RTEMS 6.1
PDM voice activity detector noise filter user configuration structure. More...
#include <fsl_pdm.h>
Data Fields | |
| bool | enableAutoNoiseFilter |
| bool | enableNoiseMin |
| bool | enableNoiseDecimation |
| bool | enableNoiseDetectOR |
| uint32_t | noiseFilterAdjustment |
| uint32_t | noiseGain |
| bool _pdm_hwvad_noise_filter::enableAutoNoiseFilter |
If noise fileter automatically activated, true means enable
| bool _pdm_hwvad_noise_filter::enableNoiseDecimation |
If enable noise input decimation
| bool _pdm_hwvad_noise_filter::enableNoiseDetectOR |
Enables a OR logic in the output of minimum noise estimator block
| bool _pdm_hwvad_noise_filter::enableNoiseMin |
If Noise minimum block enabled, true means enabled
| uint32_t _pdm_hwvad_noise_filter::noiseFilterAdjustment |
The adjustment value of the noise filter
| uint32_t _pdm_hwvad_noise_filter::noiseGain |
Gain value for the noise energy or envelope estimated
