RTEMS 6.1
_lpspi_slave_config Struct Reference
LPSPI slave configuration structure. More...
#include <fsl_lpspi.h>
uint32_t bitsPerFrame
lpspi_clock_polarity_t cpol
lpspi_clock_phase_t cpha
lpspi_shift_direction_t direction
lpspi_which_pcs_t whichPcs
lpspi_pcs_polarity_config_t pcsActiveHighOrLow
lpspi_pin_config_t pinCfg
lpspi_data_out_config_t dataOutConfig
Field Documentation
◆ bitsPerFrame
uint32_t _lpspi_slave_config::bitsPerFrame
Bits per frame, minimum 8, maximum 4096.
◆ cpha
lpspi_clock_phase_t _lpspi_slave_config::cpha
Clock phase.
◆ cpol
lpspi_clock_polarity_t _lpspi_slave_config::cpol
Clock polarity.
◆ dataOutConfig
lpspi_data_out_config_t _lpspi_slave_config::dataOutConfig
Configures if the output data is tristated between accesses (LPSPI_PCS is negated).
◆ direction
lpspi_shift_direction_t _lpspi_slave_config::direction
MSB or LSB data shift direction.
◆ pcsActiveHighOrLow
lpspi_pcs_polarity_config_t _lpspi_slave_config::pcsActiveHighOrLow
Desired PCS active high or low
◆ pinCfg
lpspi_pin_config_t _lpspi_slave_config::pinCfg
Configures which pins are used for input and output data during single bit transfers.
◆ whichPcs
lpspi_which_pcs_t _lpspi_slave_config::whichPcs
Desired Peripheral Chip Select (pcs)
