RTEMS 6.1
_semc_config_t Struct Reference
SEMC configuration structure. More...
#include <fsl_semc.h>
semc_dqs_mode_t dqsMode
uint8_t cmdTimeoutCycles
uint8_t busTimeoutCycles
semc_axi_queueweight_t queueWeight
busTimeoutCycles: when busTimeoutCycles is zero, the bus timeout cycle is 255*1024. otherwise the bus timeout cycles is busTimeoutCycles*1024. cmdTimeoutCycles: is used for command execution timeout cycles. it's similar to the busTimeoutCycles.
