RTEMS 6.1
MECC ocram single error information, including single error address, ECC code, error data and error bit position. More...
#include <fsl_mecc.h>
Data Fields | |
| uint32_t | singleErrorAddress |
| uint32_t | singleErrorDataLow |
| uint32_t | singleErrorDataHigh |
| uint32_t | singleErrorPosLow |
| uint32_t | singleErrorPosHigh |
| uint8_t | singleErrorEccCode |
| uint32_t _mecc_single_error_info::singleErrorAddress |
Single error address on Ocram bank n
| uint32_t _mecc_single_error_info::singleErrorDataHigh |
Single error high 32 bits uncorrected read data on Ocram bank n
| uint32_t _mecc_single_error_info::singleErrorDataLow |
Single error low 32 bits uncorrected read data on Ocram bank n
| uint8_t _mecc_single_error_info::singleErrorEccCode |
Single error ECC code on Ocram bank n
| uint32_t _mecc_single_error_info::singleErrorPosHigh |
Single error bit postion of high 32 bits read data on Ocram bank n
| uint32_t _mecc_single_error_info::singleErrorPosLow |
Single error bit postion of low 32 bits read data on Ocram bank n
