RTEMS 6.1
msdos_format_request_param_t Struct Reference
FAT file system format request parameters. More...
#include <dosfs.h>
const char * OEMName
 OEM name string or NULL.
const char * VolLabel
 Volume label string or NULL.
uint32_t sectors_per_cluster
 Sectors per cluster hint.
uint32_t fat_num
 Number of FATs hint.
uint32_t files_per_root_dir
 Minimum files in root directory for FAT12 and FAT16.
uint8_t media
 Media code.
bool quick_format
 Quick format.
bool skip_alignment
 Do not align FAT, data cluster, and root directory to a cluster boundary.
bool sync_device
 Synchronize device after write operations.
int info_level
 The amount of info to output.
Field Documentation
◆ fat_num
uint32_t msdos_format_request_param_t::fat_num
Use 0 as default value.
◆ files_per_root_dir
uint32_t msdos_format_request_param_t::files_per_root_dir
The format procedure may choose a greater value. Use 0 as default value.
◆ media
uint8_t msdos_format_request_param_t::media
Media code.
Use 0 as default value. The default media code is 0xf8.
◆ quick_format
bool msdos_format_request_param_t::quick_format
Quick format.
If set to true, then do not clear data sectors to zero.
◆ sectors_per_cluster
uint32_t msdos_format_request_param_t::sectors_per_cluster
The format procedure may choose another value. Use 0 as default value.
