RTEMS 6.1
_pmu_static_lpsr_ana_ldo_config Struct Reference
LPSR ANA LDO config. More...
#include <fsl_pmu.h>
pmu_ldo_operate_mode_t mode
bool enable2mALoad
bool enable4mALoad
bool enable20uALoad
bool enableStandbyMode
Field Documentation
◆ enable20uALoad
bool _pmu_static_lpsr_ana_ldo_config::enable20uALoad
Enable/Disable 20uA load.
  • true Enables 20uA loading to prevent overshoot;
  • false Disables 20uA load.
◆ enable2mALoad
bool _pmu_static_lpsr_ana_ldo_config::enable2mALoad
Enable/Disable 2mA load.
  • true Enables 2mA loading to prevent overshoot;
  • false Disables 2mA loading.
◆ enable4mALoad
bool _pmu_static_lpsr_ana_ldo_config::enable4mALoad
Enable/Disable 4mA load.
  • true Enables 4mA loading to prevent dramatic voltage drop;
  • false Disables 4mA load.
◆ enableStandbyMode
bool _pmu_static_lpsr_ana_ldo_config::enableStandbyMode
Enable/Disable Standby Mode.
  • true Enables Standby mode, if the STBY assert, the LPSR ANA LDO enter LP mode
  • false Disables Standby mode.
◆ mode
pmu_ldo_operate_mode_t _pmu_static_lpsr_ana_ldo_config::mode
The operate mode of LPSR ANA LDO.
