RTEMS 6.1
_rdc_mem_access_config Struct Reference
Memory region domain access control configuration. More...
#include <fsl_rdc.h>
rdc_mem_t mem
bool lock
uint64_t baseAddress
uint64_t endAddress
uint16_t policy
Note that when setting the baseAddress and endAddress, should be aligned to the region resolution, see rdc_mem_t definitions.
Field Documentation
◆ baseAddress
uint64_t _rdc_mem_access_config::baseAddress
Start address of the memory region.
◆ endAddress
uint64_t _rdc_mem_access_config::endAddress
End address of the memory region.
◆ lock
bool _rdc_mem_access_config::lock
Lock the configuration.
◆ mem
rdc_mem_t _rdc_mem_access_config::mem
Memory region descriptor name.
◆ policy
uint16_t _rdc_mem_access_config::policy
Access policy.
