RTEMS 6.1
lpc176x_scb Struct Reference
System Control Block representation. More...
#include <lpc176x.h>
uint32_t flashcfg
 Flash Accelerator Configuration Register.
uint32_t reserved_04 [15]
uint32_t memmap
 Memopry Map Control.
uint32_t reserved_44 [15]
lpc176x_pll pll_0
 Phase-Locked Loop 0.
uint32_t reserved_90 [4]
lpc176x_pll pll_1
 Phase-Locked Loop 1.
uint32_t reserved_b0 [4]
uint32_t pcon
 Power Mode Control register.
uint32_t pconp
 Power Control for Peripherals register.
uint32_t reserved_c8 [15]
uint32_t cclksel
 Selects the divide valuefor creating the CPU clock from the PPL0 output.
uint32_t usbclksel
 Selects the divide value for creating the USB clock from the PPL0 output.
uint32_t clksrcsel
 Clock Source Select register.
uint32_t reserved_110 [12]
uint32_t extint
 External Interrupt flag register.
uint32_t reserved_144
uint32_t extmode
 External Interrupt Mode register.
uint32_t extpolar
 External Interrupt Polarity register.
uint32_t reserved_150 [12]
uint32_t rsid
 Reset Source Identification Register.
uint32_t reserved_184 [7]
uint32_t scs
 System Controls and Status Register.
uint32_t reserved_1a4
uint32_t pclksel [2]
 Peripheral Clock Selection registers 0 and 1.
uint32_t pboost
 Peripheral boost.
uint32_t reserved_1b4 [5]
uint32_t clkoutcfg
 Clock Output Configuration Register.
uint32_t rstcon [2]
 Reset Control bit 0 and 1.
uint32_t reserved_1d4 [4]
