RTEMS 6.1
_sensor_output Struct Reference
uint8_t type
sensorOutputResolution_t output_resolution
sensorOutputFormat_t output_format
uint8_t supported
uint32_t output_width
uint32_t output_height
const sensorReg_toutput_setting
Field Documentation
◆ output_format
sensorOutputFormat_t _sensor_output::output_format
sensor output resolution
◆ output_height
uint32_t _sensor_output::output_height
output width
◆ output_resolution
sensorOutputResolution_t _sensor_output::output_resolution
Index 0: normal, 1: AF setting
◆ output_setting
const sensorReg_t* _sensor_output::output_setting
output height
◆ output_width
uint32_t _sensor_output::output_width
supported for current output_resolution
◆ supported
uint8_t _sensor_output::supported
sensor output format
