RTEMS 6.1
Structure is used to hold the parameters to configure a PWM fault. More...
#include <fsl_pwm.h>
Data Fields | |
| pwm_fault_clear_t | faultClearingMode |
| bool | faultLevel |
| bool | enableCombinationalPath |
| pwm_fault_recovery_mode_t | recoverMode |
| bool _pwm_fault_param::enableCombinationalPath |
true: Combinational Path from fault input is enabled; false: No combination path is available
| pwm_fault_clear_t _pwm_fault_param::faultClearingMode |
Fault clearing mode to use
| bool _pwm_fault_param::faultLevel |
true: Logic 1 indicates fault; false: Logic 0 indicates fault
| pwm_fault_recovery_mode_t _pwm_fault_param::recoverMode |
Specify when to re-enable the PWM output
