RTEMS 6.1
Structure for the user to configure the fault input filter. More...
#include <fsl_pwm.h>
Data Fields | |
| uint8_t | faultFilterCount |
| uint8_t | faultFilterPeriod |
| bool | faultGlitchStretch |
| uint8_t _pwm_fault_input_filter_param::faultFilterCount |
Fault filter count
| uint8_t _pwm_fault_input_filter_param::faultFilterPeriod |
Fault filter period;value of 0 will bypass the filter
| bool _pwm_fault_input_filter_param::faultGlitchStretch |
Fault Glitch Stretch Enable: A logic 1 means that input fault signals will be stretched to at least 2 IPBus clock cycles
