
char last_error [64]
The global RAP data. This structure is allocated on the heap when the first call to location an application and is never released.
Field Documentation
◆ apps
rtems_chain_control rtems_rap_data_s::apps
List if loaded application.
◆ last_errno
int rtems_rap_data_s::last_errno
Last error number.
◆ last_error
char rtems_rap_data_s::last_error[64]
Last error string.
◆ lock
rtems_mutex rtems_rap_data_s::lock
The RAP lock id
