RTEMS 6.1
mpc55xx_dspi_bus_entry Struct Reference
LibI2C bus driver entry. More...
#include <dspi.h>
rtems_libi2c_bus_t bus
 Standard bus driver fields.
unsigned table_index
 Index in the bus table: mpc55xx_dspi_bus_table.
unsigned bus_number
 Bus number (available after rtems_libi2c_register_bus()).
volatile struct DSPI_tagregs
 Hardware registers.
bool master
 Selects SPI master or slave mode.
union DSPI_PUSHR_tag push_data
 Data for the Push Register.
mpc55xx_dspi_edma_entry edma_transmit
 eDMA entry for transmission.
mpc55xx_dspi_edma_entry edma_push
 eDMA entry for push data generation.
mpc55xx_dspi_edma_entry edma_receive
 eDMA entry for receiving.
uint32_t idle_char
 Idle character transmitted in read only mode.
uint32_t baud
 Current baud.
Field Documentation
◆ bus_number
unsigned mpc55xx_dspi_bus_entry::bus_number
Note
You must set it in the initialization code after the bus registration.
◆ edma_push
mpc55xx_dspi_edma_entry mpc55xx_dspi_bus_entry::edma_push
You can choose every available channel.
◆ edma_receive
mpc55xx_dspi_edma_entry mpc55xx_dspi_bus_entry::edma_receive
The channel is fixed to a particular DSPI.
◆ edma_transmit
mpc55xx_dspi_edma_entry mpc55xx_dspi_bus_entry::edma_transmit
