RTEMS 6.1
_rtems_rfs_format_config Struct Reference
#include <rtems-rfs-format.h>
size_t block_size
size_t group_blocks
size_t group_inodes
int inode_overhead
size_t max_name_length
bool initialise_inodes
bool verbose
RFS File System Configuration data used to format the file system. For default values leave the field set to 0.
Field Documentation
◆ block_size
size_t _rtems_rfs_format_config::block_size
The size of a block.
◆ group_blocks
size_t _rtems_rfs_format_config::group_blocks
The number of blocks in a group.
◆ group_inodes
size_t _rtems_rfs_format_config::group_inodes
The number of inodes in a group.
◆ initialise_inodes
bool _rtems_rfs_format_config::initialise_inodes
Initialise the inode tables to all ones.
◆ inode_overhead
int _rtems_rfs_format_config::inode_overhead
The percentage overhead allocated to inodes.
◆ max_name_length
size_t _rtems_rfs_format_config::max_name_length
The maximum length of a name.
◆ verbose
bool _rtems_rfs_format_config::verbose
Is the format verbose.
