RTEMS 6.1
LPSPI master transfer handle structure used for transactional API. More...
#include <fsl_lpspi.h>
Data Fields | |
| volatile bool | isPcsContinuous |
| volatile bool | writeTcrInIsr |
| volatile bool | isByteSwap |
| volatile bool | isTxMask |
| volatile uint16_t | bytesPerFrame |
| volatile uint8_t | fifoSize |
| volatile uint8_t | rxWatermark |
| volatile uint8_t | bytesEachWrite |
| volatile uint8_t | bytesEachRead |
| uint8_t *volatile | txData |
| uint8_t *volatile | rxData |
| volatile size_t | txRemainingByteCount |
| volatile size_t | rxRemainingByteCount |
| volatile uint32_t | writeRegRemainingTimes |
| volatile uint32_t | readRegRemainingTimes |
| uint32_t | totalByteCount |
| uint32_t | txBuffIfNull |
| volatile uint8_t | state |
| lpspi_master_transfer_callback_t | callback |
| void * | userData |
| volatile uint8_t _lpspi_master_handle::bytesEachRead |
Bytes for each read RDR.
| volatile uint8_t _lpspi_master_handle::bytesEachWrite |
Bytes for each write TDR.
| volatile uint16_t _lpspi_master_handle::bytesPerFrame |
Number of bytes in each frame
| lpspi_master_transfer_callback_t _lpspi_master_handle::callback |
Completion callback.
| volatile uint8_t _lpspi_master_handle::fifoSize |
FIFO dataSize.
| volatile bool _lpspi_master_handle::isByteSwap |
A flag that whether should byte swap.
| volatile bool _lpspi_master_handle::isPcsContinuous |
Is PCS continuous in transfer.
| volatile bool _lpspi_master_handle::isTxMask |
A flag that whether TCR[TXMSK] is set.
| volatile uint32_t _lpspi_master_handle::readRegRemainingTimes |
Read RDR register remaining times.
| uint8_t* volatile _lpspi_master_handle::rxData |
Receive buffer.
| volatile size_t _lpspi_master_handle::rxRemainingByteCount |
Number of bytes remaining to receive.
| volatile uint8_t _lpspi_master_handle::rxWatermark |
Rx watermark.
| volatile uint8_t _lpspi_master_handle::state |
LPSPI transfer state , _lpspi_transfer_state.
| uint32_t _lpspi_master_handle::totalByteCount |
Number of transfer bytes
| uint32_t _lpspi_master_handle::txBuffIfNull |
Used if the txData is NULL.
| uint8_t* volatile _lpspi_master_handle::txData |
Send buffer.
| volatile size_t _lpspi_master_handle::txRemainingByteCount |
Number of bytes remaining to send.
| void* _lpspi_master_handle::userData |
Callback user data.
| volatile uint32_t _lpspi_master_handle::writeRegRemainingTimes |
Write TDR register remaining times.
| volatile bool _lpspi_master_handle::writeTcrInIsr |
A flag that whether should write TCR in ISR.
