RTEMS 6.1
SNVS config structure. More...
#include <fsl_snvs_hp.h>
Data Fields | |
| bool | rtcCalEnable |
| uint32_t | rtcCalValue |
| uint32_t | periodicInterruptFreq |
This structure holds the configuration settings for the SNVS peripheral. To initialize this structure to reasonable defaults, call the SNVS_GetDefaultConfig() function and pass a pointer to your config structure instance.
The config struct can be made const so it resides in flash
| uint32_t _snvs_hp_rtc_config::periodicInterruptFreq |
Defines frequency of the periodic interrupt; Range from 0 to 15
| bool _snvs_hp_rtc_config::rtcCalEnable |
true: RTC calibration mechanism is enabled; false:No calibration is used
| uint32_t _snvs_hp_rtc_config::rtcCalValue |
Defines signed calibration value for nonsecure RTC; This is a 5-bit 2's complement value, range from -16 to +15
