RTEMS 6.1
SNVS DIG LDO config. More...
#include <fsl_pmu.h>
| pmu_snvs_dig_charge_pump_current_t _pmu_snvs_dig_config::chargePumpCurrent |
The current of SNVS DIG LDO's charge pump current.
| pmu_snvs_dig_discharge_resistor_value_t _pmu_snvs_dig_config::dischargeResistorValue |
The value of SNVS DIG LDO's Discharge Resistor.
| bool _pmu_snvs_dig_config::enableLdoStable |
Enable/Disable SNVS DIG LDO Stable.
| bool _pmu_snvs_dig_config::enablePullDown |
Enable/Disable Pull down.
| pmu_ldo_operate_mode_t _pmu_snvs_dig_config::mode |
The operate mode the SNVS DIG LDO.
| uint8_t _pmu_snvs_dig_config::trimValue |
The trim value.
