RTEMS 6.1
imx_gpio_pin Struct Reference
#include <imx-gpio.h>
volatile struct imx_gpiogpio
uint32_t mask
unsigned int shift
enum imx_gpio_mode mode
bool is_active_low
A i.MX GPIO pin or set of pins.
Use this structures to handle pins in the application. You can either get them from an FDT entry (with imx_gpio_init_from_fde_property) or fill them by hand.
Field Documentation
◆ gpio
volatile struct imx_gpio* imx_gpio_pin::gpio
Management structure for the GPIO. Get with imx_gpio_get_by_index.
◆ is_active_low
bool imx_gpio_pin::is_active_low
Whether the pin is active low. Only used to store the last field of the FDT entries. Can be queried via the imx_gpio_get_active_level.
◆ mask
uint32_t imx_gpio_pin::mask
Select the pins you want to handle with this mask. The mask is not influenced by the shift field.
◆ mode
enum imx_gpio_mode imx_gpio_pin::mode
Whether the pin is an input, output, interrupt, ...
◆ shift
unsigned int imx_gpio_pin::shift
If set to something != 0: Shift the pins that many bits.
